Trimming a four speed input shaft.
#3051860
06/19/22 10:54 PM
06/19/22 10:54 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I'd like to talk with someone that has experience in trimming the end a four speed input shaft.
Does anyone have experience in doing this or can you recommend someone?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: Trimming a four speed input shaft.
[Re: 69CoronetRT]
#3052007
06/20/22 02:25 PM
06/20/22 02:25 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Why do you want to cut it off?
[Re: Cab_Burge]
#3052021
06/20/22 03:01 PM
06/20/22 03:01 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Why do you want to cut it off? Because his crank is from an auto trans car that is not drilled out... Just my $0.02...
[Re: Sinitro]
#3052024
06/20/22 03:11 PM
06/20/22 03:11 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
That’s the deal. Easier to cut an eight or less off the shaft and go to the roller pilot.
I want my fair share
