Looking for 440 rebuild kit to improve torque
#3044008
05/20/22 09:03 PM
05/20/22 09:03 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Since I last posted on here, decided to start collecting parts to build my 75’ Trailduster. A friend was in desperate need and ended up selling him my last street 440 I had, so now I will need to build one for the truck. Looking for rebuild kit or to put something together to build on the engine. It’s a stock 205hp 75’ cast crank 440. I want to continue to run goatpiss that passes for 87 octane in California. I’m not looking to make big horse power, more like torque, so a good street-able profile is good. If I can up the horsepower to 300+ and have much more torque and not affect the mileage to much for city driving and a little hauling around the area.
So looking for a good quality rebuild kit with pistons. Would love to hear ideas on a cam/lifter. Also plan to run a thermoquad, RPM intake and stock electronic ignition. Also, looking at possibly headers as you guys told me it would help with torque. Keeping the 3:55 ratio gearing in the truck if that helps.
Re: Looking for 440 rebuild kit to improve torque
[Re: mgoblue9798]
#3049425
06/10/22 02:36 PM
06/10/22 02:36 PM
Posts: 246 Falcon, CO
Mad-Max
Falcon, CO
...while I haven't had it out on the main streets yet to see how well it does, the Engine Pro MC1787 is the cam I put in my 440 (it was what came in the engine master rebuild kit ordered from the machine shop). It idles smooth, and from the few hours it's been running /driving around the property it seems to have loads of torque. My truck was built to be a multi-purpose camping/rock-crawling rig that is also 100% streetable - it rolls on 40" Toyos with 5.38 gears. I found the engine buried deep inside a '79 Winnebago motor coach - it is a 440-3 block with standard 452 heads, and got a standard 'RV' rebuild with ~9-1 compression.
Engine Pro MC1787, hydraulic flat tappet - Duration @ .050 Intake 204 Exhaust 214, Advanced Duration Intake 278 Exhaust 288; Valve Lift .420 Exhaust .443 - Lobe Sep. Intake 107 Exhaust 117; Power range 1500-4000; Idle: Smooth - Comment: Torque Cam strong low to mid range torque and pulling power.
- Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
[Re: migsBIG]
#3049475
06/10/22 06:54 PM
06/10/22 06:54 PM
Guitar Jones
Stroke it to 490-500 cubes. Torque for days on pump swill.
[Re: Guitar Jones]
#3049551
06/11/22 12:05 AM
06/11/22 12:05 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Stroke it to 490-500 cubes. Torque for days on pump swill. This ^^ 4.25 stroker crank. The rest you had to buy anyway. 600ft/lbs easier than falling out of a tree. Kevin
[Re: Twostick]
#3051327
06/17/22 04:25 PM
06/17/22 04:25 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
Stroke it to 490-500 cubes. Torque for days on pump swill. This ^^ 4.25 stroker crank. The rest you had to buy anyway. 600ft/lbs easier than falling out of a tree. Kevin I love my 512, but it isn't really conducive to gas mileage. Even with a 3.54 gear and overdrive.
[Re: MarkZ]
#3051331
06/17/22 04:46 PM
06/17/22 04:46 PM
Guitar Jones
Stroke it to 490-500 cubes. Torque for days on pump swill. This ^^ 4.25 stroker crank. The rest you had to buy anyway. 600ft/lbs easier than falling out of a tree. Kevin I love my 512, but it isn't really conducive to gas mileage. Even with a 3.54 gear and overdrive. My magnum headed 360 LA gets 7 MPG, 4.10s and no overdrive, I bet your 512 isn't too far off of that. Hoping the NV4500 O/D gets it to at least 10. Probably wishful thinking though as the truck spends 90% of its time below 30 MPH. Still won't be a waste though as I had already purchased most everything for the swap at least 3 years ago. I've spent less than $800 up to this point actually doing the swap and the NP435 was on its last legs.
