Re: need to replace my garage door opener [Re: mopars4ever] #3043871
05/20/22 11:48 AM
05/20/22 11:48 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I put in a LiftMaster last year and love it.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: need to replace my garage door opener [Re: BloFish] #3043970
05/20/22 05:39 PM
05/20/22 05:39 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I put a 2 car garage addition on 20+ years ago. At that time I grabbed a Genie from HD and put it up. Worked fine until this year, then it died. I had the door company that installed the door come out and install a belt drive Liftmaster. Works great and quiet...uses the same MyQ app so wireless, remote function. I don't need battery backup...if I lose power,pull the cord and roll the door up. Think it was $400 completely installed with haul away of the Genie.
Re: need to replace my garage door opener [Re: Dcuda69] #3045534
05/27/22 06:17 AM
05/27/22 06:17 AM
United Kingdom
drenatyn Offline
drenatyn  Offline
United Kingdom
Swinging gates must not have a skewed post. The sashes must be level and open easily, without unnecessary effort. It is better if they hang on hinges with bearings.
The instructions for the drive usually have a graph of the ratio of the length of the sash to its height. That's why the weight of the leaf is a relative indicator. In addition to the weight of the gate leaf, there is another important parameter: the sail and wind resistance. The higher this parameter, the harder it is for the drive to push the gate leaf, including strong winds. It's important which Garage Doors you choose. Very good if they are wood.
Re: need to replace my garage door opener [Re: Dcuda69] #3045580
05/27/22 10:23 AM
05/27/22 10:23 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
I got one at my old house and can’t wait to install at this one. These are great. Big power too. Had to get it because I did a complete reworking and changed out two wasted single bay width doors and went to a huge single door that weighed too much for the old openers.
The ability to have somebody put packages that arrive into your garage while on vacation is great. Even more so these days to when things ship on huge delays.
I want my fair share
Re: need to replace my garage door opener [Re: SomeCarGuy] #3045584
05/27/22 10:38 AM
05/27/22 10:38 AM
central il.
second 70 Offline
second 70  Offline
central il.
No need to change out working openers . You can upgrade your opener these are only $30 and fit most openers. Same IQ tech. Open and close door from anywhere. Young neighbors wanted to replace broken touch pad but I got them this instead. Works great and you can always check door anytime with your phone to see it it's open or closed.
Simple wifi install.
https://www.lowes.com/pd/Chamberlain-MYQ-SMART-GARAGE-CONTROL/5001920965
Re: need to replace my garage door opener [Re: second 70] #3045769
05/28/22 05:46 AM
05/28/22 05:46 AM
Port Huron, Michigan
MI_Custumz Online content
MI_Custumz  Online Content
Mine keeps saying offline at least once a week. I have to unplug it and plug it back in. Sucks if you are not home. I have a smart plug I can control from anywhere and plugged the MyQ into that. We will see if that works. Everyone said it's the wifi, but the wifi cameras are all fine.
Re: need to replace my garage door opener [Re: second 70] #3045779
05/28/22 07:13 AM
05/28/22 07:13 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
If it's a torsion spring door get a liftmaster 8500. Mounts on end of torsion shaft and gets rid of everything else leaving ceiling clean. Stu loved em. Hard to see but it's the small black box on left on wall behind bike. I have one on the 16ft front garage door too. Comes with a bluetooth light that plugs in where old opener was installed. I have both on same signal so when either door opens or you trip motion detector on wall panel the both come on together. Bright enough to go in and out of garage without turning on any lights. You can see it between the led fixtures.
I wish I would have done this wall mount style. I still may add eventually. As you can see, I use every square inch of my garage.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: need to replace my garage door opener [Re: 6PKRTSE] #3045815
05/28/22 10:23 AM
05/28/22 10:23 AM
boston mass-moving to long isl...
massdaytona Offline
massdaytona  Offline
that is one LARGE shaker....
Re: need to replace my garage door opener [Re: massdaytona] #3045816
05/28/22 10:28 AM
05/28/22 10:28 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Yea, I was gonna say that blue car may need medical attention. wave
STOP POTATO HATE!
Re: need to replace my garage door opener [Re: MI_Custumz] #3045849
05/28/22 11:42 AM
05/28/22 11:42 AM
central il.
second 70 Offline
second 70  Offline
central il.
WiFi signals can suck in some areas in the same room or have some interference messing them up and just moving your control to another outlet or location might fix your problem. It can drive you nuts when the signal is better outside than inside.
Re: need to replace my garage door opener [Re: second 70] #3045875
05/28/22 12:49 PM
05/28/22 12:49 PM
BDW Offline
BDW  Offline
After reading this thread, bought this on Amazon and its been working great, only $22.
Hated the feeling when I might have left the garage open, now I can check and open or close from my phone.
https://youtu.be/0gcyJC_WkRk
Re: need to replace my garage door opener [Re: BDW] #3046040
05/29/22 12:37 AM
05/29/22 12:37 AM
My wifi opener had a sticker on it saying not to use led bulbs. That might be messing with your signal.
Re: need to replace my garage door opener [Re: SomeCarGuy] #3046055
05/29/22 06:04 AM
05/29/22 06:04 AM
I don't have LED bulbs in the garage door opener, but there are LED's in the other light fixtures in the garage. I truly think it's the camera I have causing interference. Every since I put it in the garage, the remote distance has decreased. I'm fine with that since I want a camera in the garage. I see the wifi garage door opener adaptor as a luxury and not a need, so if it works most of the time that's cool too.
