Re: 563ci build specs, what will it make?
[Re: JERICOGTX]
#3042761
05/16/22 11:29 AM
05/16/22 11:29 AM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
I'd have to guess it'd make a metric $#!+ - of horsepower with a sizeable pantload of torque.
Sure looks good. Are you going to break some hearts and grind off the logo on the belt drive?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3042777
05/16/22 12:09 PM
05/16/22 12:09 PM
Posts: 10,091 MN
JERICOGTX
MN
Are you going to break some hearts and grind off the logo on the belt drive? No. It gets covered enough by the engine plate, and water pump. I'll break hearts by painting an aluminum block...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042784
05/16/22 12:22 PM
05/16/22 12:22 PM
ZIPPY
S.E. Michigan
True to form, then. I love the overall look with the painted parts, and all the extra work you put in. Really sets it apart.
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#3042799
05/16/22 01:21 PM
05/16/22 01:21 PM
Posts: 16,936 NC
440Jim
NC
Primary tubes are 39” long. They step up from 2.125-2.250 after 6 “ from the header flange. I basically copied my Hooker 5209 headers, when I built them, only these actually fit the car without a hammer. What headers will be used on the dyno? Those are pretty long, IMO. I do like the short length of 2.125 tubes. I made mine with 8” of 2.125” and 21” of 2.250” for a total 29” length.
[Re: 440Jim]
#3042804
05/16/22 01:38 PM
05/16/22 01:38 PM
Posts: 10,091 MN
JERICOGTX
MN
We will make the first pulls with Hooker 5209 headers, then switch over to the headers I built. I basically copied the 5209 headers when I built them.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042835
05/16/22 04:24 PM
05/16/22 04:24 PM
Posts: 16,936 NC
440Jim
NC
Very nice looking headers. I wasn't sure if the Hooker car headers would fit around the dyno you will use. I look forward to the performance comparison.
[Re: Streetwize]
#3042914
05/16/22 09:38 PM
05/16/22 09:38 PM
Posts: 10,091 MN
JERICOGTX
MN
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042917
05/16/22 09:47 PM
05/16/22 09:47 PM
Posts: 10,081 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now. I am guessing stick cars like a little earlier c/l?. Plenty of duration.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#3042949
05/17/22 06:31 AM
05/17/22 06:31 AM
Posts: 10,091 MN
JERICOGTX
MN
I'd put the cam in earlier unless you're tire limited. I'd guess about 870-880 hp I let my machinist pick out the cam. He wants the cam set 107-108, which is where it’s at now. I am guessing stick cars like a little earlier c/l?. Plenty of duration. No clue. I wish I understood camshafts more. About a year ago, he built a 572 Mopar with 572-13 heads, and it made 1000hp. I didn't see any reason for him to not pick out the cam.
69 GTX
68 Road Runner
[Re: dvw]
#3042956
05/17/22 07:20 AM
05/17/22 07:20 AM
Posts: 10,091 MN
JERICOGTX
MN
Doug, bore is 4.524. Previous owner of the block just had it cleaned up enough, and ordered custom pistons for it. When I got the block, it had broke a rod bolt on the 202 pass, since being refreshed. It was in a dragster, that only ran 1/8 mile. The block came with 6 good pistons, so I only had to order two from Diamond. I tried to keep this on somewhat of a budget, so I used what I had, and worked around it.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042969
05/17/22 08:11 AM
05/17/22 08:11 AM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Well if it's 111 and in at 107 it's plus 4 where I thought it was put in straight-up (@ 111 ATDC) which for a non efi car seems late.
[Re: Streetwize]
#3042986
05/17/22 09:24 AM
05/17/22 09:24 AM
Posts: 10,091 MN
JERICOGTX
MN
Checking the cam installed straight up, it came to 102. I had all I could do to get it to 109, but after talking with the machinist, he wanted it around 107-108. It's at 108 right now.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042993
05/17/22 09:42 AM
05/17/22 09:42 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#3042998
05/17/22 10:02 AM
05/17/22 10:02 AM
Posts: 10,091 MN
JERICOGTX
MN
My goal is 850hp. Anything over is a bonus. Anything less, is what it is.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3042999
05/17/22 10:07 AM
05/17/22 10:07 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
My goal is 850hp. Anything over is a bonus. Anything less, is what it is. I'm no dyno guy, but I'll say I think you're gonna be happy w/ it!
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3043004
05/17/22 10:27 AM
05/17/22 10:27 AM
Posts: 10,091 MN
JERICOGTX
MN
My goal is 850hp. Anything over is a bonus. Anything less, is what it is. I'm no dyno guy, but I'll say I think you're gonna be happy w/ it! I've lowered my expectations enough to just live with what ever happens.
69 GTX
68 Road Runner
