high output small alternator #3049614
06/11/22 10:48 AM
06/11/22 10:48 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I have a mini denso style alternator on my barracuda, it fits fine, but I do not think I could go with a OE style due to the size.
My current alternator puts out 90 amps max. I am running a big electric fan, big dual fuel pumps, electric water pump and holley fuel injection. While the car is running it actually loses charge. My alternator is maxed out and cannot keep up with the demand. It was adequate before I went to EFI, but the addition of the fuel pumps, and water pump and efi has made it unacceptable.
I am looking for something small and single wire hookup. Ideally Id like to see 150 amps- mine is mounted to the motor plate, on the passenger side at the bottom of the plate just about the k member. It is an AndyF plate and alt kit.
I do not have much room- so i need something small. HELP!!!!!
Re: high output small alternator [Re: 8urvette] #3049622
06/11/22 11:28 AM
06/11/22 11:28 AM
AndyF Offline
AndyF  Offline
You might have a problem with your alternator since the combined load of what you listed isn't 90 amps. Do you have a clamp meter? Clamp meters are fairly inexpensive these days and super handy to have. I go around the car and check the amperage in every cable on the car to see what is going on. Often times you'll be surprised that one cable is carrying a lot of current while another one isn't. All it takes is a poor connection somewhere to mess things up.
Check your alternator output with the engine running and see how many amps it is producing. Check both battery cables as well as all the engine grounds.
Re: high output small alternator [Re: AndyF] #3049654
06/11/22 12:49 PM
06/11/22 12:49 PM
moparx Offline
moparx  Offline
first thing i thought of, was grounds.
need to check those closely.
also, please tell me you aren't using those elcheapistan "clamp on" battery terminals where the positive and negative cables are retained to the terminal by a strap and two bolts. i hate those things ! mad
horrible connection[s] for sure using those !
beer
Re: high output small alternator [Re: 8urvette] #3049660
06/11/22 01:10 PM
06/11/22 01:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My local alternator shop told me you can’t get high output out of these small alternators. After talking to him I’d be surprised if yours is putting out 90 amp.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: high output small alternator [Re: pittsburghracer] #3049774
06/11/22 08:48 PM
06/11/22 08:48 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Idont have a clamp on amp meter... would be nice.
The ground from the battery to chassis is 2/0 with crimp connectors on the batter side a 3/8 lug on the other side. I am also running a 2 ga ground strap from the block back the neg on the battery, it's a double barrel style crimp connector. I have several small 8 ga grounds from various parts of the engine to the chassis, including the alternate and starter case.
My battery is a big 950cca 1100 mca battery.
My alternator probably isn't putting out the advertised 90 amp, but what can I get that is small that will put out decent amperage?
Re: high output small alternator [Re: 8urvette] #3049798
06/11/22 10:16 PM
06/11/22 10:16 PM
AndyF Offline
AndyF  Offline
You can buy a clamp meter for $30 from Amazon. I'd suggest buying one before you waste money on upgrading your alternator. You might just have a bad connection somewhere.
https://www.amazon.com/Proster-Auto...&hvtargid=pla-570396598205&psc=1
Re: high output small alternator [Re: AndyF] #3049810
06/11/22 10:44 PM
06/11/22 10:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is the fan on a relay?
Re: high output small alternator [Re: slantzilla] #3049813
06/11/22 10:58 PM
06/11/22 10:58 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Fan, water pump and fuel pump are all on relays
Re: high output small alternator [Re: 8urvette] #3049830
06/12/22 07:15 AM
06/12/22 07:15 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I was looking at these to upgrade (the 150A ones) but they are pricey. Page 46-47. HTH's
http://www.powermastermotorsports.com/catalog.html#
EDIT: They aren't too bad price wise.I was looking at the ones with mounting kits on Summit, that bumps the price up some grin
Re: high output small alternator [Re: Tig] #3049831
06/12/22 07:53 AM
06/12/22 07:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run a Denso mini as well. Been thru all the voltage drop tests. Sped it up to a 3-1 ratio. Still can't keep up with the fans. The field core just isn't big enough physically to produce enough amperage. The ratings are unrealistic.
Doug
Re: high output small alternator [Re: dvw] #3049845
06/12/22 09:24 AM
06/12/22 09:24 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
150 amp alternator is definitely a bigger core, 118mm case. My dad's 75amp alternator is 100mm case and it is a tiny little thing. If you can possibly fit the 118mm, its a good investment. Part# 8148 from powermaster. Can't say enough good things about the alternator.
Re: high output small alternator [Re: 8urvette] #3049969
06/12/22 03:42 PM
06/12/22 03:42 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
do a load test on your battery.
Re: high output small alternator [Re: johnzgarage] #3049981
06/12/22 04:47 PM
06/12/22 04:47 PM
AndyF Offline
AndyF  Offline
Exactly. Find the real problem before throwing money
Re: high output small alternator [Re: AndyF] #3049997
06/12/22 06:04 PM
06/12/22 06:04 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
What pulley ratio (or just pulley sizes) and idle speed?
Re: high output small alternator [Re: INTMD8] #3050001
06/12/22 06:38 PM
06/12/22 06:38 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
ok, it is a new battery- a few months old- 6 at most.
I wanted to upgrade it and get some more CCA- I went and bought a new battery figuring ill just use this one in one of my other projects.
Start the car up with the new bigger battery and i have 14.4 volts at idle.
with the other battery i was seeing in mid 13's.... so maybe i dont use this "old" battery and just return it?
Re: high output small alternator [Re: 8urvette] #3050009
06/12/22 07:32 PM
06/12/22 07:32 PM
AndyF Offline
AndyF  Offline
So it wasn't an alternator problem after all. Might have been a battery issue or it could've been a bad connection which you fixed when you replaced the battery. You can double check by swapping batteries again and making sure everything is tight. If the voltage drops back to 13 at idle then you know the battery is weak.
Re: high output small alternator [Re: INTMD8] #3050012
06/12/22 07:43 PM
06/12/22 07:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
East coast recommends around 20,000 alternator rpm at max engine RPM. So a 7000 rpm motor is close to 3-1 ratio.
Doug
Re: high output small alternator [Re: dvw] #3050036
06/12/22 09:08 PM
06/12/22 09:08 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
^ Suprised 20k doesn't damage the rotor, I thought Denso's were 16k max.
I'm at 2-1 ratio, 1150 idle, 7600 max rpm, so alternator speed 2,300 at idle and 15,200 max.
Re: high output small alternator [Re: INTMD8] #3050066
06/13/22 12:13 AM
06/13/22 12:13 AM
AndyF Offline
AndyF  Offline
The small Denso alternators are 20,000 rpm limit. The GM alternators are usually 16,000 or 18,000. Powermaster has the numbers in their catalog.
Re: high output small alternator [Re: 8urvette] #3050072
06/13/22 02:36 AM
06/13/22 02:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
Don't forget about the wire size on the car feeding from the alternator to the battery possibly being a choke, you can only push so many amps through a stock wire work scope
One of the Power Master techs. told me to use a # 4 gauge wire from their single wire100 amp alternator directly to the battery after I burnt the original 10 gauge wire up in my old race car by accidently grounding it while trying to use a timing light off of the single wire feed to the battery, the clamp on lead for the 12V feed to the timing light flopped over when i started the motor up and grounded out against the case whiney realcrazy
