Throttle body EFI with E85 fuel
#3051725
06/19/22 02:03 PM
06/19/22 02:03 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Does anybody here run E85 through their throttle body EFI system? I'm building a 408 Magnum small block for a friend and he is asking me about running EFI and what brand he should buy and which one is compatible with E85. Thank you Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Throttle body EFI with E85 fuel
[Re: AndyF]
#3051829
06/19/22 09:35 PM
06/19/22 09:35 PM
fourgearsavoy
Rittman Ohio
Thanks Andy I can't find too much information about throttle bodies with the larger injectors already installed for E85. One less thing for me to do when I set this thing up and get the engine and fuel system installed. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: fourgearsavoy]
#3051869
06/19/22 11:33 PM
06/19/22 11:33 PM
Posts: 31,082 Oregon
AndyF
Thanks Andy I can't find too much information about throttle bodies with the larger injectors already installed for E85. One less thing for me to do when I set this thing up and get the engine and fuel system installed. Gus All depends on how much power the engine is going to make. Holley doesn't recommend E85 with the Sniper products, not sure about the Terminator. Some racers use E85 with the Holley Sniper but they flush the system after each race.
[Re: Dragula]
#3051962
06/20/22 11:56 AM
06/20/22 11:56 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
He would probably be better off with some kind of port injection setup where he can use an E85 safe injector. It costs more in the long run but would probably be cheaper than whatever may fail that was not designed for E85 inside of a sniper.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3052066
06/20/22 06:14 PM
06/20/22 06:14 PM
fourgearsavoy
Rittman Ohio
It's just going to be a regular old street car with maybe 450 HP cam is going to be low end torque cam. He just wants a turn key street car with reliable smooth performance. I think he should just go with a dual plane intake and a Thunder series AVS carb but he wanted to check into the whole EFI thing. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
