Electrical Puzzle #3052607
06/23/22 08:12 AM
06/23/22 08:12 AM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
Vehicle- 1969 Charger
Problem- Short somewhere under dash?
How I got here- Issue began with left rear turn signal and brake lights inoperative. Car had multiple issues but where I'm at now is that when I apply the left signal and check with a test light at the kick panel connector (and I have the connector disconnected, I am testing on the side going to the underpass harness), test light flashes strong on both tight and left signals at the correct terminals. Running lights to rear light test lamp at correct terminal when headlight switch is on.
However, when the left signal is activated, the test light will also flash weakly when the probe is touched against the terminal coming from the fuel gauge.
Using a multimeter, I get a weak but audible tone when I check gor voninuity as gallows. One lead of multi meter to fuel gauge terminal and one lead to left rear turn signal AND with one lead going yo terminal for running lights.
I'm stumped. Is this a bad ground causing a backfeed or a short in the dash somewhere or am I being punished by dome satanic vilt?
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Electrical Puzzle [Re: Ghoste] #3052610
06/23/22 08:39 AM
06/23/22 08:39 AM
Andrewh Offline
Andrewh  Offline
what does the fuel gauge have to do with rear lights?
fuel gauge feed pulses because it is 5 volts but from a pulsing voltage reg at the dash, unless you changed it to solid state.
Re: Electrical Puzzle [Re: Andrewh] #3052614
06/23/22 08:50 AM
06/23/22 08:50 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's called back feed.
As the flasher for the lights pulses it loads and unloads the entire electrical system and you are seeing that back fed into where ever you are testing.
Bet the engine is off while you are doing this.
Re: Electrical Puzzle [Re: Sniper] #3052626
06/23/22 09:23 AM
06/23/22 09:23 AM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
Yes, to each So basically what you are telling me is that what I am seeing is normal?
Re: Electrical Puzzle [Re: Ghoste] #3052693
06/23/22 12:11 PM
06/23/22 12:11 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Are you using LED brake/tail lights? I had a similar problem when I had 4 LED tail and brake lights (1968 Charger) the lighting for a tachometer I have installed on my column would light up when I had the breaks on. I chalked it up to some kind of backfeed problem shruggy Because of problems with the flasher, I've had to switch out one of the LEDs on each side, and I haven't noticed the tach lighting up anymore
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Electrical Puzzle [Re: Ghoste] #3052710
06/23/22 01:29 PM
06/23/22 01:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
Did it do t new, NOT.
It is not normal and you probably are having a grounding issue, clean the metal up where the light socket plugs in and see if that fixes it.
Electricity is like all liquids, they take the easiest path back to the source, the battery work wrench up twocents
Re: Electrical Puzzle [Re: Cab_Burge] #3052725
06/23/22 02:29 PM
06/23/22 02:29 PM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
No LED on mine. Incandescent bulbs. Correct type for each socket. Harnesses are not hacked into. No high amp alternator. It's largely as Dodge made it.
Re: Electrical Puzzle [Re: Andrewh] #3052730
06/23/22 02:45 PM
06/23/22 02:45 PM
Canada
Ghoste Offline OP
Ghoste  Offline OP
Canada
That's what puzzles me. Fuel gauge of course has nothing to do with turn dignals. That's why it seems strange to me that a test light applied to that terminal flashes in unison with the turn signal flasher and only with activation of the left signal.
Re: Electrical Puzzle [Re: Ghoste] #3052734
06/23/22 03:00 PM
06/23/22 03:00 PM
PA
70Duster Offline
70Duster  Offline
PA
Try this......It's possibly a bad ground connection so run a wire from the metal casing of the brake light / turn signal housing inside the trunk to a good ground such as one of the bolts that fasten the trunk lid latch. This worked for me on a '70 Road runner with similar issues.
Re: Electrical Puzzle [Re: 70Duster] #3052750
06/23/22 03:36 PM
06/23/22 03:36 PM
moparx Offline
moparx  Offline
it sure sounds like a ground issue to me.
also, look over the front turn signal light/housing assembly for a good ground as well.
you just never know about grounds.
beer
Re: Electrical Puzzle [Re: moparx] #3052794
06/23/22 07:39 PM
06/23/22 07:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Tail light, brake lights, and turn signals, and front turn signal lights on a 69 Charger are grounded through the taillight (or front turn light) mounting screws. Paint, rust, corrosion, or even dirt between the screws and the sheet metal the screws are in will cause all kinds of strange things to happen. The power for those lights is back tracking through the lighting system looking for a place to ground. That often comes through dash, or instrument light grounds.
The best "fix" is to solder a ground wire on the bulb holder and attach it to its own ground, or you can buy replacement bulb holders with a ground tab attached you connect a ground wire to. You will probably need to do this to each bulb in the tail & front turn lights. The headlights are usually grounded by their own dedicated ground wires per side of the car.
Re: Electrical Puzzle [Re: poorboy] #3052795
06/23/22 07:45 PM
06/23/22 07:45 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sounds like it's a non-issue to me. He's only seeing something with a test light.
Re: Electrical Puzzle [Re: Sniper] #3052820
06/23/22 09:09 PM
06/23/22 09:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If that's the case then rolleyes
Re: Electrical Puzzle [Re: Ghoste] #3052845
06/23/22 11:07 PM
06/23/22 11:07 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
The fuel & rear light wires are in same wire bundle going to rear of car.
Something frayed along the way back there maybe?
Re: Electrical Puzzle [Re: TJP] #3052880
06/24/22 07:36 AM
06/24/22 07:36 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If it's an LED test light, and I am guessing it is, it's doesn't take much to make them flicker.
