Re: anti roll bar or sway bar
[Re: dragon]
#3052692
06/23/22 11:54 AM
06/23/22 11:54 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I don't know how much pressure they have. I don't know anyone that has broke anything. I'm not smart enough to know how they work, but they work amazingly well. The biggest ones look the sexiest, but they're expensive.
2011 Drag Pak Challenger
[Re: rickseeman]
#3052703
06/23/22 12:41 PM
06/23/22 12:41 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I have one on my Challenger. There is not enough pressure to break brackets or anything during launches in most cases.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#3052769
06/23/22 05:35 PM
06/23/22 05:35 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I made this bar out of mild steel 13/8 x . 125 wall. Twisted it in the first hit. 11.17 starting line ratio, 860 hp,, 4.56 gears and 33x15x15 slicks. I went to 1 3/4 x .134 wall tube, no problem. It is all about leverage and torque. Combine too much of both, and anything can bend or break.
[Re: gregsdart]
#3052872
06/24/22 06:44 AM
06/24/22 06:44 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Just out of interest, Super Stock guys aren't allowed to run aftermarket ARB's so usually run the H/D stock anti sway stuff on the rear. They don't have any issues, even when using them in conjunction with Caltrac bars, which induce a lot of rise and axle rotation.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dragon]
#3053132
06/24/22 07:56 PM
06/24/22 07:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I broke the bar on my anti roll due to it being a bit small on dia... I replaced it with a larger bar and its been perfect since.... like Greg said.. add enough torque and things can break.. you have very little load sitting at the line until you hit the pedal
[Re: MR_P_BODY]
#3053212
06/25/22 08:27 AM
06/25/22 08:27 AM
Posts: 2,527 PA
moparacer
PA
Shouldn't be any preload or pressure on an anti roll bar in a 4 link setup if it is right. If anything is breaking might be something else wrong. Preload with the 4 link and set the anti roll to be zero preload at race weight with driver in car.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3053380
06/25/22 10:15 PM
06/25/22 10:15 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Shouldn't be any preload or pressure on an anti roll bar in a 4 link setup if it is right. If anything is breaking might be something else wrong. Preload with the 4 link and set the anti roll to be zero preload at race weight with driver in car. This is close to how mine is set up. With zero preload, I wound my right-hand side down two turns, which made a huge difference to how flat the car now launches.
[Re: moparacer]
#3053527
06/26/22 02:40 PM
06/26/22 02:40 PM
6PKRTSE
Motor City
[quote=moparacer]Shouldn't be any preload or pressure on an anti roll bar in a 4 link setup if it is right. If anything is breaking might be something else wrong. Preload with the 4 link and set the anti roll to be zero preload at race weight with driver in car. [ /quote] Yes, this is how we sent mine up with me in the car, at race weight, with both bottles in the trunk and all my gear in my lap as my buddies adjust the heims until all bolts slip in and out of the holes so everything is with no preload. Car leaves hard, straight and level every time.
[Re: 6PKRTSE]
#3053743
06/27/22 09:25 AM
06/27/22 09:25 AM
gregsdart
This picture shows my dart before anti roll install, 30 inch ladderbars. At one point the settings were so far out of whack it would seperate on the left rear violently, run out of shock travel and pull the left slick clean up off the track! It happened when the front mount was close to the neutral line. It says a lot about how flexible ladderbars can be, and how much an anti roll is needed in SOME situations.
