Page 1 of 3 1 2 3
Anyone ever used CLR to flush / clean a radiator #3046222
05/29/22 06:06 PM
05/29/22 06:06 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
The coronet runs a little warmer than I feel it needs to. A tad over halfway on the factory gauge . I have not ckd with a temp gun or mechanical gauge yet....... But raise the hood and it definitely seems warmer then the Satellite does in same ambient temps
Ive already replaced thermostat with a high flow style
The car runs ok , But seems to run warmer the more you drive it.
Like sitting at light. it warms up a tad, but doesnt cool down once moving again . Like my Satellite does.
Timing is right , carb seems adjusted right .
I don't feel like it over heats ,,,,,, just would like to cool it down a tad . Especially before I get the air working here soon
Anyone ever used CLR to clean a radiator out?
Im thinking lay it on its back and fill it up, and just let soak for a bit. then flush and reinstall
Thoughts ???
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046226
05/29/22 06:28 PM
05/29/22 06:28 PM
Andrewh Offline
Andrewh  Offline
I don't know feeling warmer is a good guide.
I would want temp readings.
and temps creeping up at a light could be a few things. clutch if you are using one, water pump or fan not deep enough in the shroud.
but if you are going to flush, I think this might be a better choice.
https://www.evapo-rust.com/restore-your-engines-cooling-system/
someone recommended it to me and I got a couple qts to try, just got it today, but won't have time to try it for a week or two.
Re: Anyone ever used CLR to flush / clean a radiator [Re: Andrewh] #3046229
05/29/22 06:39 PM
05/29/22 06:39 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
No fan clutch as its direct drive. Fan blades are dead center in the shroud edge.
I was thinking pick up a decent mechanical gauge before doing anything to have a better baseline on actual temps
I tend to think if it was water pump it would cool down once moving again, at least a little bit.
My Satellite runs right at 180ish range with a Stewart components Tstat. Even on a 100 plus degree day even in traffic. It may warm up close to 200 at stops but cools right back down once moving. And the coronet feels warmer underhood than the Satellite does
When I first got the Satellite it would run warmer the more you drove it . And I did basically same thing. Flushed the radiator and block ( with garden hose and radiator in car ) Went with the stewart Components Tstat and it cured it
ps, the Satellite has an aftermkt mechanical gauge in it .
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046272
05/29/22 09:41 PM
05/29/22 09:41 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I've used Radiator Flush. I believe Prestone brand.
2011 Drag Pak Challenger
Re: Anyone ever used CLR to flush / clean a radiator [Re: rickseeman] #3046276
05/29/22 09:58 PM
05/29/22 09:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The usual questions apply:
What is the real coolant temp ? (mech gauge)
Hoses collapsing ? (observe running/hot)
Blockage in engine or radiator ? (water in = water out, test separately; for engine,with T-stat out)
Never thought of using CLR for a flush but in the past I've used the Prestone stuff.
Best is if you have a radiator shop clean it out (assuming there's one in your area).
Haven't had that issue for decades, since switching to distilled water w/Water Wetter and coolant.
But who knows what the prior owner did.
Re: Anyone ever used CLR to flush / clean a radiator [Re: topside] #3046287
05/29/22 10:43 PM
05/29/22 10:43 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I’ve never used clr.
I’ve had a few engines that kept pushing casting sand into the radiator. No matter what I used or how many flushes, it would just build up and need to be taken to a radiator shop. High speed blasts would break the crud loose soon after. Especially sustained interstate flat out runs…
I want my fair share
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046295
05/29/22 11:08 PM
05/29/22 11:08 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Originally Posted by gtx6970
Thoughts ???
My thought is: With so many radiator flush products on the market, what made you jump directly to CLR? Not trying to be critical, just curious...
Personally, I'd be afraid of the potential affects of un-tested chemicals (in CLR) on the gaskets/sealants they're going to come in contact with.
Re: Anyone ever used CLR to flush / clean a radiator [Re: Fat_Mike] #3046305
05/29/22 11:30 PM
05/29/22 11:30 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thoughts ???
Simple answer ....Was walking thru dept store and spotted the bottle. Thought.....will it clean a radiator internally.?????
Radiator will not be in the car . Im planning pull it and lay it on its back . Filling radiator only. Then flush several times becore reinstall in car.
I will head out tomorrow and pick up a mech gauge . Before doing anything but deep down have feeling its warm....at least warmer than i want ot to run
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046308
05/29/22 11:49 PM
05/29/22 11:49 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Radiator will not be in the car . I'm planning pull it and lay it on its back . Filling radiator only. Then flush several times before reinstall in car......
Oh...you said that but I assumed (I know) you meant a complete motor flush. On a bare radiator I don't think it could hurt.
Re: Anyone ever used CLR to flush / clean a radiator [Re: Fat_Mike] #3046325
05/30/22 12:18 AM
05/30/22 12:18 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
What I may do is drain refill and add flush/ cleaner . flush again,
then pull radiator and fill it will cleaner only and let it sit a while.
the flush it seperately.
resinstall and go for a drive
Right now, car has 1 gallon coolant, then filled with tap water. new 160 Stewart Components stat . No water wetter of any kind
And if I were a betting man would say its over 200 degrees. ( I will know tomorrow afternoon ) And I know some say thats not hot
But its to hot for my tastes
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046349
05/30/22 06:38 AM
05/30/22 06:38 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Oxalic acid has been considered a good flush for more than 50 years.
https://www.astm.org/stp25166s.html
The evaporust special gell certainly looks interesting,
maybe after a first oxalic acid cleaning?
