Under Floor Master Cylinder mounts? #3047877
06/04/22 01:10 PM
06/04/22 01:10 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Can I see photos of how you did yours?
And looking for the supplier that sells these;
Re: Under Floor Master Cylinder mounts? [Re: Dragula] #3048013
06/05/22 11:30 AM
06/05/22 11:30 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
i think speedway motors sells the under floor wilwood setup like you pictured.
possibly affco brand as well.
beer
Re: Under Floor Master Cylinder mounts? [Re: moparx] #3048111
06/05/22 05:31 PM
06/05/22 05:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is part of the chassis itself as was the one in my other tube chassis cars.
Re: Under Floor Master Cylinder mounts? [Re: moparx] #3048142
06/05/22 08:16 PM
06/05/22 08:16 PM
Dragula Offline OP
Dragula  Offline OP
beer
Checked all 8 pages.....didn't see it.
Re: Under Floor Master Cylinder mounts? [Re: Dragula] #3048276
06/06/22 11:51 AM
06/06/22 11:51 AM
moparx Offline
moparx  Offline
hmmm.........
i thought that odd, so i grabbed my AFCO catalog that i got from Speedway and looked up pedal assemblies.
they list dual floor mount pedal setups by wilwood [ww340-1285] tilton [T72-642] and cnc [CN204SLMC]
then i discovered that catalog was dated 2001 ! blush sorry !!!
you may have to call them. i'll bet they still offer them, just not listed in their catalog or on line.
and what about Summitt ? they offer so many things anymore they may have something.
beer
Re: Under Floor Master Cylinder mounts? [Re: moparx] #3048279
06/06/22 12:01 PM
06/06/22 12:01 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
s&w, alston, ART etc
need a check valve so calipers do not drain back to master
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Under Floor Master Cylinder mounts? [Re: 440lebaron] #3048282
06/06/22 12:02 PM
06/06/22 12:02 PM
moparx Offline
moparx  Offline
i forgot about those guys ! spank
thanks for the reminder !
beer
Re: Under Floor Master Cylinder mounts? [Re: moparx] #3048525
06/07/22 07:27 AM
06/07/22 07:27 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
if your running drum brakes a residual valve may be required to hold pressure to the wheel cylinder ! if your running aftermarket racing disc you don't want pressure held in the line by a residual valve. Had both installed not a good thing at top end brake drag! also watch for pedal ratio front pressure should be around 1250psi rear is close to 1000 psi. my master is under the floor!
Re: Under Floor Master Cylinder mounts? [Re: dart9ss] #3048541
06/07/22 08:40 AM
06/07/22 08:40 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
they have a 2# and 10# had to put in a 2# so calipers would not drain back, first brake pump nothing there
Re: Under Floor Master Cylinder mounts? [Re: 440lebaron] #3048603
06/07/22 12:03 PM
06/07/22 12:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You do not NEED a residual valve unless you run drums. I have NEVER run one on anything with a low mount master. Three dragsters and now a fourth tube chassis car with MC's on the floor and never an issue with braking or pedal feel, I can go from tight as a nats a$$ or some "wiggle" room on the pedal.
