Re: 11 second A-body small block build?
[Re: Valiant_Showoff]
#3048313
06/06/22 02:21 PM
06/06/22 02:21 PM
Posts: 20,751 A collage of whims
topside
A collage of whims
I ran consistent 11.40-11.44 with the following, in a '70 Duster @ about 3200 lbs with me and 10 gals gas in it: 358" 340, ported X heads, 750DP Holley, single-plane intake, MSD, Crane MFT .580/.600 lift, 12.5:1 CR, Stahl 1 7/8 headers. Holley blue, Moroso electric water pump, pan evac, 8-point cage. 7.10s on 15x4s in front. Jack Arnew's modified upper control arms (car always went dead straight & carry ft wheels at launch). 4400-stall TA converter, RMVB mostly stock 904, Dana 60 5.38, 13x31s on 15x12 wheels (mini-tubs, springs moved to rails). The fewer pounds you have to move, the better for literally everything. That said, it always liked more ballast in the trunk. It was never a street car, so everything that wasn't needed was gone except 1 seat and a finished interior.
[Re: topside]
#3048319
06/06/22 02:46 PM
06/06/22 02:46 PM
Posts: 4,669 Wichita
GY3
Wichita
Gonna need better or ported heads and/or, like topside said, lighter weight.
[Re: topside]
#3048327
06/06/22 03:05 PM
06/06/22 03:05 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
It’s gonna take those heads being pretty good to do what you want at that weight. Just went through several motors/ upgrades on my 3300 pound Dart. Bone stock 360 shortblock. It started with stock Eddie heads, 4500 8 inch vert, 750 Holley, 1 5/8 headers, 4.10 gear, and a 727. Cam was a comp solid flat tappet. If I remember right it was like 244@50, had a missmatched( for the combo) Mopar M1 single plane on it. Ran 12.23 at 109 and change
I had the heads mildly ported( not a full tilt job by any means) and milled about 30 to help compression a bit, also ran 028 mr Gasket head gaskets. , heads went in range of 260 ish at 550 lift” Ditched the M1 for an airgap, installed a 950 Holley I had that was known to be very good, Howard’s solid cam 260/264 565/565 lift, After those changes, car went best of 11.26@ almost 119. Most of the time though 11.40’s in the summer. Cam really woke it up. 8 inch convertor is a requirement, and just cutting the heads a bit and minor porting helped take advantage of the upgrades. Strongly recommend the airgap, works nice I think your going to find that with your weight and 3.55 gears it tough to get where you want.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
#3048329
06/06/22 03:06 PM
06/06/22 03:06 PM
Posts: 1,772 Keymar, MD
DusterKid
Keymar, MD
You might be able to dip into the 11's if your combo is 100% working on a great weather day other wise I think your going have to change something. We have raced a Duster 3200ish lbs, dedicated race car, but not all chopped up for 15 years now with a 360. Dana 60, 4.56 gears, 30" tire, 727. The compression has always been 10-10.5:1. We've ran .a 533/.533, .519/.524 hydraulic cams, .528/.528 solid cam. We picked up a good bit when we went to a 8" 5000 stall convertor. All engines were shifted at 6,000, used a Victor 340 intake with a 750 Holley. We've ran steel X (I think X and not J but could have that backwards), Edlebrock and Trick Flow heads. We ran the Edelbrocks the most and that combo was typically a 11.60-11.80s combo, best it ever went was a 11.51. Trick Flows we only have a few runs on but ran about a tenth quicker than the Edelbrocks. The steel heads ran 12.00-12.20s. We used to have cheap hedman headers on the car, but have since put Dougs 1 5/8 headers and with a 12" glasspak muffler.
[Re: DusterKid]
#3048342
06/06/22 03:47 PM
06/06/22 03:47 PM
Posts: 4,975 new jersey usa
11secdart
new jersey usa
Lots of good advice here... IMO more gear ( 4.10, 4.30 or 4.56 ) less converter ( 8 inch ) just a quick note : years ago my good 340 was broken and I had a basically stock 318 ( 340 cam, LD4B intake, 750 carb, and stock 360 heads ) with a 904 , 10 inch converter and 3.91 gears it went 13.20s in my 3200 lb Dart I put in an 8 inch Turbo- Action converter and it went 12.60s with no other changes. I went 11.30s with a 340 at 9 1/2 to 1 compression , ported " J" heads and a 557 lift Mopar Purple shaft cam . I went 10.50s ( 10.40 best ) with a 360 Magnum short block, 11.5 to 1 compression , W2 heads , 590 lift cam, made 549 hp ... currently set up has gone a best of 11.07 at 119 with the same 360 Magnum short block ,40 over to 367 c.i. , W2 heads , 585/595 lift cam, 10 to 1 compression on pump gas made 527 hp and 467 tq on the dyno. All my combos are ran thru the mufflers ( 3 inch Flowmasters ) with either 1 7/8 TTI headers or my previous Tubular Automotive 1 7/8 headers , Victor intakes and an AED prepped 750 hp carb. I wont even get into my R3 block/ Indy 360-1 head 408 thats a whole story in itself... these are just a few of the small block combos I have ran over the years.. your results may vary
#3048375
06/06/22 04:55 PM
06/06/22 04:55 PM
topside
A collage of whims
The basic logic is that the engine's a pump, and the drivetrain is a lever. So, more you can pump (airflow and RPM), and the better your leverage (converter stall and gearing), the harder the car will run. Obviously traction and weight are big factors, but you still have to create power and apply it efficiently. W2s were worth a lot for me, and ported Batten (aluminum) W2s, an 850, a .630 roller, and 6,000 RPM stall were worth .80. By then it was 368", and mid/low 10s. Shifted it usually at 7500, occasionally 8000.
