Re: Mickey Thompson vs. Nitto street drag radials
[Re: Valiant_Showoff]
#3053086
06/24/22 05:54 PM
06/24/22 05:54 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
nitto's did not hook at all on my Charger, they drove real nice, MT's or M&H hook great on my junker
#3053124
06/24/22 07:45 PM
06/24/22 07:45 PM
Posts: 1,131 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I haven't been able to find NT555RII in the size I wanted to try out and bought M/T ET Street S/S instead.
From what I've read and heard talking to people who run the NT555RII at the track, the ET Street S/S works better. The Nitto drives better on the street and should last longer, but you're still talking a soft compound tire with a limited lifespan. A couple of people mentioned the NT555RII losing its grip after being heat-cycled from burnouts even though there is still a good amount of tread left.
Wish I had more firsthand knowledge, though.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3053732
06/27/22 08:33 AM
06/27/22 08:33 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
The Nittos are better on the street (more tread, harder compound), but that comes at the expense of dragstrip performance.
[Re: an8sec70cuda]
#3053752
06/27/22 09:56 AM
06/27/22 09:56 AM
Posts: 4,680 Wichita
GY3
Wichita
The Nittos are better on the street (more tread, harder compound), but that comes at the expense of dragstrip performance. Totally agree with this. We have always used ET Street Pro's but a friend tried the Nitto's. On a low 11 second car he just could not make it hook consistently at the track. Switched to the Pro's and no issues.
