Re: long ram manifolds
[Re: mgoblue9798]
#3045759
05/28/22 12:43 AM
05/28/22 12:43 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Mopar made three different lengths on the runners by removing the dividers between the runners, I think the last version used the shortest dividers As far as the power band I think they were all low RPM performers, under 4200 RPKM for peak HP and I think around 3200 to 3600 RPM for peak torque, maybe I'm wrong on the numbers so make sure and check them before deciding
[Re: mgoblue9798]
#3045760
05/28/22 12:47 AM
05/28/22 12:47 AM
Posts: 287 NW Illinois
MoonshineMattK
NW Illinois
I am considering buying a set to possibly use on my 440 in my truck.
Any idea if these require the use of special valve covers?
Would there be enough room to run a master cylinder and brake booster? Are you talking about the Chrysler 300 manifolds? If so I believe they require matching exhaust manifolds to heat the carb instead of the exhaust crossover.
[Re: MoonshineMattK]
#3045771
05/28/22 06:00 AM
05/28/22 06:00 AM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
What year truck?? I built a 440 Shortram motor,(same length as the long ram) and put it in my '81 W-150. You'll need to use a set of 60'e vintage valve covers, even the early 70's are to high and the rams won't clear. Also, you will probably have to ditch the brake booster and move the master cylinder. I moved mine 3" to the center and tied down the driver's side motor mount as it has 1/4" clearance. After telling you all the bad parts now the good. They make mind-blowing low-end torque. My motor is 9.2-1 with E-STREET heads and an MP.528 solid cam with Doug's 1-3/4" headers. It make 512ftlbs@2500 and 543ftlbs@3800. When choosing a cam for your motor err on the conservative side. The rams won't work with a big cam. The .528 was about as big as I dared go with shortrams. The carb pad will accept 500 CFM Edelbrocks , possibly 600's too but don't try and over carb the rams, Dave
[Re: mgoblue9798]
#3045877
05/28/22 12:58 PM
05/28/22 12:58 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Would there be enough room to run a master cylinder and brake booster? Like this...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3045884
05/28/22 01:23 PM
05/28/22 01:23 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Would there be enough room to run a master cylinder and brake booster? Like this... Yes exactly like that. Thanks for the pic. I scoured the web but could not find a pic myself. Is this your truck?
[Re: Cab_Burge]
#3045885
05/28/22 01:26 PM
05/28/22 01:26 PM
mgoblue9798
Atlanta, GA
Mopar made three different lengths on the runners by removing the dividers between the runners, I think the last version used the shortest dividers As far as the power band I think they were all low RPM performers, under 4200 RPKM for peak HP and I think around 3200 to 3600 RPM for peak torque, maybe I'm wrong on the numbers so make sure and check them before deciding You have a pretty good memory. The set I want are the long ram divided runners the entire length. 30" runner length including the intake runner in the head to the valve. They were tuned from the factory for torque between 2400 and 3200 rpm with the peak at 2800. Just about perfect for a truck motor that will actually be doing some light towing.
#3045886
05/28/22 01:30 PM
05/28/22 01:30 PM
mgoblue9798
Atlanta, GA
Would there be enough room to run a master cylinder and brake booster? Are you talking about the Chrysler 300 manifolds? If so I believe they require matching exhaust manifolds to heat the carb instead of the exhaust crossover. You are correct about the special exhaust manifolds if the heat feature is needed. I don't think I will have any icing problems in Atlanta GA.
[Re: quickd100]
#3045894
05/28/22 01:41 PM
05/28/22 01:41 PM
mgoblue9798
Atlanta, GA
What year truck?? I built a 440 Shortram motor,(same length as the long ram) and put it in my '81 W-150. You'll need to use a set of 60'e vintage valve covers, even the early 70's are to high and the rams won't clear. Also, you will probably have to ditch the brake booster and move the master cylinder. I moved mine 3" to the center and tied down the driver's side motor mount as it has 1/4" clearance. After telling you all the bad parts now the good. They make mind-blowing low-end torque. My motor is 9.2-1 with E-STREET heads and an MP.528 solid cam with Doug's 1-3/4" headers. It make 512ftlbs@2500 and 543ftlbs@3800. When choosing a cam for your motor err on the conservative side. The rams won't work with a big cam. The .528 was about as big as I dared go with shortrams. The carb pad will accept 500 CFM Edelbrocks , possibly 600's too but don't try and over carb the rams, Dave Thank you for the info. Truck is a 74 ext cab long bed 440 w/ 518. I am looking at the long ram manifolds that are divided the entire length of the runner. Cam will be 268 duration or smaller. I have a couple little 450 holleys from old 413 industrial motors and thought I might try those out. One thing I haven't been able to see from top side pics is how does the trans kick down linkage work? Would it be hard to fabricate without having the original parts? I am thinking a new style cable could be made to work but don't know for sure.
[Re: W.I.N. Racing]
#3045919
05/28/22 02:52 PM
05/28/22 02:52 PM
Cab_Burge
Would there be enough room to run a master cylinder and brake booster? Like this... This is living proof you can do anything you want on modifying motors in vehicles, if you have the skill and patience
[Re: Cab_Burge]
#3045923
05/28/22 03:22 PM
05/28/22 03:22 PM
Posts: 19,366 north of coder
moparx
the kick down linkage is an adjustable rod that is attached to the bellcrank. it runs to the back of the engine where it snaps onto the linkage going to the transmission. i may have a PDF of the log ram from a FSM on the other computer. i'll have to look. it shows all the adjustment procedures and the order in which to do them. i think this info is also on one of the "forward look" sites, but i can't recall which one.
[Re: mgoblue9798]
#3045965
05/28/22 05:49 PM
05/28/22 05:49 PM
W.I.N. Racing
Byron, NY
Would there be enough room to run a master cylinder and brake booster? Like this... Yes exactly like that. Thanks for the pic. I scoured the web but could not find a pic myself. Is this your truck? Yes from 1987...the long rams defiantly made more torque but a single Holley 800/Street Dominator intake made more HP (better Ets)
[Re: mgoblue9798]
#3046261
05/29/22 08:59 PM
05/29/22 08:59 PM
MoonshineMattK
NW Illinois
Would there be enough room to run a master cylinder and brake booster? Are you talking about the Chrysler 300 manifolds? If so I believe they require matching exhaust manifolds to heat the carb instead of the exhaust crossover. You are correct about the special exhaust manifolds if the heat feature is needed. I don't think I will have any icing problems in Atlanta GA. Reason I mentioned the exhaust heat. Years ago I blocked the heat crossover on an engine I planned to run year round. Ran poorly below 60°
[Re: mgoblue9798]
#3046298
05/29/22 11:11 PM
05/29/22 11:11 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Would there be enough room to run a master cylinder and brake booster? Are you talking about the Chrysler 300 manifolds? If so I believe they require matching exhaust manifolds to heat the carb instead of the exhaust crossover. You are correct about the special exhaust manifolds if the heat feature is needed. I don't think I will have any icing problems in Atlanta GA. You might be surprised. Carb icing isn't so much ambient temp related as it is humidity. Kevin
[Re: Twostick]
#3046330
05/30/22 01:07 AM
05/30/22 01:07 AM
Cab_Burge
[quote=MoonshineMattK][quote=mgoblue9798]I am considering buying a set to possibly use on my 440 in my truck. You might be surprised. Carb icing isn't so much ambient temp related as it is humidity. Kevin I learn that lesson while flying piston driven engine airplanes Manifold pressure starts dropping off along with the indicated air speed, slowly slowing down. Pull the carb heat and bingo everything got better