A video boroscope “snake camera” to view interior passages after a flush seems logical,
since their price has come down so much,
and they have so many uses.
The smaller than 9 mm camera diameter is very handy.
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046350
05/30/22 06:43 AM
05/30/22 06:43 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill, I would check the radiator with an infrared heat gun all over the radiator and make sure it is even everywhere. My '68 RR would be fine and if you opened the cap and looked in you would think the radiator was perfect. Go for a stop and go drive and it would lose coolant after it heat soaked when you stopped. Took out the infrared heat gun and the whole right/passenger's side upper corner had no or lower temp and was completely clogged. Re-cored it and no problems. Make sure with a infrared heat gun the radiator doesn't have bad areas and the temp is even. (didn't read all of the posts so if this has been suggested, oops blush )
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046463
05/30/22 02:32 PM
05/30/22 02:32 PM
Quote
Make sure your mechanical gauge is accurate before trusting it scope
I've seen and had some expensive ones that weren't rant
The first one was a race large diameter320 degree reading face Autometer mechanical temp gauge with the sender plumbed into the water pump housing next to the upper radiator hose thermostat housing, it would read 140 F when the water flowing into the radiator was less than my body temps were shock down puke
The last street car I built had a Griffen copper and brass cross flow 4 core radiator that was a little shorter in height than the opening in the radiator support so some of the air would flow under it instead of all the air flowing through it realcrazy It would get hot, above 220F, driving in town and not cool down when driving it at or above 50 MPH on the highways whiney
I replaced it with a two core aluminum and it ran 165F in town and would cool down to 160F when slowing down on the highways on the off ramps boogie
The next summer it was back to running hotter so I had the radiator back flush at our local radiator shop and that fixed it for that year work
That motor was my first pump gas 400 stroker motor that ran on 91 octane pump gas here in Oregon. that motor made 612 HP at 5500 RPM before installed in the car, I used a low deck six pack intake with a set of 1970 440 automatic non CA carbs, that car, 1971 duster weighing 3450 Lbs. with me in it, exceeded my wildest expectations by running 10:69 at 124.+ MPH on Oregon pump gas with the air cleaner and full 3.0 inch exhaust system on the car with the Magna Flow 14x7 oval muffs, mounted behind the rear end the first time out boogie
if it runs between 180 and 220 F I wouldn't worry about that, if it runs hotter or cooler fix it up twocents
Re: Anyone ever used CLR to flush / clean a radiator [Re: 360view] #3046479
05/30/22 02:58 PM
05/30/22 02:58 PM
GMP440 Offline
GMP440  Offline
Once you have the radiator all flushed out I would get a radiator shroud if you don't have one and a thermostatic clutch fan. Both those will improve on the cooling.
Re: Anyone ever used CLR to flush / clean a radiator [Re: GMP440] #3046550
05/30/22 07:19 PM
05/30/22 07:19 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
It has a shroud.
And i picked up a mechanical gauge today.
Already verified its accuracy on the stovetop with thermostat before installing in car
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046561
05/30/22 07:59 PM
05/30/22 07:59 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Your engs.may have different water pump blade counts 6 vs 8 just a thought.
Re: Anyone ever used CLR to flush / clean a radiator [Re: 71GTX471] #3046606
05/30/22 09:59 PM
05/30/22 09:59 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i have used CLR to unclog heater cores in the car,pumped it back and forth with a drill powered pump,worked great,no problem
my ladder of success is missing some rungs
Re: Anyone ever used CLR to flush / clean a radiator [Re: rhad] #3046898
05/31/22 08:59 PM
05/31/22 08:59 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Update
Ive got the mech gauge on it .
Going in this morning temps ran right on the 160 thermostat. Ambient temps were in the 60s
Coming home in town driving it got to about 180ish, ambient temps were mid 90s
Once on the interstate temps crept up to the mid 190s range.
once off the hiway it cooled back down slightly to about 185ish
This is with a Stewart Components 160 hi flow stat , 1 gallon prestone antifreeze and the rest filled with tap water . It has a fixed blade aftermkt aluminum fan and stock pulleys
I can see the fan itself causing temps to rise in town stop and go driving ,,,,,, but should make no difference on the interstate speeds . I dont know what blades the water pump has on it
I have not just let it sit and extended idle to see where it goes yet
My Satellite with this very thermostat runs right on the 160ish range as long as its moving. Temps will creep up on it slightly but as soon as its moving again it cools right back down pretty quick .
This Coronet doesnt seem to cool back down like the Satellite does once moving. thus why Im thinking radiator flow
Re: Anyone ever used CLR to flush / clean a radiator [Re: gtx6970] #3046906
05/31/22 09:45 PM
05/31/22 09:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill an infrared heat gun will tell you something about how your flow is through the radiator. It should be "approximately" the same all over if it is flowing properly and somewhat cooler at or near the return/bottom, just saying.
Re: Anyone ever used CLR to flush / clean a radiator [Re: A12] #3046909
05/31/22 10:07 PM
05/31/22 10:07 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Mike,
Im going to pull the ac condenser to ck the radiator like you mentioned. With the AC stuff in there . Im afraid theres not much room to get very accurate temp readings
Page 1 of 3 1 2 3
