Page 2 of 3 1 2 3
Re: Flat washers under flywheel bolts? [Re: 340Cuda] #2678496
07/17/19 11:41 PM
07/17/19 11:41 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by 340Cuda
The last ARP flywheel/flexplate bolts I bought specifically said not to use washers with them.
I have no idea why.
Yet they sell flywheel bolts with flat washers for the high end HEMI stuff. Hence my question. More of a curiosity than anything I guess.
Re: Flat washers under flywheel bolts? [Re: lancer493] #2678499
07/17/19 11:43 PM
07/17/19 11:43 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by lancer493
I 'think' the small amount of distortion created by tightening the hardened bolts,with their specifically sized and machined area under the head, may help to create a locating effect that is normally accomplished with a dowel or tapered cone. Both of the last 2 would add additional machining steps and cost.I think a hard steel washer would elimate that 'freebie' effect mentioned in the beginning,as it 'may' act as a bushing between the 2 mating surfaces. Not sure if a dowel is included in the equation. That spinning flywheel creates some serious energy there,especially when try to move a 4000lb vehicle with sticky tires. Conical lug nuts on a street car comes to mind.Nothing textbook here, purely speculation and observation. Just my thoughts. Bill
The bushing example makes good sense. I guess I didn't really think too far into how much heat gets built up in the flywheel.
Re: Flat washers under flywheel bolts? [Re: fourgearsavoy] #2678500
07/17/19 11:46 PM
07/17/19 11:46 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by fourgearsavoy
If the OP is talking about an actual "flywheel" and not a flex plate you need to be careful the bolt heads don't contact the damper springs of the clutch disc like Cab said. I like the ARP bolts with a flange built in because they are easier on the flywheel. You might be able to get away with some thin hardened AN washers but double check it.
Gus beer
You know I'd never have a car with a flex plate!
I think I'll stick with the lube under the head, loctite on the threads and torque 'em down. Now instead of being nervous about the lack of washers I am paranoid they will cause problems.
Re: Flat washers under flywheel bolts? [Re: FastmOp] #2678502
07/17/19 11:48 PM
07/17/19 11:48 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by FastmOp
I sheared grade 8 bolts a few months ago. I noticed on the ARP bolts they have a nice flat land under the head that looks pretty nice and was bigger then the land on the grade 8 bolts ATI sends with their flywheel and spacer kit. Plus the ARP bolts are 41something chrome moly.
ATI has issues with the flex plate they sell. I reused my old one because the converter bolt pattern is wrong on the new one.
Always ARP. You should see the bolts that I got from one of the vendors. They are grade 8 with the heads ground down. Very scary especially when I ordered them with all of the face plated 9310 gears. Nothing leaves my shop wearing hardware store bolts, especially on the rotating assembly. ACE is not the place for flywheel bolts.
Re: Flat washers under flywheel bolts? [Re: Stanton] #2678504
07/17/19 11:57 PM
07/17/19 11:57 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Originally Posted by Stanton
Millions have been built with no washers. All the flywheel bolt manufacturers DON'T supply washers. Good enough for me !!!
Millions have not been built with 750hp moving 3600lbs through a solid disc clutch/aluminum flywheel to plant sticky 10.5" slick tires at 5000 rpm. That begs the question.
Some of the flywheel bolt manufactures that cover the entire motorsports spectrum *do* offer flywheel bolts with washers:
Example #1
Example #2
Example #3
I though maybe I was missing something.
Re: Flat washers under flywheel bolts? [Re: Stanton] #2678505
07/17/19 11:58 PM
07/17/19 11:58 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
When it comes to high performance race parts I want to as safe as possible, especially in the cars I build, drive and race and have pay to for the race parts work
Don't you think ARP would have tossed the idea around ?!?!?
Yes, I actually do think ARP has tossed this idea around lol.
Re: Flat washers under flywheel bolts? [Re: Jeremiah] #3047770
06/03/22 11:06 PM
06/03/22 11:06 PM
Pueblo, CO USA
Darkbreeze Offline
Darkbreeze  Offline
Pueblo, CO USA
Sorry to necro, but for anybody who might still come across this thread, which they will because I did while looking for something else, I feel like it's important to correct misinformation even though I realize none of it was given intentionally.
The bottom line is, none of the answers is actually correct in this thread for about 95%, maybe more, of applications. The reason being, about 95% of manufacturers use PLACE BOLTS, which you can read about at the following link and I guarantee none of you ever heard of them otherwise they'd have been mentioned in this thread, on critical fastener locations like flywheel bolts, oil pump bolts, camshaft retainer bolts, etc.
https://www.earnestmachine.com/sites/default/files/products/imported/BHP.pdf
You will be able to identify Place Bolts by the undercut in the bottom of the head and the six cut out lines in the top of the bolt head. This design allows the bolt to create far more clamping power than a standard bolt, even when using a lock washer.
If you remove a place bolt on any application that is the ONLY kind of bolt that should go back in that application location. Generally these are used on applications where the bolt is not particularly long, since longer bolt bodies are able to provide their own additional clamping spring tension, and where they are both difficult to get to if a bolt were to come loose AND would be likely to create a catastrophic end result if they did.
