No turn signal or flashers #3041018
05/09/22 05:17 PM
05/09/22 05:17 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Just noticed that I have no flashers or turn signals on my 69 GTX. Suggestions?
Re: No turn signal or flashers [Re: mercman1] #3041029
05/09/22 06:02 PM
05/09/22 06:02 PM
Andrewh Offline
Andrewh  Offline
brake lights?
Re: No turn signal or flashers [Re: mercman1] #3041033
05/09/22 06:28 PM
05/09/22 06:28 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
turn signal switch on the steering wheel?
Might just need the terminals cleaned, might need to be replaced.
Re: No turn signal or flashers [Re: 1fastrunner] #3041037
05/09/22 06:57 PM
05/09/22 06:57 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
How much wiring did you eliminate to go drag racing?
With a car that old, I would suspect the turn signal switch needs attention, but then again, if it doesn't connect to anything, even a NOS one isn't going to work.
The 4 way and the turn signals are separate circuits, you need to test each one independently of each other. The only things they share is the turn signal switch (each has its own part in the turn signal switch) and the wiring to the bulbs and the bright filament on the bulbs
It could be as easy as a fuse, or flasher unit. I'd start with those, and make sure the simple stuff is good.
Re: No turn signal or flashers [Re: poorboy] #3041053
05/09/22 07:49 PM
05/09/22 07:49 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
idk if you car has a connector @the bottom of dash where steering column is attached. That connector is notorious for getting fouled. Take apart, spray with de-oxit and reconnect, repeat a few times.
Re: No turn signal or flashers [Re: srt] #3041058
05/09/22 08:01 PM
05/09/22 08:01 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
The car in question is the street car in the right lane.
When I restored it back in 98-99, I replaced every wire in the car with new harnesses from Year One.
So the running lights and brake lights work.
No turn signals or flashers.
Are the silver I think 3 prong flashers different for turn signals and flashers or are they interchangeable?
Thanks to all.
Re: No turn signal or flashers [Re: mercman1] #3041066
05/09/22 08:35 PM
05/09/22 08:35 PM
BDW Offline
BDW  Offline
Re: No turn signal or flashers [Re: BDW] #3041111
05/10/22 12:01 AM
05/10/22 12:01 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Don’t overlook the bulbs themselves. I had a funky deal, in my 69 GTX last week and it was the led bulbs I put in last fall. Internal short.
That’s kinda freaky you have two of the same cars like that.
I want my fair share
Re: No turn signal or flashers [Re: SomeCarGuy] #3041123
05/10/22 06:46 AM
05/10/22 06:46 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
LED turn signals require a matching LED flasher as well, correct?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: No turn signal or flashers [Re: A39Coronet] #3041145
05/10/22 09:00 AM
05/10/22 09:00 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Aren't flashers polarity sensitive?
That's why connectors only go on one way, check your wiring first.
Joe
Re: No turn signal or flashers [Re: A39Coronet] #3041151
05/10/22 09:45 AM
05/10/22 09:45 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
That would be my question as well
Abe Lincoln
Re: No turn signal or flashers [Re: dart4forte] #3041176
05/10/22 11:37 AM
05/10/22 11:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A regular flasher will work they just flash very fast. An electronic flasher is what is needed to make them flash correctly.
Re: No turn signal or flashers [Re: dart4forte] #3041178
05/10/22 11:45 AM
05/10/22 11:45 AM
central il.
second 70 Offline
second 70  Offline
central il.
I remember as a broke 16 year old I would just switch the hardly ever used flasher with the turn flasher to get turn signals to work and leave the flasher not working. So it's real possible that both flashers are bad and since most people don't use the flashers sometimes the only time they do is to check them when the turn signals stop working. Lol It's so easy just to plug a new flasher in and see if it works. The 1 on the fuse box is normally the flashers and the turn signal one is hidden up under dash.
Re: No turn signal or flashers [Re: mercman1] #3041212
05/10/22 01:43 PM
05/10/22 01:43 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Thanks to all.
'69 Plymouth Service Manual shows the square two terminal flasher for the hazzards and another for the turn signals.
The hazard fuse covers several circuits and is always hot.
If the dome light works and the stop light works, then there's power to the fuse.
The stop light circuit shares wire D31 from the Fuse to the connector fo the flasher unit. if the stop light works, power is getting that far.
Turn signals only get power when the key is in Run or Accessory. They have no fuse. The flasher serves as circuit breaker.
The places that both connect are the turn switch itself, and the turn switch connector. using a voltmeter you can check for power at the turn switch connector (steering column) and the hazzard connector.
Re: No turn signal or flashers [Re: Mattax] #3041332
05/10/22 09:35 PM
05/10/22 09:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks to all.
nice job mattax bow beer
Re: No turn signal or flashers [Re: A39Coronet] #3041357
05/10/22 11:34 PM
05/10/22 11:34 PM
SomeCarGuy Offline
SomeCarGuy  Offline
The ones I had were yorkim and didn’t require one. They flashed same as old school ones. Worked fine for awhile. Just more modern crap that isn’t made to last. They were awesome bright though. Three times more you could easily tell against the garage door looking back to back with old style. Wasn’t meant to be.
Re: No turn signal or flashers [Re: mercman1] #3041358
05/10/22 11:53 PM
05/10/22 11:53 PM
If it work before and is not working now I would look for corroded or a open, broken wire wrench up
Those are two separate circuits, the turn signal circuit fed off the ignition switch and the flashers are not, correct scope up
Re: No turn signal or flashers [Re: Cab_Burge] #3041671
05/11/22 10:40 PM
05/11/22 10:40 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Interesting side note is the company saw my review and contacted me today about making it right. Guess we’ll see what that means.
