Re: Need somebody to look at their 440 with ps and ac for me
[Re: fastmark]
#3046065
05/29/22 08:18 AM
05/29/22 08:18 AM
Posts: 5,918 ohio
ruderunner
ohio
The mangled hole appears to be square hole you'd put a ratchet into for tensioning the belt.
No bolt goes there.
Angry white pureblood male
[Re: ruderunner]
#3046197
05/29/22 03:42 PM
05/29/22 03:42 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
No bolt goes there. That's right
[Re: CYACOP]
#3046264
05/29/22 09:12 PM
05/29/22 09:12 PM
Posts: 10,222 Someplace you aren't
SomeCarGuy
Thanks guys
The pulley looks to be the same size as what is pictured here. It’s way to big to fit a correct for the car belt.
Would a Saginaw lump bolt up to the bracket I have? Did they make those in a similar style to the federal pump? The Saginaw s I had were all later and had the teardrop shape, not even close to a federal in look. Also there is a trw pump that from what I know has a similar shape to the federal.
I want my fair share
[Re: gtx6970]
#3046358
05/30/22 08:12 AM
05/30/22 08:12 AM
Posts: 6,426 Abilene, Texas
fastmark
Abilene, Texas
TRW , Saginaw and Federal pumps are take their own special mounting brackets Correct. Bouchillon sells the brackets and pulley. You can find them for sale here. I saw one on for b bodies only the other day. They run about $200 or less.
