need advice from any iron head racers #305353
05/02/09 10:25 AM
05/02/09 10:25 AM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
I am lookin to see what plug you guys run in closed chamber iron 915 heads for racing. I dont think the rj12 will do the trick for what i want. I will spray a 150 shot on this sometimes also but id like to know some plug recomendations for both . Thanks for your help guys!!
www.sikosracing.net Heads up Drag racing
Re: need advice from any iron head racers [Re: moparmattkos] #305354
05/02/09 10:48 AM
05/02/09 10:48 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am using an NGK #8.i can get the stock # to order later.sorry.
edit: thye stock # is 3354 part # R5670-8 for my 346 heads.
Re: need advice from any iron head racers [Re: blownzoom440] #305355
05/02/09 04:37 PM
05/02/09 04:37 PM
Illinois
mopar addict
mopar addict
Illinois
What is your combo? Nos , blower , or N/a??
Re: need advice from any iron head racers [Re: moparmattkos] #305356
05/02/09 04:47 PM
05/02/09 04:47 PM
ELYRIA,OH
ELYRIA,OH
boosted,about 15.5to1cr total,sunoco 110,7AL-2 pro coil,firecore 50 wires.30* timing.
Re: need advice from any iron head racers [Re: blownzoom440] #305357
05/02/09 07:38 PM
05/02/09 07:38 PM
Cumberland, MD
Supersonic Offline
Supersonic  Offline
Cumberland, MD
I run auto lite 75 in mine. it has shaved and ported 915 heads and runs 10.30's. I have 24 runs on this motor without changing any of the plugs yet, they seem to do the job. I know a lot of people hate auto lite's but i've always had good luck with them so i've never changed.
Re: need advice from any iron head racers [Re: moparmattkos] #305358
05/02/09 10:35 PM
05/02/09 10:35 PM
Try a Autolite AR73 or AR72, or a Champion J63Y or J6YC and or Accel 132
Re: need advice from any iron head racers [Re: Cab_Burge] #305359
05/02/09 11:03 PM
05/02/09 11:03 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
I,ve been using Accel 134 for a couple of years now. 906,s 14 to 1 alcohol. Never had any issues.
Re: need advice from any iron head racers [Re: moparmattkos] #305360
05/03/09 08:21 AM
05/03/09 08:21 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
When the motor had 915s on it we ran AR73 gaped at .035.I like the cut back electrode on the AR plugs I think there is less chance of detonation with that style plug.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: need advice from any iron head racers [Re: wildcargo] #305361
05/03/09 11:31 PM
05/03/09 11:31 PM
Illinois
mopar addict
mopar addict
Illinois
I went to the local parts store and they crossed over the ar73 to autolite 85's will these work ok?
Re: need advice from any iron head racers [Re: moparmattkos] #305362
05/03/09 11:44 PM
05/03/09 11:44 PM
Absolutely not, a 85 is a resistor plug that has the same heat range as the non resistor Autolite # 75 A 83 is the same heat range as a 73
Re: need advice from any iron head racers [Re: moparmattkos] #305363
05/04/09 12:17 AM
05/04/09 12:17 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Champion H8C. Should be easy to get. Oreilly Auto Parts stocks them. That is what I run in Iron head big blocks. Got them in the Lebaron right now with 915 heads. Dan
Re: need advice from any iron head racers [Re: qwkmopardan] #305364
05/05/09 12:25 AM
05/05/09 12:25 AM
Illinois
mopar addict
mopar addict
Illinois
I went to all the local parts stores no one keeps this plug either. They told me that c this plug crosses over to a autolite 216???? Dan is your motor n/a or a power adder? will these work and what about a little 175 shot on it???
Re: need advice from any iron head racers [Re: moparmattkos] #305365
05/05/09 09:23 AM
05/05/09 09:23 AM
Illinois
mopar addict
mopar addict
Illinois
Re: need advice from any iron head racers [Re: moparmattkos] #305366
05/05/09 09:36 AM
05/05/09 09:36 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
We run the NGK 5670-9 on our
Alky Injected 14-1, Iron headed 440, Use PN 3913 to order through O'Reilly's.
Taking over the World one win light at a time.
Re: need advice from any iron head racers [Re: afxcoronet] #305367
08/15/09 01:00 PM
08/15/09 01:00 PM
Illinois
mopar addict
mopar addict
Illinois
More info The motor is a 451 stroker about 11 to 1 with a 590 cam 915 heads and a 4500 converter in a 3000lb car with a very occasinal 150 shot of nos.
Re: need advice from any iron head racers [Re: moparmattkos] #305368
08/15/09 01:21 PM
08/15/09 01:21 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We ran Auto lite 74s in both the 915 and the Max wedge heads. We did use a 150 shot on my buddies 440 with 915s and using the 74s.. I think that they changed the number on it but they can cross it for ya.. oh his is a 496... 12.5 comp soild mop cam 590 lift single carb 1050 dom. Hope this helps ya.
Re: need advice from any iron head racers [Re: 70dusterjohn] #305369
08/16/09 03:39 PM
08/16/09 03:39 PM
Illinois
mopar addict
mopar addict
Illinois
Are those ar74's or just the 74's??
Re: need advice from any iron head racers [Re: moparmattkos] #305370
08/16/09 03:59 PM
08/16/09 03:59 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Used to run autolite 75 or 74 in a 915 headed 511 ran 9.80's in a 3200 lb car - they were cheap and worked - I did try the 85 and 84's never really noticed any difference using a MSD 6Al - the resistence in the plug is negligable.
Re: need advice from any iron head racers [Re: blownzoom440] #305371
08/17/09 12:02 AM
08/17/09 12:02 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
These are the plugs you need . Or the -7s,,, If you can wait since may, you can wait to order them?
