Help identifying splash shields from 68-69 B body #303963
04/30/09 07:11 PM
04/30/09 07:11 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Can any one identify where these go? they are off a 68 Coronet.
Think the C shaped ones are headlight seals.
The long one is an extruded piece - think this seals the metal splash shield to the fender by the door hinge.
What is the one by the plate?
What is the small straight one?
Thanks!
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Help identifying splash shields from 68-69 B body [Re: 71TA] #303964
04/30/09 08:01 PM
04/30/09 08:01 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
At least two of the Three on the right go in the front of the fender. On a 69, there is only the plastic shield bolted behind the headlight and the short flat one installed below it against the outer fender. The two on left go on the splash pan which is attached to the cowl and seals the area in front of the door
Re: Help identifying splash shields from 68-69 B body [Re: RoadRunnerJD] #303965
04/30/09 08:07 PM
04/30/09 08:07 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Splash pan?
Re: Help identifying splash shields from 68-69 B body [Re: RoadRunnerJD] #303966
04/30/09 10:53 PM
04/30/09 10:53 PM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
That sounds correct to me.
