Re: Pretty sure my converter died
[Re: dvw]
#3046681
05/31/22 09:33 AM
05/31/22 09:33 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
In all my years doing 727's I've only ever seen one set of pump gears break. Not sure of the cause. But it's not very common in my eyes. Doug Not common at all….. other than lucky me and the original poster I can’t even recall ever reading another thread here on the subject. BUT….. it must happen after all they make a “better” piece.
[Re: dvw]
#3046682
05/31/22 09:34 AM
05/31/22 09:34 AM
Posts: 3,076 Michigan
A727Tflite
In all my years doing 727's I've only ever seen one set of pump gears break. Not sure of the cause. But it's not very common in my eyes. Doug Over 50 years for me, same findings. One thing that changed was the cut in the converter impeller hub, that helped prevent edge loading on the rotor lugs.
[Re: rickraw]
#3046823
05/31/22 05:27 PM
05/31/22 05:27 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A&A has them, 4340 steel inner and stock outer. Pricey, 250 At my age if it saved me from pulling my transmission it would be well worth it. Lol.
[Re: pittsburghracer]
#3046825
05/31/22 05:30 PM
05/31/22 05:30 PM
Posts: 3,395 Pa
Hot 340
Pa
A&A has them, 4340 steel inner and stock outer. Pricey, 250 At my age if it saved me from pulling my transmission it would be well worth it. Lol. Truth John, truth
