Re: Did it run an 8? [Re: dvw] #3042796
05/16/22 01:08 PM
05/16/22 01:08 PM
NC
440Jim Offline
440Jim  Offline
NC
I would say that was a successful first day at the track with the new setup.
You did some work, but earned the reward with it getting better as you went.
Keep it up. You will get the 8 second time slip.
Re: Did it run an 8? [Re: 440Jim] #3042844
05/16/22 04:52 PM
05/16/22 04:52 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
how many batteries in the car??? shruggy
just saying....... grin
whistling
....BAD A$$ STREET CAR.....
Re: Did it run an 8? [Re: n20mstr] #3042850
05/16/22 05:06 PM
05/16/22 05:06 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The Chute may be coming next. Its has touched 150 mph on a couple of passes. Best ET was 9.005. But in better air with a little tail wind. It uses one XS 16 volt battery. Previously it had 2 Optima's. The single 16 volt works much better. We'll be out again Memorial weekend. Bigger jets, looser front shocks.
Doug
Re: Did it run an 8? [Re: dvw] #3042870
05/16/22 06:02 PM
05/16/22 06:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Doug
You gonna be at 131?
That will be my first time out..new heads and intake
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Did it run an 8? [Re: dvw] #3042948
05/17/22 06:29 AM
05/17/22 06:29 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Doug what RPM do you shift at/cross the stripe?
I'd imagine you'll be well into 8.90s come fall weather so it's just a matter of time.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Did it run an 8? [Re: A39Coronet] #3043027
05/17/22 11:40 AM
05/17/22 11:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Congrats on getting it out there and on he runs. *'s will be a snap now. It was certain hot ans sticky in the middle of the country this weekend. Was really nasty weather in St Louis for sure for us.
Re: Did it run an 8? [Re: A39Coronet] #3043072
05/17/22 01:17 PM
05/17/22 01:17 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Usually try 6900-7000. The shift light was acting up so there were some over or under. At 149 right about 7300. It's got a 7400 chip. and didn't sound like it tagged it.
Doug
Re: Did it run an 8? [Re: dvw] #3043260
05/18/22 10:10 AM
05/18/22 10:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Congrats. How was the track prep? I see they made some more improvements. I will be heading up there sometime before july.
Re: Did it run an 8? [Re: dvw] #3043263
05/18/22 10:16 AM
05/18/22 10:16 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'll say from personal experience lately that I found down leg boosters to make way more power if the main body's aren't on the big side to make up for the "choke" and in a single application a customer went from 10.77 to 10.40 with no other changes in Vegas......
Re: Did it run an 8? [Re: dvw] #3043273
05/18/22 10:53 AM
05/18/22 10:53 AM
MI, Livingston
P
plymth70 Offline
plymth70  Offline
P
MI, Livingston
did Scott bring the charger?
Re: Did it run an 8? [Re: mopar dave] #3043275
05/18/22 11:06 AM
05/18/22 11:06 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Track prep is generally good there. Track is a bit bumpy, but not bad.
Frankly, it isn’t 131, but the new concrete walls and fresh staging lane pavement was definitely an upgrade
Where exactly do you live, Dave?
1.41 best 60 foot
6.56 at 104.17
Re: Did it run an 8? [Re: B3422W5] #3043297
05/18/22 12:33 PM
05/18/22 12:33 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Only part of the track that is spooky is the seam in the right lane in the shut down area. I avoid it. Track prep was no issue. Scott didn't bring the Red Eye. We used his truck due to his fuel allowance. I put him to work.
Doug
Re: Did it run an 8? [Re: dvw] #3043309
05/18/22 01:19 PM
05/18/22 01:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Great pictures Doug!
69 GTX 68 Road Runner
Re: Did it run an 8? [Re: B3422W5] #3043509
05/19/22 08:55 AM
05/19/22 08:55 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Over by Clio, Mt.Morris area close to Flint.
