Re: Did it run an 8?
[Re: dvw]
#3042796
05/16/22 12:08 PM
05/16/22 12:08 PM
Posts: 16,790 Western NC
440Jim
Western NC
I would say that was a successful first day at the track with the new setup. You did some work, but earned the reward with it getting better as you went.
Keep it up. You will get the 8 second time slip.
1993 Daytona, 1973 Cuda 440, 2009 Challenger 5.7 Hemi, 2015 RAM 1500 5.7 Hemi 8-speed auto, Link to 572 B1 - Part 1
[Re: n20mstr]
#3042850
05/16/22 04:06 PM
05/16/22 04:06 PM
Posts: 9,252 MI, usa
dvw
MI, usa
The Chute may be coming next. Its has touched 150 mph on a couple of passes. Best ET was 9.005. But in better air with a little tail wind. It uses one XS 16 volt battery. Previously it had 2 Optima's. The single 16 volt works much better. We'll be out again Memorial weekend. Bigger jets, looser front shocks. Doug
[Re: dvw]
#3042870
05/16/22 05:02 PM
05/16/22 05:02 PM
Posts: 11,560 Portage,michigan
B3422W5
Portage,michigan
The Chute may be coming next. Its has touched 150 mph on a couple of passes. Best ET was 9.005. But in better air with a little tail wind. It uses one XS 16 volt battery. Previously it had 2 Optima's. The single 16 volt works much better. We'll be out again Memorial weekend. Bigger jets, looser front shocks. Doug You gonna be at 131? That will be my first time out..new heads and intake
69 Dart GTS A4 Silver All steel, flat factory hood, 3350 race weight 418 BPE factory replacement headed stroker Best so far, 10.68 at 124.48 1.44 best 60 foot. 6.76 at 101.63 best 1 /8
[Re: A39Coronet]
#3043027
05/17/22 10:40 AM
05/17/22 10:40 AM
Posts: 18,792 Las Vegas
Al_Alguire
Las Vegas
Congrats on getting it out there and on he runs. *'s will be a snap now. It was certain hot ans sticky in the middle of the country this weekend. Was really nasty weather in St Louis for sure for us.
[Re: A39Coronet]
#3043072
05/17/22 12:17 PM
05/17/22 12:17 PM
dvw
MI, usa
Doug what RPM do you shift at/cross the stripe?
I'd imagine you'll be well into 8.90s come fall weather so it's just a matter of time. Usually try 6900-7000. The shift light was acting up so there were some over or under. At 149 right about 7300. It's got a 7400 chip. and didn't sound like it tagged it. Doug
[Re: dvw]
#3043263
05/18/22 09:16 AM
05/18/22 09:16 AM
Posts: 19,313 State of confusion
Thumperdart
State of confusion
I'll say from personal experience lately that I found down leg boosters to make way more power if the main body's aren't on the big side to make up for the "choke" and in a single application a customer went from 10.77 to 10.40 with no other changes in Vegas......
[Re: mopar dave]
#3043275
05/18/22 10:06 AM
05/18/22 10:06 AM
B3422W5
Portage,michigan
Congrats. How was the track prep? I see they made some more improvements. I will be heading up there sometime before july. Track prep is generally good there. Track is a bit bumpy, but not bad. Frankly, it isn’t 131, but the new concrete walls and fresh staging lane pavement was definitely an upgrade Where exactly do you live, Dave?
