Antique auto part? Anyone recognize it? #3047033
06/01/22 11:47 AM
06/01/22 11:47 AM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
A little background. I invited several metal detectorists to explore area around my colonial house. So far, except for a few wheat pennies, they have found about 30 pounds of iron. Largely farming relics. About 6" down, they found this. It may be important to note the house has never had steam heat. The shape immediately suggests to me some connection with the thermostat in an auto's cooling system. I think it important to note that it has a "bleed" allowing fluid to flow out of it, perhaps to a pressure or temperature gauge. It has a part number, but it is now illegible. Anyone recognize it?
I bead blasted it, and have tried to attach a few pictures (I hope that worked)
What I am calling a "bleed" is shown in the second picture, just below the tubular portion. It could be mistaken for a shadow.
Re: Antique auto part? Anyone recognize it? [Re: Faust] #3047043
06/01/22 12:24 PM
06/01/22 12:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Automatic choke heat tube source? Does the end of the tube opposite the threaded fitting have a small opening?
Re: Antique auto part? Anyone recognize it? [Re: John_Kunkel] #3047052
06/01/22 12:45 PM
06/01/22 12:45 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
No, only what I am calling a "bleed" into the main fitting itself. That is shown in the second picture, although it might look like a shadow. So, the brass fitting can draw fluid or pressure from the main fitting. I was assuming it was part of the cooling system, although I suppose it could mount on an exhaust flange.
Re: Antique auto part? Anyone recognize it? [Re: Faust] #3047126
06/01/22 03:53 PM
06/01/22 03:53 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
A friend just suggested it could have been mounted under a single barrel carb to pull a vacuum for something. Makes sense.
Re: Antique auto part? Anyone recognize it? [Re: Faust] #3047127
06/01/22 03:54 PM
06/01/22 03:54 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Wild azz guess.....
Any history of any steam powered machinery or equipment in your local area?
Looks like it could have been a flange that was installed in a steam line so that a pressure gauge could be installed.....
Re: Antique auto part? Anyone recognize it? [Re: Faust] #3047164
06/01/22 05:31 PM
06/01/22 05:31 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
^ this
Old School approach for a manifold vacuum source.
Modern interpretation:
one barrel carburetor base plate
Down to just a blue car now.
Re: Antique auto part? Anyone recognize it? [Re: rick@laysons] #3047165
06/01/22 05:36 PM
06/01/22 05:36 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
Originally Posted by rick@laysons
Wild azz guess.....
I wondered about that possibility. While it became a manufacturing town, my property was a large farm. That is why I mentioned the house had never had steam heat (or any heat, until my parents bought it).
Re: Antique auto part? Anyone recognize it? [Re: Faust] #3047195
06/01/22 07:22 PM
06/01/22 07:22 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Probably an old tractor part.
Re: Antique auto part? Anyone recognize it? [Re: 71GTX471] #3047197
06/01/22 07:28 PM
06/01/22 07:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It could also introduce heat to the carb, I suppose, but more likely pulls manifold vacuum.
