TA Power Steering Pump
#3051529
06/18/22 03:38 PM
06/18/22 03:38 PM
Posts: 2,377 White Plains, NY
VCODE
White Plains, NY
Ok, so how do I tell if the Federal Power Steering pump I have is the correct pump for a TA with Quick Ratio Steering. I have a Federal pump but not sure about the correct pressure to work with a TA steering Box The Part # in the book shows a 3004799. What casting # number on the pump to tell if it's for a TA. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: TA Power Steering Pump
[Re: fastmark]
#3051641
06/19/22 06:51 AM
06/19/22 06:51 AM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
Ok. Someone posted an answer on for b bodies only to your question. He included pressures for each application. I was remembering that the c body and TA pump shared the same pressure and part ͏N͏o. I don’t have my parts book here at home. Do they have different valves or just a valve that is adjusted for the pressure? In other words, can you take the valve out and see the difference?
[Re: fastmark]
#3051652
06/19/22 07:36 AM
06/19/22 07:36 AM
Posts: 1,322 VA
dragon slayer
VA
I would have to find my hand written notes but I would think the best way to figure it out would be setting up with a pressure gage and testing pumps. My very old posting talked to the various # and stamps on the pumps, but no one could provide any decoding.
The Valve is custom fit to the pump body. Supposedly your not suppose to swap them by tech documents. When I was doing this I had a pile of pumps to sort through. Here is pump data from one that I rebuilt and retained as a spare for my car.
8D8 8 B 2591C 1.387” Short Valve, .974” spring, and 4 .060” Shims
There were differences in valve length, spring and # of shims. A rebuilder would be able to modifiy to the pressure needs of the car. Could anyone decifier 8D8 8 B? Is 2591C a date code and shift, probably. Could some of the pumps I look at have additional stamping from a rebuilder? Possibly.
I know the charger hemi guys have assembly prints for the cars, does some one have assembly prints for the TA/AAR. If so, does the sheet for PS show any notes that could help with paint mark, stamp code?
[Re: dragon slayer]
#3051661
06/19/22 08:52 AM
06/19/22 08:52 AM
VCODE
White Plains, NY
Thanks for the great info. Now to see if I can pressure test my pump to see what pressure it is putting out. Bob
