Re: The Superbird that went swimming..........
[Re: A12]
#3051040
06/16/22 05:01 PM
06/16/22 05:01 PM
Posts: 5,924 ohio
ruderunner
ohio
So the question remains, where is it now?
I'm aware of a couple older wrecking yards on rt 20 , might be worth a drive across the state to check them out.
Angry white pureblood male
[Re: ruderunner]
#3051046
06/16/22 05:16 PM
06/16/22 05:16 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
I'm aware of a couple older wrecking yards on rt 20 , might be worth a drive across the state to check them out. Don't waste your time or gas money - this was over 50 years ago! The yard that submerged Superbird went to would have parted it out within probably a year & crushed it. That car is LOOOOONG gone. Only way it could have survived, is if someone bought it complete from the yard. Helluva story though.
[Re: poorboy]
#3051172
06/17/22 07:29 AM
06/17/22 07:29 AM
Posts: 19,992 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Don't know what it was like back then, but these days, a flood car (one that has been under water above the rockers) that is less then 10 years old at the time of going under water, can not be "rebuilt" it has to be scrapped. That's not correct. Plenty of cars that end up in the situation you describe get repaired.
Earning every penny of that moderator paycheck.
DBAP
[Re: 360view]
#3051343
06/17/22 05:36 PM
06/17/22 05:36 PM
Posts: 5,924 ohio
ruderunner
ohio
IDK, I've dunked a few 4wd trucks over the years, pull em out, drain them out, fresh fluids and run it!
One was my 6 month old Ranger. Drove it daily for 4 years.