[Re: topside]
#3048379
06/06/22 05:23 PM
06/06/22 05:23 PM
11secdart
new jersey usa
Man !!! .. my old 627 lift roller cam 340 /W2 head 12.5 to 1 compression I shifted at 7,200 ran 10.70s... now I am only shifting at 6,000 / 6500 leaving at 2,000 .. I guess I should mention that my car is slowed down via throttle stop to run 11.50s at 114 with 1.49-1.51 60 ft... I really like the W2 heads I wish I had them on my 408 instead of the Indy 360-1s
[Re: 11secdart]
#3048383
06/06/22 05:39 PM
06/06/22 05:39 PM
B3422W5
Portage,michigan
Man !!! .. my old 627 lift roller cam 340 /W2 head 12.5 to 1 compression I shifted at 7,200 ran 10.70s... now I am only shifting at 6,000 / 6500 leaving at 2,000 .. I guess I should mention that my car is slowed down via throttle stop to run 11.50s at 114 with 1.49-1.51 60 ft... I really like the W2 heads I wish I had them on my 408 instead of the Indy 360-1s Interesting comment. The Indy heads are pretty much aluminum W2 heads. Would rather run them any day of the week than W2’s. Depending on which flavor, they have a good bit more potential than W2’s as well. And, aluminum you can fix.
[Re: B3422W5]
#3048390
06/06/22 06:19 PM
06/06/22 06:19 PM
11secdart
new jersey usa
We had a problem with them when they arrived from Indy that my engine builder had to fix before they were able to be used and I have had a problem with breaking their rockers on three different occasions , I only shift at 6,500 and we aren't running a lot of spring pressure . I understand that was an on going problem with their rockers. Indy no longer makes or offers them anymore they sent me what they had left in stock but they weren't the ones I needed. I ended up driving three hours one way to buy a used set because I couldn't find them anywhere. A friend had one that I was able to get the second time I broke one. I have to go to Harland Sharp, T&D or Hughes to get a complete new rocker system and they aren't cheap. That motor is out now due to a cracked stroker crank and my W2 / 367 back up motor is in now. My ancient W2 ductile iron non-roller rockers have been fine for over 25 years with out any breakage
[Re: 11secdart]
#3048408
06/06/22 07:34 PM
06/06/22 07:34 PM
B3422W5
Portage,michigan
We had a problem with them when they arrived from Indy that my engine builder had to fix before they were able to be used and I have had a problem with breaking their rockers on three different occasions , I only shift at 6,500 and we aren't running a lot of spring pressure . I understand that was an on going problem with their rockers. Indy no longer makes or offers them anymore they sent me what they had left in stock but they weren't the ones I needed. I ended up driving three hours one way to buy a used set because I couldn't find them anywhere. A friend had one that I was able to get the second time I broke one. I have to go to Harland Sharp, T&D or Hughes to get a complete new rocker system and they aren't cheap. That motor is out now due to a cracked stroker crank and my W2 / 367 back up motor is in now. My ancient W2 ductile iron non-roller rockers have been fine for over 25 years with out any breakage Those Indy rockers have been known to be junk forever. Yes, a good rocker system isn’t cheap.
[Re: B3422W5]
#3048429
06/06/22 08:43 PM
06/06/22 08:43 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
If you’re not running in the 11s it’s mostly the car setup. Use the Wallace calculator, weight to mph. 3.55s won’t get you where you want to be, neither will 6000 rpm. You ain’t got a 572 big block torque monster to move that car with those gears.
#3048472
06/06/22 10:59 PM
06/06/22 10:59 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
#3049284
06/10/22 03:43 AM
06/10/22 03:43 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Nitrous or a turbo will get you there with those gears at that weight.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
#3049427
06/10/22 02:37 PM
06/10/22 02:37 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
It will cost more, but in the long run, these would be much better options:
360 Magnum with stock Eddy heads, small .520 cam, inexpensive 76 mm turbo, 3:55 gear, 2,500 stall, aftermarket fuel injection. You will have to purposely try not to run 10's.
OR
6.2 Hemi w/8 speed conversion, 3:55 gears
[Re: TheOtherDodge]
#3049428
06/10/22 02:49 PM
06/10/22 02:49 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ya for sure you could use a power adder but for the ET you are looking for it’s absolutely not needed.
[Re: pittsburghracer]
#3049559
06/11/22 02:12 AM
06/11/22 02:12 AM
Guitar Jones
Not needed, but would make it very streetable, easier on parts, better fuel mileage, etc. It's a no brainer really.
