Late Model Pentastar 3.6L Motor & Valvetrain:
#3047335
06/02/22 11:04 AM
06/02/22 11:04 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
We (wife & I) currently have two vehicles with the 3.6L "Pentastar" V-6 engine. They are impressive as hell - lots of power, smooth, solid, & they do well on mileage. I have read & heard they are a "world-class" engine. I have also read where Chrysler brought vehicles in from various fleets where they had compiled over 500,000 miles on vehicles in some cases, & disassembled the engines & found them to show almost no wear internally. That being said, the motors are reputed to be plagued with top-end issues - issues with the overhead cams, rockers, lifters, & roller bearings. After watching these videos, it looks like the problem centers around the roller bearings. My 2016 300 has noise on cold starts (sounds like a solid lifter engine) & it will last for a good 10 minutes, but once the engine is up to temp, the noise will subside. I recently had a dealer evaluate this since I'm still under drivetrain warranty, & the tech said everything sounded fine. My question is this, after watching these videos, HOW can some of these components fail, while others not fail? I'd assume they are all built to the same tolerances, & many of the engine components are coming from the same vendors. I have not heard about improved components dated after xxx or anything like that, or using an aftermarket replacement part that is better than the factory component. I have not heard from anybody a theory on why some of these engines are affected, & others not. Could it be due to oil change intervals? Any theories or first-hand knowledge? Check these out: https://youtu.be/248MoyxigKQ https://youtu.be/XkrwxVVcjsg
Re: Late Model Pentastar 3.6L Motor & Valvetrain:
[Re: Sunroofcuda]
#3047347
06/02/22 11:42 AM
06/02/22 11:42 AM
Posts: 3,076 Michigan
A727Tflite
We (wife & I) currently have two vehicles with the 3.6L "Pentastar" V-6 engine. They are impressive as hell - lots of power, smooth, solid, & they do well on mileage. I have read & heard they are a "world-class" engine. I have also read where Chrysler brought vehicles in from various fleets where they had compiled over 500,000 miles on vehicles in some cases, & disassembled the engines & found them to show almost no wear internally. That being said, the motors are reputed to be plagued with top-end issues - issues with the overhead cams, rockers, lifters, & roller bearings. After watching these videos, it looks like the problem centers around the roller bearings. My 2016 300 has noise on cold starts (sounds like a solid lifter engine) & it will last for a good 10 minutes, but once the engine is up to temp, the noise will subside. I recently had a dealer evaluate this since I'm still under drivetrain warranty, & the tech said everything sounded fine. My question is this, after watching these videos, HOW can some of these components fail, while others not fail? I'd assume they are all built to the same tolerances, & many of the engine components are coming from the same vendors. I have not heard about improved components dated after xxx or anything like that, or using an aftermarket replacement part that is better than the factory component. I have not heard from anybody a theory on why some of these engines are affected, & others not. Could it be due to oil change intervals? Any theories or first-hand knowledge? Check these out: https://youtu.be/248MoyxigKQ https://youtu.be/XkrwxVVcjsg When i was doing warranty analysis at Chrysler I always started by breaking failures down by supplier first, date of manufacturer (day and shift), etc. The biggest culprit is process variability (people and machines) and inadequate quality control. Any time you have an assembly - in this case the 3.6 with many examples accruing that many miles the design is capable and robust. That leads to these failures being variability or maintenance. Read up on the Shainin process.
[Re: A727Tflite]
#3047432
06/02/22 03:58 PM
06/02/22 03:58 PM
Posts: 10,643 S.E.Ohio
Magnumguy
S.E.Ohio
We have a '17Pacifica. After 70,000 miles, #5 started leaking A-freeze. Took about 3 wks to get one, tech breaks off a bolt in that head reassembling, so off it came after waiting that long, then it's another 3 wks to get another. I've owned Chryslers that I've extremely overheaded, abused, paid virtually no money for. Only one in my 50 yrs of ownership that I"ve had to take the motor apart. I will agree it a runnin' son of a gun though.
