It's alive #3041405
05/11/22 08:32 AM
05/11/22 08:32 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Nearly a year after kicking a rod thru the pan. Parts hold ups. Welding the block, heads, and pan. A few upgrades that required fabrication. Fired up in a 1/2 revolution. Idle oil pressure is up with new lifter bore bushings. Crank scraper installed at .060" clearance. Cam backed up from 108 to 111. 5/8" studs in the axles. Fresh trans, shocks, slicks. Carbon hood is painted. Test on Friday.
Doug
Re: It's alive [Re: dvw] #3041411
05/11/22 08:58 AM
05/11/22 08:58 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Why did you move the cam? Calm down the launch?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: It's alive [Re: dvw] #3041419
05/11/22 09:33 AM
05/11/22 09:33 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Doug
looks great Doug. hope it runs well.
Re: It's alive [Re: 572B1] #3041421
05/11/22 09:48 AM
05/11/22 09:48 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looking forward to hearing the results Doug. Best of luck!
69 GTX 68 Road Runner
Re: It's alive [Re: JERICOGTX] #3041422
05/11/22 09:50 AM
05/11/22 09:50 AM
Chesterfield Twp. Mi.
John Burdine Offline
What are you using for front shocks now?
Re: It's alive [Re: John Burdine] #3041425
05/11/22 10:08 AM
05/11/22 10:08 AM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
Looks great as ever
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: It's alive [Re: dvw] #3041428
05/11/22 10:25 AM
05/11/22 10:25 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Misfit world is complete - Looks good!
Re: It's alive [Re: dvw] #3041432
05/11/22 10:39 AM
05/11/22 10:39 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looks exactly the same (perfect)! Welcome back.
Rich H.
Esse Quam Videri
Re: It's alive [Re: ZIPPY] #3041438
05/11/22 11:07 AM
05/11/22 11:07 AM
K
Kiddart Offline
Kiddart  Offline
K
Awesome, looks killer as always!!!! cant wait to see you run
Thank you
Kiddart
Re: It's alive [Re: Kiddart] #3041441
05/11/22 11:29 AM
05/11/22 11:29 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
What's the 411 on those carbs?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: It's alive [Re: Brad_Haak] #3041448
05/11/22 11:44 AM
05/11/22 11:44 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
So clean!
Jealous.
'63 Dodge 330
11.19 @ 121 mph
Re: It's alive [Re: GY3] #3041460
05/11/22 12:22 PM
05/11/22 12:22 PM
an8sec70cuda Offline
VERY nice!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: It's alive [Re: dvw] #3041475
05/11/22 12:50 PM
05/11/22 12:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
SO NICE !!!
AND EXPECTING SOME 8.XX ETS SOON !! up
nO BETTER FEELING THAN A FRESH START LIKE THAT...... up
....BAD A$$ STREET CAR.....
Re: It's alive [Re: n20mstr] #3041478
05/11/22 12:52 PM
05/11/22 12:52 PM
moparx Offline
moparx  Offline
my favorite car here ! up bow
i hope it works as expected !
beer
Re: It's alive [Re: moparx] #3041481
05/11/22 01:00 PM
05/11/22 01:00 PM
PA
moparacer Offline
moparacer  Offline
PA
Great news! You car is a work of art.....
Interesting you retarded your cam too. I did a few weeks ago and it picked mine up.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: It's alive [Re: moparacer] #3041520
05/11/22 02:32 PM
05/11/22 02:32 PM
tboomer Online work
tboomer  Online Work
Nice job Doug!! wave The attention to detail on your car is amazing! bow
Re: It's alive [Re: tboomer] #3041525
05/11/22 02:49 PM
05/11/22 02:49 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Awesome!
Re: It's alive [Re: dvw] #3041533
05/11/22 03:09 PM
05/11/22 03:09 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Your car amazes me every time I see pictures of it. Hopefully the changes result in a nice result.
Re: It's alive [Re: dvw] #3041550
05/11/22 03:50 PM
05/11/22 03:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Very COOL !!!!!
Re: It's alive [Re: tboomer] #3041564
05/11/22 04:39 PM
05/11/22 04:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
^^^ This ^^^
One of my favorite cars, period!
