Metering block question
#3052839
06/23/22 10:20 PM
06/23/22 10:20 PM
Posts: 554 Kentucky
clovis
Kentucky
Was doing some carb testing and was going to use some of the 2 emulsion hole Holley blocks I have. On one of the blocks it has a deeper plug for the main well and when it was removed for cleaning a standard plug was installed which sits up high. With the plug high in the well like it is, will it create any specials issues or problems?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Metering block question
[Re: clovis]
#3052926
06/24/22 11:09 AM
06/24/22 11:09 AM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
The idea is the lower plug location speeds up the main well response due to the reduced volume. Some blocks have the plugs lowered, but certainly not all. And I suspect it would be pretty hard to tell the difference, regardless.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3053067
06/24/22 04:45 PM
06/24/22 04:45 PM
Posts: 554 Kentucky
clovis
Kentucky
The lower main well cap along with the two emulsion holes per side are two of the main things I look for when buying blocks.
Thanks for help, that makes perfect sense.
Its kinda funny you responded as the couple of carbs I am messing with are the older Demon RS stuff, which I have gleaned a tremendous amount of information from your old posts on Speed-Talk, so thanks for that help also.
[Re: clovis]
#3053127
06/24/22 07:50 PM
06/24/22 07:50 PM
Brad_Haak
Loudoun County, VA
Oh, cool... "With great power comes great responsibility." - Spider-Brad