[Re: Magnumguy]
#3047453
06/02/22 06:21 PM
06/02/22 06:21 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
We have a '17Pacifica. After 70,000 miles, #5 started leaking A-freeze. Took about 3 wks to get one, tech breaks off a bolt in that head reassembling, so off it came after waiting that long, then it's another 3 wks to get another. I've owned Chryslers that I've extremely overheaded, abused, paid virtually no money for. Only one in my 50 yrs of ownership that I"ve had to take the motor apart. I will agree it a runnin' son of a gun though. I have one in my 2014 300. It is impressive for such a small engine. Part of the credit though has to go to the 8spd ZF transmission. It would not do nearly as good a job on a 4,000 lb plus vehicle without the gearing.
[Re: mgoblue9798]
#3047459
06/02/22 06:38 PM
06/02/22 06:38 PM
Sunroofcuda
Highland, MI.
We have a '17Pacifica. After 70,000 miles, #5 started leaking A-freeze. Took about 3 wks to get one, tech breaks off a bolt in that head reassembling, so off it came after waiting that long, then it's another 3 wks to get another. I've owned Chryslers that I've extremely overheaded, abused, paid virtually no money for. Only one in my 50 yrs of ownership that I"ve had to take the motor apart. I will agree it a runnin' son of a gun though. I have one in my 2014 300. It is impressive for such a small engine. Part of the credit though has to go to the 8spd ZF transmission. It would not do nearly as good a job on a 4,000 lb plus vehicle without the gearing. Did yours ever develop the oil filter housing leak? I'm on my 3rd 300 - first one was a 2012, then a 2014, & my current one is the '16. The 2012 developed the oil filter housing leak - this is VERY COMMON. It was covered under the drivetrain warranty luckily. I also got this feedback from my Challenger dealer in PA. earlier today about the 3.6L: Sounds like a hit or miss case to me. We have traded a few 3.6’s with over 250000 miles that have never been opened up or any issues.
Brant J Schroyer General Manager Laurel Valley Motors
[Re: Sunroofcuda]
#3047464
06/02/22 07:00 PM
06/02/22 07:00 PM
mgoblue9798
Atlanta, GA
Brant J Schroyer General Manager Laurel Valley Motors Not yet, but I do my own oil changes. I could see it would be very easy to crack if some nimrod at a lube shack started torquing on it. Should have been designed with a metal filter base and cover with the replaceable cartridge style filter.
[Re: Sunroofcuda]
#3047557
06/03/22 02:13 AM
06/03/22 02:13 AM
Posts: 5,139 Las Vegas, NV
Tom_440
Las Vegas, NV
Brant J Schroyer General Manager Laurel Valley Motors My 2014 had the oil cooler leak. No drivetrain warranty from my dealer so I did it myself. Interesting concept taking off 2 intake manifolds to replace the oil cooler and oil pressure sending unit (which also is a common failure). It was a good opportunity to replace the spark plugs though. But that motor gets great mpg considering the heft of the challenger it is lugging around.
[Re: dvw]
#3047629
06/03/22 01:18 PM
06/03/22 01:18 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I fixed a 3.6 for my friends son. Just over 100,000. Every oil change was done at the dealer. Started ticking from the upper end. It ate the needle bearings in one cam follower. I slipped a follower in. Been fine ever since. That's the only one that I've known personally to have aby issue. My Caravan runs great Doug I keep a couple rockers on the shelf for our Town and Country. If you can catch the noise when the rollers first start to go, it's not that hard of a job to change them. I've swapped 2 since 2015. But if the noise goes too long and the roller seizes and wipes the cam lobe the job gets way bigger.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#3047789
06/04/22 01:02 AM
06/04/22 01:02 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
I had the tick in the wife's 2015 3.6 Grand Cherokee. It had one bad cam follower, I changed them all. Had about 84,000 miles on it. Oil changed at the dealer every time. I do my own oil changes now, hopefully I don't have any other issues.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
