dana 60 bearing problem #3040808
05/08/22 06:46 PM
05/08/22 06:46 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
is there a better way to keep the axle bearing from leaking oil out of them,i replaced the bearing with the green bearings after a while they start to leak again?
Re: dana 60 bearing problem [Re: duspan] #3040812
05/08/22 06:51 PM
05/08/22 06:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
do you have the inner seals ? put sealant on the od of them if you install new ones
Re: dana 60 bearing problem [Re: CSK] #3040828
05/08/22 08:04 PM
05/08/22 08:04 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
This ^ and is the housing vent present and working?
Re: dana 60 bearing problem [Re: GomangoCuda] #3040848
05/08/22 09:37 PM
05/08/22 09:37 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Is this a street strip or race only car ? How much lube in the diff ?
Re: dana 60 bearing problem [Re: DavidDean] #3041278
05/10/22 06:04 PM
05/10/22 06:04 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
it is a street / strip car it has the special rear cover from strange that has the bolts that go against the main caps
Re: dana 60 bearing problem [Re: duspan] #3041369
05/11/22 02:57 AM
05/11/22 02:57 AM
Take it out for a long cruise and when you bring it home pull the fill plug while it is still hot from driving and let the hot lube drain out into a pan. Once it stops dripping COMPLETLY put the plug back in and see if that fixes the leak from the wheel bearing.
Does it leak from both sides or only one side?
Re: dana 60 bearing problem [Re: Cab_Burge] #3041470
05/11/22 12:43 PM
05/11/22 12:43 PM
moparx Offline
moparx  Offline
still need to know if the vent is present and working ? shruggy
beer
Re: dana 60 bearing problem [Re: moparx] #3041801
05/12/22 02:57 PM
05/12/22 02:57 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
the vent cap is working took it out put some air thru it no problem the cap moves easy
Re: dana 60 bearing problem [Re: duspan] #3041978
05/13/22 11:55 AM
05/13/22 11:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what about the axle seals in the tubes , are they still there ?
Re: dana 60 bearing problem [Re: duspan] #3041993
05/13/22 01:45 PM
05/13/22 01:45 PM
moparx Offline
moparx  Offline
beer
Re: dana 60 bearing problem [Re: moparx] #3042585
05/15/22 07:12 PM
05/15/22 07:12 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
the oil leaking past the sealed green bearings
Re: dana 60 bearing problem [Re: duspan] #3042589
05/15/22 07:20 PM
05/15/22 07:20 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Have the diff been narrowed? As asked before, how much lube are u adding?