Did not intend to step on anybody's toes, but sometimes, like I did, you might go half your career AFTER professional schooling, and have never heard of them, until somebody slapped me upside the head with that information. Hopefully, some of you here or others who come along later, will be better informed for the info. Good luck.
Re: Flat washers under flywheel bolts? [Re: Darkbreeze] #3047817
06/04/22 09:14 AM
06/04/22 09:14 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Very cool and thank you for the explanation and link. "Now I know!"
Re: Flat washers under flywheel bolts? [Re: Jeremiah] #3047861
06/04/22 01:28 PM
06/04/22 01:28 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I'm into bolts. Nice article. I've paid for flywheel bolts twice from "Mopar vendors" and received regular Grade 8 bolts at a big price. These guys make me very mad sometimes.
2011 Drag Pak Challenger
Re: Flat washers under flywheel bolts? [Re: Darkbreeze] #3047870
06/04/22 01:47 PM
06/04/22 01:47 PM
moparx Offline
moparx  Offline
interesting article breeze. thank you sir ! up
i learned something, so you can say you taught an old dog. biggrin
beer
Re: Flat washers under flywheel bolts? [Re: moparx] #3047995
06/05/22 10:22 AM
06/05/22 10:22 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
In the pic are stock bolts and arp, was told 45 years ago at my first car repair job to never use any bolt that did not have the cutout head on a flywheel. Now I know exactly why. Notice the arp has even more contact area on the flywheel than stock bolt no cuts in head and they are undercut. I do all mockups to check and correct flywheel runout with 7/16 head bolt washers, even with a new flywheel the place bolts distort the [censored] of of the washers, worse on a used wheel. That is why I never use washers. Thanks for the info
Re: Flat washers under flywheel bolts? [Re: Jeremiah] #3048007
06/05/22 11:39 AM
06/05/22 11:39 AM
AndyF Offline
AndyF  Offline
I've wondered about the same thing. There are examples of both washers and non-washer flywheel bolts. I use washers if there is space for them. Typically you need a chamfered washer with a high strength bolt since the bolt will have a radius under the head. I don't think there is a problem if you use the correct washer for the bolt and if you have the clearance.
Re: Flat washers under flywheel bolts? [Re: AndyF] #3048019
06/05/22 12:47 PM
06/05/22 12:47 PM
moparx Offline
moparx  Offline
so using a flexplate, i use the ARP bolts with no washers, correct ?
or use grade 8 flat washers if i have the clearance ?
beer
Re: Flat washers under flywheel bolts? [Re: Cab_Burge] #3048062
06/05/22 03:00 PM
06/05/22 03:00 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
I try to use thin harden flat washers with thin head bolts, make sure the clutch anti chatter springs don't touch the bolt heads after torqueing before using it that way scope
Just adding photos for reference since I am in the middle of trying to undo numerous mistakes on a car I bought last year.
Even without washers they bolt heads can hit... the previous owner tried to add clearance by using a hand grinder on the heads of the flywheel bolts, but it was not enough.
Re: Flat washers under flywheel bolts? [Re: moparx] #3048063
06/05/22 03:09 PM
06/05/22 03:09 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Looks like AMK has them for flywheel applications https://www.amkproducts.com/bulk-fasteners-products/?Product_ID=12702
Gus beer
64 Plymouth Savoy
Dana 60
Re: Flat washers under flywheel bolts? [Re: Craig J] #3048064
06/05/22 03:13 PM
06/05/22 03:13 PM
Rittman Ohio
Rittman Ohio
That happens when people use a flywheel that has been cut a few too many times twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Flat washers under flywheel bolts? [Re: fourgearsavoy] #3048125
06/05/22 07:47 PM
06/05/22 07:47 PM
Craig J Offline
Craig J  Offline
I believe you are probably correct. the face of the flywheel is basically even with the ring gear.
Re: Flat washers under flywheel bolts? [Re: Craig J] #3048169
06/05/22 10:58 PM
06/05/22 10:58 PM
Rittman Ohio
Rittman Ohio
Yep only good for an engine run stand now.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Flat washers under flywheel bolts? [Re: fourgearsavoy] #3048196
06/06/22 08:01 AM
06/06/22 08:01 AM
VA
dragon slayer Offline
VA
I was surprised as I read through this and was commenting to myself about "they are place bolts". Surprised it was a post from the past. Place bolts are used in several other locations including flex plate to tq, alternator bracket, cam, power steering valve.
Re: Flat washers under flywheel bolts? [Re: moparx] #3048206
06/06/22 08:54 AM
06/06/22 08:54 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
beer
Me too.
Glad to learn the automotive term “Place Bolts”.
In mining they are commonly called “Double A”
like the link to earnest machine has typed on the right.
I understand the undercut head because in Mech Engr education
class time is spent on “Stress Concentration Analysis”.
I now am wondering about whether
the six cut marks on the upper head surface are “cosmetic” just for human eyes to see
or are functional in that they affect either stress concentration
or act similar to “toothed lock washers.”
Page 2 of 3 1 2 3
