anti roll bar or sway bar #3052645
06/23/22 10:08 AM
06/23/22 10:08 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
How much pressure is on a anti roll or sway bar on a 4 link rear end set up. Has anyone broke brackets or bolt or arms anything like that ?? Thanks
Re: anti roll bar or sway bar [Re: dragon] #3052692
06/23/22 11:54 AM
06/23/22 11:54 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I don't know how much pressure they have. I don't know anyone that has broke anything. I'm not smart enough to know how they work, but they work amazingly well. The biggest ones look the sexiest, but they're expensive.
2011 Drag Pak Challenger
Re: anti roll bar or sway bar [Re: rickseeman] #3052703
06/23/22 12:41 PM
06/23/22 12:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have one on my Challenger. There is not enough pressure to break brackets or anything during launches in most cases.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: anti roll bar or sway bar [Re: 6PKRTSE] #3052707
06/23/22 01:16 PM
06/23/22 01:16 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Re: anti roll bar or sway bar [Re: dragon] #3052716
06/23/22 01:56 PM
06/23/22 01:56 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I broke the arms off the end of the tube on my old demon but, that happened on the street. No where for rear end to go when driving over irregular surfaces. Never broke them at the strip.
Re: anti roll bar or sway bar [Re: rickraw] #3052738
06/23/22 03:14 PM
06/23/22 03:14 PM
AndyF Offline
AndyF  Offline
Yeah I can see busting stuff on the street, especially with a ladder bar car. Railroad tracks or steep driveways can bust stuff. There shouldn't be more than a few hundred pounds of force on the anti-sway bar ends at the track. The linkage doesn't have to be very big to handle a couple hundred pounds. 1/4-20 bolts will handle that.
Re: anti roll bar or sway bar [Re: 6PKRTSE] #3052756
06/23/22 03:58 PM
06/23/22 03:58 PM
moparx Offline
moparx  Offline
should one slightly groove the bushings to ensure the grease goes 360 degrees around the bushing ?
beer
Re: anti roll bar or sway bar [Re: moparx] #3052759
06/23/22 04:20 PM
06/23/22 04:20 PM
AndyF Offline
AndyF  Offline
beer
It isn't a high load situation or a high wear application. The bar is barely going to move when you go down the track.
Re: anti roll bar or sway bar [Re: AndyF] #3052769
06/23/22 05:35 PM
06/23/22 05:35 PM
gregsdart Offline
gregsdart  Offline
I made this bar out of mild steel 13/8 x . 125 wall. Twisted it in the first hit. 11.17 starting line ratio, 860 hp,, 4.56 gears and 33x15x15 slicks. I went to 1 3/4 x .134 wall tube, no problem. It is all about leverage and torque. Combine too much of both, and anything can bend or break.
Re: anti roll bar or sway bar [Re: gregsdart] #3052872
06/24/22 06:44 AM
06/24/22 06:44 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Just out of interest, Super Stock guys aren't allowed to run aftermarket ARB's so usually run the H/D stock anti sway stuff on the rear. They don't have any issues, even when using them in conjunction with Caltrac bars, which induce a lot of rise and axle rotation. twocents
Re: anti roll bar or sway bar [Re: dragon] #3053132
06/24/22 07:56 PM
06/24/22 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I broke the bar on my anti roll due to it being a bit small on dia... I replaced it with a larger bar
and its been perfect since.... like Greg said.. add enough torque and things can break.. you have
very little load sitting at the line until you hit the pedal
wave
Re: anti roll bar or sway bar [Re: MR_P_BODY] #3053212
06/25/22 08:27 AM
06/25/22 08:27 AM
PA
moparacer Offline
moparacer  Offline
PA
Shouldn't be any preload or pressure on an anti roll bar in a 4 link setup if it is right. If anything is breaking might be something else wrong.
Preload with the 4 link and set the anti roll to be zero preload at race weight with driver in car. twocents
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: anti roll bar or sway bar [Re: moparacer] #3053380
06/25/22 10:15 PM
06/25/22 10:15 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
This is close to how mine is set up. With zero preload, I wound my right-hand side down two turns, which made a huge difference to how flat the car now launches.
Re: anti roll bar or sway bar [Re: moparacer] #3053527
06/26/22 02:40 PM
06/26/22 02:40 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
[quote=moparacer]Shouldn't be any preload or pressure on an anti roll bar in a 4 link setup if it is right. If anything is breaking might be something else wrong.
/quote]
Yes, this is how we sent mine up with me in the car, at race weight, with both bottles in the trunk and all my gear in my lap as my buddies adjust the heims until all bolts slip in and out of the holes so everything is with no preload. Car leaves hard, straight and level every time.
Re: anti roll bar or sway bar [Re: 6PKRTSE] #3053743
06/27/22 09:25 AM
06/27/22 09:25 AM
gregsdart Offline
gregsdart  Offline
This picture shows my dart before anti roll install, 30 inch ladderbars. At one point the settings were so far out of whack it would seperate on the left rear violently, run out of shock travel and pull the left slick clean up off the track! It happened when the front mount was close to the neutral line. It says a lot about how flexible ladderbars can be, and how much an anti roll is needed in SOME situations.
