Re: '92 E.X.D. WHEEL BEARING
[Re: Magnumguy]
#3047596
06/03/22 11:29 AM
06/03/22 11:29 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
check here linky I assume it's the 4000 lb option? Disco'd, use the part numbers in google, you might turn something. 2ยข
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Magnumguy]
#3047728
06/03/22 08:00 PM
06/03/22 08:00 PM
Guitar Jones
All the diesel trucks had the 4000 pound front axle rating. Napa shows several different ones.
[Re: jerseybud]
#3047880
06/04/22 02:36 PM
06/04/22 02:36 PM
Posts: 10,645 S.E.Ohio
Magnumguy
S.E.Ohio
timken set 45 is the largest set listed on rockauto.
They must know the part number is listed right on the bearing and race right? I know the hub stuff is hard to find, and chrysler parts those years are MESSED up (ala rear leaf bushings for a 92 w250) Truck sustained suspension damage, wheel and suspension were tore up pretty bad. I guess the driver's side would be the same?
[Re: Magnumguy]
#3047914
06/04/22 06:30 PM
06/04/22 06:30 PM
Posts: 5,886 ohio
ruderunner
ohio
Get the numbers stamped on the cups and cones. Seal too.
Not uncommon but most catalogs have inaccurate listing.
Angry white pureblood male
