surprising performance increase #3047328
06/02/22 10:19 AM
06/02/22 10:19 AM
coquille oregon
1savoyracer Offline OP
coquille oregon
in my 727 of all places.......changed out my tranzact valve body, for a Griner, from Keith Long at "727 Specialist".........No other changes to the car were made.......1/8th mile racing, i instantly picked up 2 tenths, 5 MPH, and .05 on my 60 foot........all from a valve body swap. with so many disappointments out there in the racing world, both products and people, it is really a pleasant surprise when i get something that unexpectedly worked so damn well.......so, a big thanks to Keith!
Re: surprising performance increase [Re: 1savoyracer] #3047338
06/02/22 11:17 AM
06/02/22 11:17 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We had an older Trans act one, and it cracked....not sure how long it was like that, but he did partially warranty it.
Re: surprising performance increase [Re: 1savoyracer] #3047341
06/02/22 11:28 AM
06/02/22 11:28 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Are you footbraking, or using a transbrake?
Re: surprising performance increase [Re: DusterKid] #3047345
06/02/22 11:40 AM
06/02/22 11:40 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I had an older Griner and it cracked and I lost all line pressure.
They did fix it. Cost me $295.00 to fix and a full rebuild.
My transact valvebody is excellent.
My fixed Griner works excellent too when I swapped them out.
Re: surprising performance increase [Re: Sammy] #3047349
06/02/22 11:44 AM
06/02/22 11:44 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
nice, that's a big step up , most of been something wrong with transact
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: surprising performance increase [Re: 1savoyracer] #3047363
06/02/22 12:38 PM
06/02/22 12:38 PM
A727Tflite Offline
A727Tflite  Offline
Hard to believe.
Re: surprising performance increase [Re: DusterKid] #3047371
06/02/22 12:52 PM
06/02/22 12:52 PM
coquille oregon
coquille oregon
I am using a transbrake
Re: surprising performance increase [Re: 440lebaron] #3047376
06/02/22 12:54 PM
06/02/22 12:54 PM
coquille oregon
coquille oregon
possible, it was that way from day one
Re: surprising performance increase [Re: 1savoyracer] #3047399
06/02/22 02:23 PM
06/02/22 02:23 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
You are welcome 1savoyracer.
Griner did allot of testing to get the best shift timing and to reduce overlap. I have seen this in the past. Keith
Re: surprising performance increase [Re: 727specialist] #3047435
06/02/22 04:13 PM
06/02/22 04:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
how could it improve the 60ft? unless he is out of 1st gear by then... not releasing as quickly whatever element is holding it locked or the only other thing I could imagine would be if it was letting a little fluid into 2nd servo or 3rd gear clutch pack causing some bit of fluid drag on the frictions yet not enough to engage and burn a clutch or band?
Re: surprising performance increase [Re: 1savoyracer] #3047449
06/02/22 05:49 PM
06/02/22 05:49 PM
AndyF Offline
AndyF  Offline
2 tenths is a lot. Must have had a lot of shift overlap or perhaps something funny going on with the line pressure. That is a big gain. Another reason why I don't get super excited about people trying to predict engine power from the ET. Until the car is all sorted out the ET can change quite a bit without making engine mods.
Re: surprising performance increase [Re: HotRodDave] #3047450
06/02/22 05:56 PM
06/02/22 05:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I believe converter charge pressure can effect a lot of things.
68 Barracuda Formula S 340
Re: surprising performance increase [Re: HotRodDave] #3047452
06/02/22 06:03 PM
06/02/22 06:03 PM
NW Indiana USA
NW Indiana USA
The trans is in first and reverse when the brake is on. The high gear clutches have to release quickly. If they don't that can affect the 60 ft. Keith
Re: surprising performance increase [Re: 727specialist] #3047495
06/02/22 08:33 PM
06/02/22 08:33 PM
A727Tflite Offline
A727Tflite  Offline
Correct. And how does one release the front clutch quicker through the valve body?
Re: surprising performance increase [Re: A727Tflite] #3047499
06/02/22 08:40 PM
06/02/22 08:40 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Curious if footbraking a trans with a brake would make the car slower than with a foot brake valve body
Several years ago I swapped out a 727 with T/A reverse manual valve body, swapped in a 904 with a brake valve body( A&A) which I have always footbraked, car actually slowed down 7 or 8 instead of picking up a tenth or so I expected. I don’t think the convertor is off, in fact I feel it’s more “ right” than the one that was in it when I bought the car.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: surprising performance increase [Re: A727Tflite] #3047522
06/02/22 09:53 PM
06/02/22 09:53 PM
NW Indiana USA
NW Indiana USA
The Griner valve body dumps the pressure through the solenoid and the hole drilled in the high gear drum. Keith
Re: surprising performance increase [Re: B3422W5] #3047527
06/02/22 10:18 PM
06/02/22 10:18 PM
NW Indiana USA
NW Indiana USA
Not with a Griner. You should have picked up a couple of tenths just by switching the 727 to a 904 Keith
Re: surprising performance increase [Re: 727specialist] #3047562
06/03/22 06:25 AM
06/03/22 06:25 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I agree
1.41 best 60 foot
6.60 at 103.90 1/8
Re: surprising performance increase [Re: B3422W5] #3047567
06/03/22 07:10 AM
06/03/22 07:10 AM
Locomotion Offline
Locomotion  Offline
It's my understanding that trans-brake combos need to operate at higher pressures than footbrake combos. the extra pressure can increase drag on the pump and slow ET's footbraking.
Re: surprising performance increase [Re: 727specialist] #3047568
06/03/22 07:16 AM
06/03/22 07:16 AM
A727Tflite Offline
A727Tflite  Offline
I was under the assumption the others released the same way. Without changing the reaction shaft support which is a fixed restriction in the system I was wondering how the valve body can release the front clutch faster.
Anyways, no need to reply, not here to pick at your product, I heard it’s a good one. Just that two tenths is pretty amazing.
