Re: Who has milled their Stealths? [Re: rexus31] #305392
05/05/09 12:37 AM
05/05/09 12:37 AM
organ
maximum entropy Offline
organ
i could do it!
Re: Who has milled their Stealths? [Re: maximum entropy] #305393
05/05/09 01:39 PM
05/05/09 01:39 PM
NL
Frederick Offline
Frederick  Offline
NL
Milled 0.050" to get at 75cc chambers.
Now at 9.3:1 with a +0.030 383 with pistons 0.040 down.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: Who has milled their Stealths? [Re: Frederick] #305394
05/05/09 01:52 PM
05/05/09 01:52 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
I know they're not stealths but I did the same on my edelbrocks for my 496" to put me at 10.6:1. Went from advertised 84cc chambers down to a measured 74cc at -.050
My machinist also opted for machining my intake rather than the intake side of the heads. I think this is so you don't reduce the v/c surface (not that I think it'd be a big deal but w/e). Intakes are cheaper than heads at any rate
The formula for how much to remove from the intake side per .01 off the head is here in the forums, I believe it's like .012 or .013 per .010 off the deck but you should double check... My math is probably wrong
