dana 60 bearing problem
#3040808
05/08/22 06:46 PM
05/08/22 06:46 PM
Posts: 100 ma.
duspan
ma.
is there a better way to keep the axle bearing from leaking oil out of them,i replaced the bearing with the green bearings after a while they start to leak again?
Re: dana 60 bearing problem
[Re: duspan]
#3040812
05/08/22 06:51 PM
05/08/22 06:51 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
is there a better way to keep the axle bearing from leaking oil out of them,i replaced the bearing with the green bearings after a while they start to leak again? do you have the inner seals ? put sealant on the od of them if you install new ones
[Re: CSK]
#3040828
05/08/22 08:04 PM
05/08/22 08:04 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
is there a better way to keep the axle bearing from leaking oil out of them,i replaced the bearing with the green bearings after a while they start to leak again? do you have the inner seals ? put sealant on the od of them if you install new ones This ^ and is the housing vent present and working?
[Re: duspan]
#3041369
05/11/22 02:57 AM
05/11/22 02:57 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
Take it out for a long cruise and when you bring it home pull the fill plug while it is still hot from driving and let the hot lube drain out into a pan. Once it stops dripping COMPLETLY put the plug back in and see if that fixes the leak from the wheel bearing. Does it leak from both sides or only one side?
[Re: duspan]
#3041978
05/13/22 11:55 AM
05/13/22 11:55 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
the vent cap is working took it out put some air thru it no problem the cap moves easy what about the axle seals in the tubes , are they still there ?
