Re: Holly carb surging
[Re: cudaman1969]
#3053591
06/26/22 05:39 PM
06/26/22 05:39 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
How is your float level ? If your needle and seat were leaking or sticking the float level would be too high . Pull the sight plug and check it. Sometimes a power valve will cause this. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3053634
06/26/22 08:44 PM
06/26/22 08:44 PM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
Checked while running and no fuel leaking down Ventura’s, only does it after complete warm up. I have another carb I’ll stick on to try this week sometime, have to use van tomorrow. One other thing, if I hold pedal down a little more in gear at a stop light it evens out. Maybe trash in idle circuit.?
[Re: 57Fury440]
#3053680
06/26/22 10:54 PM
06/26/22 10:54 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I'm going with year old gas
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#3053710
06/27/22 07:15 AM
06/27/22 07:15 AM
Posts: 10,233 Someplace you aren't
SomeCarGuy
Mine is doing this. Only after hot or heat soaked. Perfect otherwise. Thinking I might’ve gotten a load of winter gas. Picked up some race gas to blend in last week. Vapor pressure of the race stuff is 6 psi. Winter blend can be as high as 14 psi I was told. Yikes!
I want my fair share
[Re: cudaman1969]
#3053760
06/27/22 10:17 AM
06/27/22 10:17 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Almost empty filled it up same, did same after fill up 2 months ago Surging at idle, cruise?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: cudaman1969]
#3053911
06/27/22 06:06 PM
06/27/22 06:06 PM
Posts: 1,210 Rochester, New York
GregY
Rochester, New York
I am just going to toss something out there, because your symptoms sound a little like what mine were.
I had a nearly brand new fuel filter on (mech fuel pump, 3/8 barb metal-housing filter), so I didn't think that was my problem. But for kicks, I took it off and I discovered that all I had left was the outer housing and a metal inner part, all of the paper filter part was gone, and the residue or whatever presumably in my carb. I didn't find any big pieces. I am pretty sure the filter was not like that when I put it on, or I would have heard it rattling.
Anyway, I disassembled the carb, blew out all the passages the best I could with carb cleaner and compressed air, and it seems to be fine now.
Greg
[Re: cudaman1969]
#3053962
06/27/22 09:22 PM
06/27/22 09:22 PM
Posts: 15,527 Omaha Ne
TJP
Omaha Ne
The Original filter that screws into bowl (1987) I’ll check it out. I surges at idle about 600, if I raise a little in gear it kinda evens out. Better today from short drive. Could very well be trash in there have you checked for vacuum leaks or tried adjusting the idle mixture ?
