Holly carb surging #3053513
06/26/22 01:51 PM
06/26/22 01:51 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Not sure why but think it might be a leaking needle seat. Sat for a year and had to tighten up the acc pump and replace manifold gasket. Now this, any other ideas?
Re: Holly carb surging [Re: cudaman1969] #3053591
06/26/22 05:39 PM
06/26/22 05:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
How is your float level ? If your needle and seat were leaking or sticking the float level would be too high . Pull the sight plug and check it. Sometimes a power valve will cause this.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Holly carb surging [Re: fourgearsavoy] #3053634
06/26/22 08:44 PM
06/26/22 08:44 PM
fredericksburg,va
fredericksburg,va
Checked while running and no fuel leaking down Ventura’s, only does it after complete warm up. I have another carb I’ll stick on to try this week sometime, have to use van tomorrow. One other thing, if I hold pedal down a little more in gear at a stop light it evens out. Maybe trash in idle circuit.?
Re: Holly carb surging [Re: cudaman1969] #3053640
06/26/22 09:11 PM
06/26/22 09:11 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
Is it possible it's a gas problem? Maybe the carb is too hot, and the gas is boiling.
Re: Holly carb surging [Re: 57Fury440] #3053680
06/26/22 10:54 PM
06/26/22 10:54 PM
Chicago
PurpleBeeper Offline
Chicago
I'm going with year old gas
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Holly carb surging [Re: PurpleBeeper] #3053710
06/27/22 07:15 AM
06/27/22 07:15 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Mine is doing this. Only after hot or heat soaked. Perfect otherwise. Thinking I might’ve gotten a load of winter gas. Picked up some race gas to blend in last week. Vapor pressure of the race stuff is 6 psi. Winter blend can be as high as 14 psi I was told. Yikes!
I want my fair share
Re: Holly carb surging [Re: SomeCarGuy] #3053726
06/27/22 08:11 AM
06/27/22 08:11 AM
fredericksburg,va
fredericksburg,va
Almost empty filled it up same, did same after fill up 2 months ago
Re: Holly carb surging [Re: cudaman1969] #3053760
06/27/22 10:17 AM
06/27/22 10:17 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Surging at idle, cruise?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Holly carb surging [Re: cudaman1969] #3053911
06/27/22 06:06 PM
06/27/22 06:06 PM
Rochester, New York
GregY Offline
GregY  Offline
Rochester, New York
I am just going to toss something out there, because your symptoms sound a little like what mine were.
I had a nearly brand new fuel filter on (mech fuel pump, 3/8 barb metal-housing filter), so I didn't think that was my problem. But for kicks, I took it off and I discovered that all I had left was the outer housing and a metal inner part, all of the paper filter part was gone, and the residue or whatever presumably in my carb. I didn't find any big pieces. I am pretty sure the filter was not like that when I put it on, or I would have heard it rattling.
Anyway, I disassembled the carb, blew out all the passages the best I could with carb cleaner and compressed air, and it seems to be fine now.
Greg
Re: Holly carb surging [Re: GregY] #3053935
06/27/22 07:37 PM
06/27/22 07:37 PM
fredericksburg,va
fredericksburg,va
The Original filter that screws into bowl (1987) I’ll check it out. I surges at idle about 600, if I raise a little in gear it kinda evens out. Better today from short drive. Could very well be trash in there
Re: Holly carb surging [Re: cudaman1969] #3053962
06/27/22 09:22 PM
06/27/22 09:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
have you checked for vacuum leaks or tried adjusting the idle mixture ?
Re: Holly carb surging [Re: TJP] #3053969
06/27/22 09:37 PM
06/27/22 09:37 PM
fredericksburg,va
fredericksburg,va
I will this weekend when I have more time, busy doing the Dentist office this week (big project)
