Re: Are all Wix oil filters created equal?
[Re: tboomer]
#3045555
05/27/22 08:56 AM
05/27/22 08:56 AM
Posts: 9,871 MI, usa
dvw
MI, usa
The R filter has larger filtering media. I've run both. Currently the standard filter after the rebuild. I figured it would catch finer debris. I'll go back to the R filer after break-in. Doug
[Re: tboomer]
#3045557
05/27/22 09:02 AM
05/27/22 09:02 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
The standard filter 85515 filters to 21 microns and flows 7-9 gallons per min. the 85515r filters to 61 microns and flows 28 GPM.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3045569
05/27/22 09:58 AM
05/27/22 09:58 AM
Posts: 10,752 North Dakota
6PakBee
North Dakota
When I was still working, our preventative maintenance foreman toured a Wix filter plant. What he was told during the tour was that Wix makes privately labelled filters for others to their specifications. When our guy asked if that meant some are better than others, the factory rep just smiled and repeated that they are made to the customer's specifications. Take it for what it's worth.
[Re: 6PakBee]
#3045571
05/27/22 10:03 AM
05/27/22 10:03 AM
Posts: 4,700 Wichita
GY3
Wichita
Use Baldwin. You'll be much happier with the quality when you pull one apart.
[Re: 6PakBee]
#3045581
05/27/22 10:32 AM
05/27/22 10:32 AM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
When I was still working, our preventative maintenance foreman toured a Wix filter plant. What he was told during the tour was that Wix makes privately labelled filters for others to their specifications. When our guy asked if that meant some are better than others, the factory rep just smiled and repeated that they are made to the customer's specifications. Take it for what it's worth. Makes ya wonder what the media difference might be between standard Wix filters (say the 51515) and the Napa Gold equivalent.
[Re: Pacnorthcuda]
#3045585
05/27/22 10:42 AM
05/27/22 10:42 AM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
Probably nothing, that factory guy isn't going to tell everyone that they label the same filter for everyone. My .02.
The GPM flow difference between the R and standard filter is staggering. How much does a high volume R or LA oil pump flow?
68 Barracuda Formula S 340
[Re: Bad340fish]
#3045594
05/27/22 11:13 AM
05/27/22 11:13 AM
Posts: 3,089 Michigan
A727Tflite
The GPM flow difference between the R and standard filter is staggering. How much does a high volume R or LA oil pump flow? What the engine will let the pump flow is the determining factor. I believe all filters are normally rated without a restriction. Based on past tests I’m betting most engines won’t allow more than 5 gpm to pass through the system.
[Re: A727Tflite]
#3045600
05/27/22 11:31 AM
05/27/22 11:31 AM
Posts: 34,942 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Canister burst strength is more with race filter too ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Bad340fish]
#3045602
05/27/22 11:36 AM
05/27/22 11:36 AM
6PakBee
North Dakota
The GPM flow difference between the R and standard filter is staggering. How much does a high volume R or LA oil pump flow? Comparing the two filters, if one has a third of the filtering capacity, that translates into a third of the pressure drop so for a constant inlet pressure, three times the flow (roughly).
[Re: 6PakBee]
#3045639
05/27/22 01:04 PM
05/27/22 01:04 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
When I was searching for a filter for my race car, I called Mobile One support for the filters. I was shocked that the plant where Mobile One filters are made also made Wix and a bunch other makes of filters. That does not mean that they are all made the same though.
[Re: tboomer]
#3045707
05/27/22 07:23 PM
05/27/22 07:23 PM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
EngineMasters did a dyno shoot-out on oil filters last year. The Wix did real well. I have ran the 51515 for many years now. Never a problem.
Master, again and still
[Re: DaveRS23]
#3045710
05/27/22 07:34 PM
05/27/22 07:34 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
The strange thing we noticed, when comparing the Wix 51515 to the Wix racing 51515R filter at the dyno ; the racing filter actually had Slightly SMALLER openingson the filter base plate. That did not make sense to us nor the dyno/shop owner.
Anyone have a clue as to why that would be?
[Re: Chargerfan68]
#3045711
05/27/22 08:03 PM
05/27/22 08:03 PM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Anyone have a clue as to why that would be? RE: higher burst pressure required a stronger base plate, easier to stamp smaller holes than make that part out of thicker metal
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: BloFish]
#3045822
05/28/22 10:45 AM
05/28/22 10:45 AM
Posts: 25,992 United Socialist States of Ame...
tboomer
Great info guys! Thank you! I have blown the "O" ring out of a Wix racing filter years ago..Also seen a Wix racing filter let go on my friends 8 second Roadrunner..
[Re: tboomer]
#3045914
05/28/22 02:43 PM
05/28/22 02:43 PM
Posts: 19,589 north of coder
moparx
i too have blown o-rings out of wix filters, but i was jacking around with pressure relief springs. the only other wix problems i have had with using them for over 45 years, was a filter with no threads, and a filter missing the o-ring. i buy them by the case [51515's] because they fit everything here. unless they take a dump quality wise, i will keep on buying them.
[Re: Bad340fish]
#3046064
05/29/22 08:14 AM
05/29/22 08:14 AM
Posts: 2,524 PA
moparacer
PA
The GPM flow difference between the R and standard filter is staggering. How much does a high volume R or LA oil pump flow? That is because of the micron ratings effect on flow rates. You cant have your cake and eat it too with oil filters and race engines. Micron rating, flow rates, oil viscosity all are at play. You can't, wait no, I should say you shouldn't, run any stock style oil filter on a race engine that sees high RPM due to the low micron rating and lower flow rates. Just the same you shouldn't run a WIX racing filter on a street engine that see's thousands of miles either.... I run the WIX R filter on my engine. Reused the bearings when we had it apart over the winter.... I guess it works.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: DaveRS23]
#3046704
05/31/22 11:28 AM
05/31/22 11:28 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
EngineMasters did a dyno shoot-out on oil filters last year. The Wix did real well. I have ran the 51515 for many years now. Never a problem. Same here. I use the WIX 51515 or NAPA Gold 1515 on all our BB Mopars. No problems ever.
