Engine install question #3046101
05/29/22 10:35 AM
05/29/22 10:35 AM
BDW Online content OP
BDW  Online Content OP
70 Challenger, 5.7 Hemi, 518 in car.
Getting ready to test fit the 5.7 and wondering if coming in from side will work?
Car is in garage, so bringing engine from front on lift would be difficult because of the 1" step in concrete.
Nice level concrete floor on side, 2 car garage, with Challenger sitting against wall.
I pulled the 340 from front, not so bad going backwards down over the 1" drop, it was a pain pushing back the other way to drop engine in garage.
Best to leave transmission in final postion, or push back, drop in motor, and reconnect?
Any isues, or reason its better to come in from front?
I'm most likely going to be doing this twice, test fit, then final drop in.
Appreciate any advice
Re: Engine install question [Re: BDW] #3046115
05/29/22 11:41 AM
05/29/22 11:41 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
When I installed the 440 in my car I had the engine and hoist sitting at the front of the concrete lip, pushed the car up installed engine and transmission together slid underneath to install transmission cross member then pushed car back into the garage. Just Becareful if your driveway is slanted I blocked the hoist.
Good luck
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Engine install question [Re: BDW] #3046122
05/29/22 11:59 AM
05/29/22 11:59 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Easier to line everything up from the front.
As you lower the hoist, the load moves away from it & engine bays are narrow side to side, so more room front to back.
Use two layers of 1/2" plywood at your 1" drop, easy-peasy.
Re: Engine install question [Re: Alaskan_TA] #3046404
05/30/22 11:27 AM
05/30/22 11:27 AM
moparx Offline
moparx  Offline
plywood to the rescue lots of time on my gravel driveway in front of the garage.
beer
Re: Engine install question [Re: Alaskan_TA] #3046592
05/30/22 09:28 PM
05/30/22 09:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Engine install question [Re: TJP] #3046603
05/30/22 09:53 PM
05/30/22 09:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Not you mention that an engine hoist coming in from the side has to maneuver around the front tire. Then how would you get the motor to shift backwards to go down between the firewall and the radiator support when each leg of the engine hoist is trapped on either side of the tire?
Re: Engine install question [Re: poorboy] #3046605
05/30/22 09:59 PM
05/30/22 09:59 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Gantry crane
Re: Engine install question [Re: Sniper] #3046617
05/30/22 10:38 PM
05/30/22 10:38 PM
Midwest
MoparsnMissiles Offline
Midwest
B series truck engine? How about a pic of the truck?
Re: Engine install question [Re: Sniper] #3046622
05/30/22 10:57 PM
05/30/22 10:57 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Originally Posted by Sniper
Gantry crane
My thought as well.
Check rental yards and or metal fab shop to loan or rent one.
Chain or elect hoist and leveler will make job easier
Re: Engine install question [Re: srt] #3046801
05/31/22 04:34 PM
05/31/22 04:34 PM
Thx for the replies, coming in from the front makes sense.
I have a HF lift, it worked well taking the 340 out, so should do that trick putting the 5.7 in.
My driveway has a little grade, and I'll have to deal with the 1" lip.
So I guess I'll have to round up some plywood and give it go.
Re: Engine install question [Re: MoparsnMissiles] #3046812
05/31/22 05:10 PM
05/31/22 05:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
52 Dodge pass car 230 going into my 51 Plymouth once it gets built and hopped up.
The build thread
https://board.moparts.org/ubbthread...1951-plymouth-cambridge.html#Post2697670
