Speedometer won't work
#3049455
06/10/22 05:47 PM
06/10/22 05:47 PM
Posts: 32 North Tonawanda
Checker
North Tonawanda
Changed transmission and valve body on My 67 RT. Speedometer worked fine before the swap. Now it's out for lunch. Checked the housing in the tail and the gears in the tail section turn when turning the wheels. All gears back there are looking good. Put a drill motor on the cable and the speedometer works. So I "assume" the cable and speedometer head are ok. All connections in the tail..speedometer to gears look ok. I was told the cable may still be bad because when putting a drill on it the inner cable moves in and out about an inch. Any help is appreciated. Thanks all. Thanks MOPARTS 727 Big block
Re: Speedometer won't work
[Re: Checker]
#3049470
06/10/22 06:37 PM
06/10/22 06:37 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
When I installed a new cable two years I had the same thing happen. Evidently I tightened the nut on the cable too tight, cause after testing the speedo with a drill and left the nut looser everything has worked fine since
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3049479
06/10/22 07:32 PM
06/10/22 07:32 PM
MoreParts
First thing I'd try doing is disconnection the cable from both ends. Then draw the cable up a bit from the passenger compartment, connect it at the transmission, then at the speedo. While you have it disconnect, also check to see of the end got bent.
[Re: MoreParts]
#3049582
06/11/22 08:21 AM
06/11/22 08:21 AM
Checker
North Tonawanda
First thing I'd try doing is disconnection the cable from both ends. Then draw the cable up a bit from the passenger compartment, connect it at the transmission, then at the speedo. While you have it disconnect, also check to see of the end got bent. I'll try this at the tranny end as with a drill the speedo works but as said earlier there is play at the tranny line and "possibly" the cable is not going into the gear when screwing the connector on...Thanks
[Re: stumpy]
#3049638
06/11/22 12:14 PM
06/11/22 12:14 PM
Checker
North Tonawanda
Did you possibly change the clocking of the speedo gear housing? What year trans did you swap out and in? Some used a different style gear. Took that assembly out of the old and installed in new
[Re: Checker]
#3049639
06/11/22 12:19 PM
06/11/22 12:19 PM
Posts: 6,252 nowhere
Sniper
nowhere
Did you possibly change the clocking of the speedo gear housing? What year trans did you swap out and in? Some used a different style gear. Took that assembly out of the old and installed in new Did you clock it properly?
[Re: Checker]
#3049641
06/11/22 12:22 PM
06/11/22 12:22 PM
Posts: 19,406 north of coder
moparx
Did you possibly change the clocking of the speedo gear housing? What year trans did you swap out and in? Some used a different style gear. Took that assembly out of the old and installed in new but is it snugged up [clocked] against the transmission output gear according to the tooth count of the speedometer gear in accordance to the speedometer gear housing markings ?
[Re: moparx]
#3049668
06/11/22 01:38 PM
06/11/22 01:38 PM
Checker
North Tonawanda
Did you possibly change the clocking of the speedo gear housing? What year trans did you swap out and in? Some used a different style gear. Took that assembly out of the old and installed in new but is it snugged up [clocked] against the transmission output gear according to the tooth count of the speedometer gear in accordance to the speedometer gear housing markings ? yes....I'll ad a bit more..The person who built the tranny and helped me install is well known throughout Niagara County as the mopar guy to go to. I've known him for over 20 years ..he's 74 years old and has been working mopars since 1964. Builds all type motors. Built the hemi in My car. He shakes his head on this one and even though the speedometer turns with a drill and worked with the other tranny..He seems to think the play in the inner section of the cable is the issue. I'm going to disconnect at the tranny and if enough inner cable is exposed...I'll use needle nose to insure the cable feeds into the tail section housing. Thanks
[Re: Checker]
#3049670
06/11/22 01:44 PM
06/11/22 01:44 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Have you seen the speedometer move at all when turning the cable form the bottom? If not make sure the square cable tip is engaged in the speedometer gear in the instrument cluster good luck on getting this fixed and back into service
[Re: Cab_Burge]
#3049709
06/11/22 04:19 PM
06/11/22 04:19 PM
Checker
North Tonawanda
Have you seen the speedometer move at all when turning the cable form the bottom? If not make sure the square cable tip is engaged in the speedometer gear in the instrument cluster good luck on getting this fixed and back into service Speedometer works with a drill motor connecteced so one would "think" from the cable at the tail shaft forward: everything is ok
[Re: Checker]
#3050324
06/13/22 10:06 PM
06/13/22 10:06 PM
Posts: 15,359 Omaha Ne
TJP
Omaha Ne
