Re: Mallory dual point vacuum advance distributor
[Re: hemienvy]
#3051920
06/20/22 09:22 AM
06/20/22 09:22 AM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Mallory has made a number of different distributors over the decades. My is to find a part number -- if possible -- and contact Mallory directly. However, given they've been bought up by MSD IIRC, I don't know what sort of tech support you'll get for their older products. Maybe posting pics on here may help to identify what the right components are, too.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3051969
06/20/22 12:17 PM
06/20/22 12:17 PM
Posts: 1,853 South Bend
John Brown
South Bend
I use old Accel catalogues to find what points and condensers were used in Mallory distributors. You will need the model number off of the distributor.
[Re: hemienvy]
#3052111
06/21/22 12:43 AM
06/21/22 12:43 AM
John Brown
South Bend
My Accel catalogue is number 3420, dated 1977. Mallory distributors listed are series YC, ZC, YD, YL, and ZD. This catalogue doesn't list any distributors with numbers such as yours
YC and ZC use Accel points number 110400 or 110401 (stiff spring) and condenser number 100401. This condenser is a large style that is mounted on the outside of the distributor body. One piece distributor cap is number 120401. Rotor is 130401. There is no crossover to any OEM vehicle listing that uses those points, condenser, rotor or distributor cap. An external mounted condenser may help identify which style of distributor you have, or maybe not.
YD, YL and ZD distributors use Accel points number 110403 or 110402 (stiff spring) and condenser number 100402. Distributor cap is Accel number 120403 which replaces a two piece Mallory cap. Rotor is number 130402. These cap and rotor numbers can only be used in a matched pair, and may not be mixed and matched with marine flat caps and rotors. There is no OEM that uses these numbers, although there may be some marine applications that do.
Hope this information helps you out.
EDIT: A quick internet search indicates a 27 series Mallory distributor relates to earlier YL series distributors. Take that for what it's worth.
[Re: John Brown]
#3052133
06/21/22 08:43 AM
06/21/22 08:43 AM
Posts: 912 Washington
hemienvy
Washington
John, That's great, Thank you very much. I took some pics. I wonder how unique the vacuum canister is, maybe it's a common GM or something.
I wonder if the "A" in the part number means adjustable vacuum ?
[Re: hemienvy]
#3052141
06/21/22 09:25 AM
06/21/22 09:25 AM
John Brown
South Bend
No idea on the vacuum advance. It doesn't look like any GM I've seen before.
