Page 4 of 5 1 2 3 4 5
Re: F M J Body Cars . . . [Re: Magnumguy] #3051077
06/16/22 07:07 PM
06/16/22 07:07 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Originally Posted by Magnumguy
Originally Posted by 440newport
I ran it with an a 727 for years but finally got the 4 speed installed in 2017 or so.
What trans did you use?
It's a late 60's A body trans with a 2.66 first gear. As Sniper said it's basically a bolt in deal. In my case the hole for the clutch rod was already in the firewall, a earlier rod boot from Brewer's fit fine. The floor hump and pedals I got from a Volare. I couldn't use the pedal assembly as is because the bracket didn't fit the steering column area, as F and J bodies have a different shaped dash. So I just used the pedals themselves on the J body bracket and drilled the hole for the longer clutch pedal support rod to come through.
Re: F M J Body Cars . . . [Re: poorboy] #3051256
06/17/22 12:20 PM
06/17/22 12:20 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Originally Posted by poorboy
The M bodies came along about 4 years after the first F body showed up. Chrysler had more money, and 4 years to correct a few issues. Harder rubber mounts, thicker upper control arm brackets with some support, and bigger sway bars. Even the later F bodies and the J bodies in between the early F & the M were better handling cars then the early F bodies were.
The F body came out in 76, the M body came out in 77. Mechanically the same, cosmetically different.
You might be thinking of the J body which came out in 80, again, mechanically the same, cosmetically different.
As the mechanical improved they were implemented across the platforms. F/J/M.
F body, the original K car.
Re: F M J Body Cars . . . [Re: Sniper] #3052162
06/21/22 11:16 AM
06/21/22 11:16 AM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Has anyone that put a Big block into an F body, changed out the power brake booster ? Looks like on car I have, the booster might have come from A body in mid 70's. It is only about 9-9.5" diameter - which allows for left side valve cover removal . . . just curious if anyone else has done same . . . long shot, I know.
Thanks,
Mark
Re: F M J Body Cars . . . [Re: a12rag] #3052164
06/21/22 11:29 AM
06/21/22 11:29 AM
5thAve Offline
5thAve  Offline
Never done the big block swap but I thought from years ago people were using a K car booster?
Re: F M J Body Cars . . . [Re: 5thAve] #3052276
06/21/22 09:55 PM
06/21/22 09:55 PM
a12rag Offline OP
a12rag  Offline OP
K car would use the 2 bolt master cylinder and my car has 4 bolt master cylinder. Pretty sure it came from mid 70s A body
Re: F M J Body Cars . . . [Re: a12rag] #3052411
06/22/22 01:08 PM
06/22/22 01:08 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Need MarkZ to chime in
Facts are stubborn things.
Re: F M J Body Cars . . . [Re: larrymopar360] #3052551
06/22/22 09:30 PM
06/22/22 09:30 PM
5thAve Offline
5thAve  Offline
Swap the master cylinder over at the same time. 79 was the first year for the aluminum 2 bolt one in all the RWD cars and full size trucks.
Im guessing there's probably an older power brake booster that fits but the K car one would be easier to find?
Re: F M J Body Cars . . . [Re: 5thAve] #3052685
06/23/22 11:39 AM
06/23/22 11:39 AM
a12rag Offline OP
a12rag  Offline OP
No issues with the booster, just changed the master cylinder . . . however went with what should be on 79, which has larger bore than master that would be on the booster (99% sure it is from mid 70's A body), so going to change master again . . .
