Are all Wix oil filters created equal? #3045549
05/27/22 08:43 AM
05/27/22 08:43 AM
tboomer Offline OP
tboomer  Offline OP
The annual Mopar Max races and car show are coming up in June this year at Cedar Falls Motorsports Park. I am getting the old 64 ready to go if I can find a driver for test and tune. I thought I had a Wix racing oil filter in the garage but it turns out to be a Wix 85515 for Carquest. The box reads contents made in USA...So what is the difference between this filter and a Wix racing filter? Do you fellas think it is safe to use? Thanks!! Ted wave
Re: Are all Wix oil filters created equal? [Re: tboomer] #3045555
05/27/22 08:56 AM
05/27/22 08:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The R filter has larger filtering media. I've run both. Currently the standard filter after the rebuild. I figured it would catch finer debris. I'll go back to the R filer after break-in.
Doug
Re: Are all Wix oil filters created equal? [Re: tboomer] #3045557
05/27/22 09:02 AM
05/27/22 09:02 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
The standard filter 85515 filters to 21 microns and flows 7-9 gallons per min. the 85515r filters to 61 microns and flows 28 GPM.
Joe
Without Data, you’re just another guy with an opinion.
Re: Are all Wix oil filters created equal? [Re: sr4440] #3045569
05/27/22 09:58 AM
05/27/22 09:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
When I was still working, our preventative maintenance foreman toured a Wix filter plant. What he was told during the tour was that Wix makes privately labelled filters for others to their specifications. When our guy asked if that meant some are better than others, the factory rep just smiled and repeated that they are made to the customer's specifications. Take it for what it's worth.
Re: Are all Wix oil filters created equal? [Re: 6PakBee] #3045571
05/27/22 10:03 AM
05/27/22 10:03 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Use Baldwin. You'll be much happier with the quality when you pull one apart.
'63 Dodge 330
11.19 @ 121 mph
Re: Are all Wix oil filters created equal? [Re: 6PakBee] #3045581
05/27/22 10:32 AM
05/27/22 10:32 AM
Kirkland, Washington
Pacnorthcuda Offline
Makes ya wonder what the media difference might be between standard Wix filters (say the 51515) and the Napa Gold equivalent.
Re: Are all Wix oil filters created equal? [Re: Pacnorthcuda] #3045585
05/27/22 10:42 AM
05/27/22 10:42 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Probably nothing, that factory guy isn't going to tell everyone that they label the same filter for everyone. My .02.
The GPM flow difference between the R and standard filter is staggering. How much does a high volume R or LA oil pump flow?
68 Barracuda Formula S 340
Re: Are all Wix oil filters created equal? [Re: Bad340fish] #3045594
05/27/22 11:13 AM
05/27/22 11:13 AM
A727Tflite Offline
A727Tflite  Offline
What the engine will let the pump flow is the determining factor.
I believe all filters are normally rated without a restriction. Based on past tests I’m betting most engines won’t allow more than 5 gpm to pass through the system.
Re: Are all Wix oil filters created equal? [Re: A727Tflite] #3045600
05/27/22 11:31 AM
05/27/22 11:31 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Canister burst strength is more with race filter too ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Are all Wix oil filters created equal? [Re: Bad340fish] #3045602
05/27/22 11:36 AM
05/27/22 11:36 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Comparing the two filters, if one has a third of the filtering capacity, that translates into a third of the pressure drop so for a constant inlet pressure, three times the flow (roughly).
Re: Are all Wix oil filters created equal? [Re: 6PakBee] #3045639
05/27/22 01:04 PM
05/27/22 01:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
When I was searching for a filter for my race car, I called Mobile One support for the filters. I was shocked that the plant where Mobile One filters are made also made Wix and a bunch other makes of filters. That does not mean that they are all made the same though.
Re: Are all Wix oil filters created equal? [Re: tboomer] #3045707
05/27/22 07:23 PM
05/27/22 07:23 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
EngineMasters did a dyno shoot-out on oil filters last year. The Wix did real well. I have ran the 51515 for many years now. Never a problem.
Master, again and still
Re: Are all Wix oil filters created equal? [Re: DaveRS23] #3045710
05/27/22 07:34 PM
05/27/22 07:34 PM
New York, USA
Chargerfan68 Offline
New York, USA
The strange thing we noticed, when comparing the Wix 51515 to the Wix racing 51515R filter at the dyno ; the racing filter actually had Slightly SMALLER openingson the filter base plate. That did not make sense to us nor the dyno/shop owner.
Anyone have a clue as to why that would be?
Re: Are all Wix oil filters created equal? [Re: Chargerfan68] #3045711
05/27/22 08:03 PM
05/27/22 08:03 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
RE: higher burst pressure required a stronger base plate, easier to stamp smaller holes than make that part out of thicker metal shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Are all Wix oil filters created equal? [Re: metallicareload] #3045762
05/28/22 12:56 AM
05/28/22 12:56 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Ever see one fail?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Are all Wix oil filters created equal? [Re: BloFish] #3045822
05/28/22 10:45 AM
05/28/22 10:45 AM
tboomer Offline OP
tboomer  Offline OP
Great info guys! Thank you! I have blown the "O" ring out of a Wix racing filter years ago..Also seen a Wix racing filter let go on my friends 8 second Roadrunner..
Re: Are all Wix oil filters created equal? [Re: tboomer] #3045914
05/28/22 02:43 PM
05/28/22 02:43 PM
moparx Offline
moparx  Offline
i too have blown o-rings out of wix filters, but i was jacking around with pressure relief springs.
the only other wix problems i have had with using them for over 45 years, was a filter with no threads, and a filter missing the o-ring.
i buy them by the case [51515's] because they fit everything here.
unless they take a dump quality wise, i will keep on buying them.
beer
Re: Are all Wix oil filters created equal? [Re: dvw] #3045921
05/28/22 03:02 PM
05/28/22 03:02 PM
Doug
i have ran two and four remote mounted stock type oil filters in the past doing dyno testing looking for more power, no gain but it would suspire me that the added filters did more filtering than one up work shruggy
All the Mopar type oil filters have built in bypasses so they don't filter all the oil like some of the GM type filters due work
I tried using the 51515R for a short while and went back to the stock 51515 Wix filters do to Murphy loving messing with me every chance I give him work
40% less filtering on the R version work down twocents
I do set my oil bypass pressure to equal 10 lbs. of pressure for each 1000 RPM at the shift RPM,7000 RPM equals 70 lbs. Of pressure with hot oil at 7000 RPM up
Re: Are all Wix oil filters created equal? [Re: Bad340fish] #3046064
05/29/22 08:14 AM
05/29/22 08:14 AM
PA
moparacer Offline
moparacer  Offline
PA
That is because of the micron ratings effect on flow rates. You cant have your cake and eat it too with oil filters and race engines. Micron rating, flow rates, oil viscosity all are at play.
You can't, wait no, I should say you shouldn't, run any stock style oil filter on a race engine that sees high RPM due to the low micron rating and lower flow rates.
Just the same you shouldn't run a WIX racing filter on a street engine that see's thousands of miles either....
I run the WIX R filter on my engine. Reused the bearings when we had it apart over the winter....
I guess it works.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Are all Wix oil filters created equal? [Re: DaveRS23] #3046704
05/31/22 11:28 AM
05/31/22 11:28 AM
an8sec70cuda Offline
iagree Same here. I use the WIX 51515 or NAPA Gold 1515 on all our BB Mopars. No problems ever.
CHIP
'06 GMC 2500HD LBZ Duramax
