Re: Resistance specs on coolant temp senders? [Re: moparx] #3052786
06/23/22 06:56 PM
06/23/22 06:56 PM
Guitar Jones Offline OP
Originally Posted by moparx
out of curiosity, is the bulb portion of the sender that goes into the coolant flow shiny brass color, or is it discolored to a greenish tint ?
beer
Old one, the 244 unit is discolored, the 196 unit is brand new and shiny.
Re: Resistance specs on coolant temp senders? [Re: NITROUSN] #3052805
06/23/22 08:16 PM
06/23/22 08:16 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by NITROUSN
Originally Posted by 6PakBee
The C-3826 may be old but it was used for decades as long as the thermal gauges were in use. Based on my 78-81 truck parts book from Mymopar, as late as '78 the IVR was PN 3592899 which superseded PN 2258413 which is the IVR for the thermal gauges that C-3826 was used to test since the early '60's. Bottom line, I think the C-3826 tool is still the tool to use on your '74 and the 244 ohm sender you have is not the stock sender for a '74 Mopar. The values from the '93 FSM are not applicable as Mopar had stopped using thermal gauges by then.
He said he is running the 93 cluster and wiring. Magnums had two temperature sensors one for the gauge and one for the computer.
Ah Ha!! I missed that. Well, if he is running the '93 instrument cluster and wiring, I can see where there just may be a problem. Without looking at the '93 circuitry my first thought would be that you'd have to run all '93 sensors in the '74. But that's just a guess.
Re: Resistance specs on coolant temp senders? [Re: Guitar Jones] #3052808
06/23/22 08:17 PM
06/23/22 08:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks like the TS271 Would be what you need. Time to move the fuel line.
Re: Resistance specs on coolant temp senders? [Re: NITROUSN] #3052814
06/23/22 08:45 PM
06/23/22 08:45 PM
Looks like what I will have to do. I have one on order should be here Saturday if the road is passable.
Re: Resistance specs on coolant temp senders? [Re: 6PakBee] #3052818
06/23/22 09:03 PM
06/23/22 09:03 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I missed that too, lol. Need new glasses or something
Re: Resistance specs on coolant temp senders? [Re: Guitar Jones] #3052913
06/24/22 10:48 AM
06/24/22 10:48 AM
moparx Offline
moparx  Offline
beer
shine up the 244 ohm unit and see what it reads then.
wondering how much, if any, the discoloration affects the reading.
beer
Re: Resistance specs on coolant temp senders? [Re: moparx] #3053051
06/24/22 03:55 PM
06/24/22 03:55 PM
I got the 93 spec sender today, checked it and it read 2K ohms, hmm, ok. Installed it, filled with coolant and it looks to be good. Gauge came up pretty quick and read in the normal zone after it got to operating temp. So I'm done futzing with it, I've done more electrical getting everything working on this truck than ever wanted to do in my life laugh2 If I would have stuck to the original plan of installing the complete fuel injected engine and fuel tank I would probably be done with it already.
Re: Resistance specs on coolant temp senders? [Re: Guitar Jones] #3053533
06/26/22 03:14 PM
06/26/22 03:14 PM
moparx Offline
moparx  Offline
never stay with a plan ! that is the only smart thing to do, and i'm not overly blessed with smarts.............. whistling biggrin
your mileage will vary.
beer