Re: F M J Body Cars . . . [Re: a12rag] #3052732
06/23/22 02:52 PM
06/23/22 02:52 PM
moparx Offline
moparx  Offline
how big in diameter is a K-car booster, and is it a single or dual diaphragm unit ?
beer
Re: F M J Body Cars . . . [Re: moparx] #3052793
06/23/22 07:36 PM
06/23/22 07:36 PM
nowhere
nowhere
beer
Depends on whether it's a stick or auto car. Rockauto has pics and dimensions
https://www.rockauto.com/en/catalog/dodge,1985,aries,2.2l+135cid+l4,1069163,brake+&+wheel+hub,power+brake+booster,1884
Re: F M J Body Cars . . . [Re: Sniper] #3053890
06/27/22 05:09 PM
06/27/22 05:09 PM
a12rag Offline OP
a12rag  Offline OP
I think the hardest thing when getting something that SOMEONE else built 30 years ago, is trying to figure out what they did back then !! . . .
Re: F M J Body Cars . . . [Re: a12rag] #3054129
06/28/22 03:50 PM
06/28/22 03:50 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've been driving the M-body coupes for about 30 years now. That has been my only Mopar "muscle car"!
Here are a couple of pics of what I currently enjoy, while the '81 awaits a proper start of the project.
Re: F M J Body Cars . . . [Re: Diplomat360] #3054349
06/29/22 12:41 PM
06/29/22 12:41 PM
a12rag Offline OP
a12rag  Offline OP
Awesome !! . . . I do miss my '80 Caravelle . . . 2door like your Dippy . . . but just stock 318, ac, pwr wdw, . . . just all round nice driving car . . .
1980 Caravelle leftside.png1980 Caravelle interior.png1980 Caravelle rightrear.png
Re: F M J Body Cars . . . [Re: a12rag] #3054429
06/29/22 03:53 PM
06/29/22 03:53 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
My first very own Mopar was a '80 Plymouth Caravelle...before that it was a '78 Caravelle that my father owned...and in hindsight was crazy enough to let me "tinker" with it...on went the 4 bbl intake, Carter TQ carb, station wagon gears (2.94 vs 2.45 I think?) along with a small head deck shaving pass at his friends machine shop, and lo' and behold, we almost had a stout machine, or as he put it at that time: "too fast, I stepped on the gas and tires started to spin, smoke was coming out"...LOL!
Ahh...good times, I was in highschool at that time...ahh, to be that young and carefree again...
Re: F M J Body Cars . . . [Re: Diplomat360] #3054466
06/29/22 05:30 PM
06/29/22 05:30 PM
a12rag Offline OP
a12rag  Offline OP
LOL . . . I love the factory Mirada Aluminum wheels ! . . .
Re: F M J Body Cars . . . [Re: a12rag] #3078074
09/17/22 12:15 PM
09/17/22 12:15 PM
Endicott, NY
bnichols Offline
bnichols  Offline
Endicott, NY
My current 79 roadrunner 24k miles not that it matters last owned by Galen Govier
2020 Gladiator
1970 Dodge Dart GT
Re: F M J Body Cars . . . [Re: a12rag] #3078075
09/17/22 12:17 PM
09/17/22 12:17 PM
Endicott, NY
bnichols Offline
bnichols  Offline
Endicott, NY
One I just sold
2020 Gladiator
1970 Dodge Dart GT
Re: F M J Body Cars . . . [Re: a12rag] #3078101
09/17/22 01:53 PM
09/17/22 01:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I just stumbled onto a clean 79 aspen wagon while looking for a set of gears for my dakota, it is just way too nice to part out. It is rot free and only has a little surface rust no bondo or metal replacement needed even the interior is pretty nice. Thinking about a maaco paint job and selling it.
Re: F M J Body Cars . . . [Re: HotRodDave] #3078121
09/17/22 03:01 PM
09/17/22 03:01 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Diplomat360's car is legendary to us M body crowd. A12rag that's a beauty and you are right, M's are very nice riding and decent handling to boot. My '89 AHB is an absolute pleasure to drive and I don't car what the E and B body fanatics say. It's a RWD, solid axle, leaf spring/torsion bar suspension V8 car so it's a real Mopar! Bnichols those are beauties you have too!
Re: F M J Body Cars . . . [Re: larrymopar360] #3078220
09/17/22 09:30 PM
09/17/22 09:30 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Galen Govier?
