glide vs manual opinions #3043086
05/17/22 02:18 PM
05/17/22 02:18 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Hi Guys,
Kind of at an impasse on a build and I've read a ton on this but still want to get opinions of people out printing slips.
The car:
'66 Chevy II- 4link rear/coil over front/ lot of fiberglass 2700ish lbs depending on who's driving
has mild 406" street strip engine now- will have heavy-effort 393" built over the winter.
currently 5.14 gears with 31x14x15 rears
I think we were really leaning toward the Gforce G101A clutch-assisted trans. There's been occasional thoughts too of running a 'glide instead. This car wont be a bracket car, it will be run primarily at events down at the Grove, and maybe in the Midwest Gassers. In reality, it will probably see the track 6-10 times a year and will also put in some limited street time. Just crunching numbers, the auto route with good converter should come in a touch cheaper, and less room built in for driving errors. But, I'm really worried about the automatic really limiting the chances of breaking into the 8s with this combo. Then there's the balancing act of I don't want a #$% ton of maintenance to do either over the long haul.
More than anything, just gauging opinions here of Guys who have taken both routes in the same car and what your experiences were/are.
I posted this on Yellowbullet as well. I know its a Bowtie, but I've learned from a ton from many of you on here reading over the years and the timing clocks don't care what brand it is.
Re: glide vs manual opinions [Re: mopar873] #3043094
05/17/22 02:58 PM
05/17/22 02:58 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
The manual will take a bit more setup and maintenance but man it would be a blast. My big question you mention in your post is how streetable is a true race clutch? I heard you can't really slip them at all - it is "in or out". That could be tough on the street.
Re: glide vs manual opinions [Re: BigBlockGTS] #3043098
05/17/22 03:14 PM
05/17/22 03:14 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A Glide is definitely the "Easy Button". If you have never had a dedicated stick car that you drag race, there is a learning curve, and you need to realize, what works for an automatic, doesn't translate to a stick always. As for street driving with a race clutch, it can be done, but you can't lay into the throttle, like a normal clutch.
69 GTX 68 Road Runner
Re: glide vs manual opinions [Re: BigBlockGTS] #3043100
05/17/22 03:17 PM
05/17/22 03:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Stick car would be way more fun. Pro Stick races are cool. And those guys will be helpful as well.
Car set up is different. Manual car will require better parts, better shocks, etc. Clutchless is a better option if you have the budget. Not streetable easily though.
The old, parts breaking "light switch" clutches are old school. Now it's controlled slippage and management of the tires in the bellhousing. Get it right and it's not high maintenance, relatively speaking.
Re: glide vs manual opinions [Re: JERICOGTX] #3043101
05/17/22 03:18 PM
05/17/22 03:18 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Good points, the fastest stick car I ever had was a high 11 car, but I could drive that one to work every day if i wanted.
Re: glide vs manual opinions [Re: mopar873] #3043107
05/17/22 03:38 PM
05/17/22 03:38 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
3400#. G-Force GF2000. Low to mid 9s. Low 1.30 60'. Repeats like a dragster on tracks other guys can't get down. Will go into the 1.20s in 60' if he gets after it in the bellhousing. Pretty low maintenance. Car has good stuff in it.
A Racepak is almost a necessity to making that happen.
Re: glide vs manual opinions [Re: CMcAllister] #3043112
05/17/22 03:56 PM
05/17/22 03:56 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
It sure makes life easier.
Re: glide vs manual opinions [Re: JERICOGTX] #3043115
05/17/22 04:05 PM
05/17/22 04:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
It quickly pays for itself.
Re: glide vs manual opinions [Re: CMcAllister] #3043214
05/18/22 12:56 AM
05/18/22 12:56 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Every glide I have ever run needed at least a 5200 stall to work properly on the strip. My RED ran 7.8 and needed 5600 stall. Don’t think it that much stall will be street friendly. You will be generating a lot of trans heat.
Re: glide vs manual opinions [Re: mopar873] #3043216
05/18/22 03:43 AM
05/18/22 03:43 AM
Have you had a car like this with stick tranny and a manual clutch?
If not maybe do some more research on the maintenance and costs to run one.
I tried racing a 4 sped hemi 1970 Cuda in NHRA stock class years ago, lots of maintenance, lots and lots wrench puke
With todays clutches it may not be that bad but the glide is way easier to race and maintain, my S/P car has one and it is great, way better than a heavy 4 or 5 speed to race and maintain.
Don't get me wrong, I love 4 speed cars, I have one now, original 1969 Dart GTS 383 4 speed car that I don't drive very often due to worrying about someone running into it on the streets or someone scratching leaning over it or rubbing on it while trying to talk about a car they use to have like it shruggy
Re: glide vs manual opinions [Re: Cab_Burge] #3043243
05/18/22 09:00 AM
05/18/22 09:00 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
I haven'h had a manual in the single digits, but you're right...everything I've researched gives me a good idea of how much setup and maintenance is involved, not to mention the increased chance of breakage.
Re: glide vs manual opinions [Re: mopar873] #3043251
05/18/22 09:43 AM
05/18/22 09:43 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I have been thinking going to a manual also. Like you I run 6-10 times a year my car runs high 9s. For me the cost is a bit much. I have a basic RMVB 904 that I built for $800 plus $700 for conv.I called Gforce and a G101A clutch-assisted trans with shifter is $5K. Then clutch,bell and driveshaft then getting it into the car.
I still might do it in the future.
