More Cubes, More Power - What about the Torque Convertor? #3038888
05/01/22 08:19 PM
05/01/22 08:19 PM
Illinois
gearhead01 Offline OP
Illinois
Changes are coming for the Road Runner.
Hurt the crank/rods/bores last year, so I will be replacing the rotating assembly.
Current setup is 0.030 over 440, OOTB Eddy Heads, 0.557 Solid cam, M1 Intake/950 Holley. Drive train is a 727 with trans brake, 8" Turbo Action convertor, Ford 9 inch with 4.11 gears.
3600 pounds with me in the seat.. Runs 11.00 on 275 Drag Radials, 10.80 on slicks.
I am planning to bore it a little more, and 4.150 stroke to crowd 500 cubes.
So, I am expecting more power and torque.
Still debating a gear change (3.89), but my question is how is the small torque convertor going to work with the horsepower and torque changes? What will happen to the stall speed?
Any insights will be appreciated.
Thank you, John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3038889
05/01/22 08:33 PM
05/01/22 08:33 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The stall speed is obviously going to increase, depending on by how much, may require an adjustment.
Alan Jones
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3038909
05/01/22 09:30 PM
05/01/22 09:30 PM
AndyF Offline
AndyF  Offline
Stall speed will go up since you'll have more torque. If you are keeping the same top end (heads, cam, intake) then the power isn't going to increase much if any, but the torque will increase. By keeping the same top end but putting it on a bigger bottom end you'll run out of air faster. A gear change may be required depending on where it was running out of air before.
Switching to taller rear gears will make the stall even higher so you'll have to keep an eye on it.
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3038962
05/02/22 12:13 AM
05/02/22 12:13 AM
look at using the 4.25 stroke kits with 2.2 rod journal sizes and 7.100 long BB Chevy type H beam forged steel rods and pump gas pistons, more HP and more torque up scope
Maybe cheaper too work scope
That combination works real well boogie up
As far as the converter working with the new combination why not leave it alone until you try it with the new motor twocents
I have own and driven a bunch of different sizes and brand torque converters on the street and at the track.
The best one was a Turbo Action 8 inch Super Stock hemi automatic built for a NHRA SS/AH 1968 hemi Cuda race car, IT WAS GREAT on the street shock up And great at the track also boogie
The worst was a 10 inch Art Carr, street and strip, it was horrible down puke whiney
Re: More Cubes, More Power - What about the Torque Convertor? [Re: Cab_Burge] #3038974
05/02/22 03:49 AM
05/02/22 03:49 AM
gregsdart Offline
gregsdart  Offline
The best one was a Turbo Action 8 inch Super Stock hemi automatic built for a HRA SS/AH 1968 hemi Cuda race car, IT WAS GREAT on the street shock up And great at the track also boogie
I agree with Cab. Also that cam will be on the small side for a 500 inch motor.
A bit taller drag radial might work better instead of a gear change, if one will fit. You can add a fair amount of cam duration and with a little luck it might even come close to a match with the converter. If not, you will have some info for a stall change.
Re: More Cubes, More Power - What about the Torque Convertor? [Re: AndyF] #3039006
05/02/22 08:45 AM
05/02/22 08:45 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3039025
05/02/22 09:47 AM
05/02/22 09:47 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Stall will go up and slippage will likely increase.
Drag radials are typically quicker & faster than bias-ply slicks. Is your chassis not dialed in for radials, or are your slicks taller and allowing the car to pull more MPH --> lower ET? A 2 tenths difference in favor of the bias-ply slicks only makes sense to me if you're over-geared with a shorter drag radial, which is exactly what I ran into years ago switching between 275/60R15 DRs and 9.00 x 29.5 slicks. The car was .2 quicker and 2 MPH faster on the taller tires cuz I was over-revving it on the big end with the shorter radials.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: More Cubes, More Power - What about the Torque Convertor? [Re: Brad_Haak] #3039102
05/02/22 02:29 PM
05/02/22 02:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We run a really mild 11", 2800 stall RATED converter with a 3.54 gear behind our 505" stroker.
Still manages a 1.36 60 ft. on a small shot of spray. Usually mid 1.50's N/A.
'63 Dodge 330
11.19 @ 121 mph
Re: More Cubes, More Power - What about the Torque Convertor? [Re: GY3] #3039109
05/02/22 02:54 PM
05/02/22 02:54 PM
PA
moparacer Offline
moparacer  Offline
PA
What did it flash before? The stall is going to be higher but I bet it will be fine unless it was on the loose side with the 440. And IMHO many times over the years I have seen people size and stall converters too tight to begin with.
Like I always say loosen it up to the point you cant tell if the car shifted or not, then tighten it up a couple hundred, and roll with it... laugh2
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: More Cubes, More Power - What about the Torque Convertor? [Re: moparacer] #3039180
05/02/22 07:45 PM
05/02/22 07:45 PM
Illinois
Illinois
Thank you all for your knowledge.
Plan is for a larger cam - 0.600+ lift and more duration. I have not bought rotating assembly parts yet, so going a little bigger is still an option.
Slicks are 30.0/10.5R-15 - Hoosier radial slicks. I may not have to change gear ratio.
I have never put the convertor on stall, so I am not sure.
At this point, keeping the set-up the same is probably a good game plan. If it does not work, start with a convertor change after testing the stall on the current set-up.
Thanks again for your input.
John
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3039217
05/02/22 10:53 PM
05/02/22 10:53 PM
AndyF Offline
AndyF  Offline
Nice looking car. It is all related so if you change one thing you end up changing other things. If you consider that fun then you'll have lots of fun. If you hate working on the car then you'll hate all the work!
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3039218
05/02/22 10:53 PM
05/02/22 10:53 PM
gregsdart Offline
gregsdart  Offline
Great looking car, John! Good luck with it. 👍
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3039582
05/04/22 07:40 AM
05/04/22 07:40 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We moved from a 528 to a 572 and used the same converter that was originally built for the 528 by ATi. Rear gear / tire was also the same. The H/P difference was initially around 100hp, in favour of the 572. It worked fine, as has been said, we picked up 3-400 on the flash stall footbreaking the same. Going from 10.00 to mid 9's (135 - 142mph) the car put on some weight with the extra safety gear/ more cage and further mods. The converter was on the list to change but it worked good so it stayed.
HTH's up
Re: More Cubes, More Power - What about the Torque Convertor? [Re: Tig] #3039802
05/04/22 08:16 PM
05/04/22 08:16 PM
Illinois
Illinois
Thanks all for the comments.
I will give it a try with the current converter. If it does not work, not a lot of work to change it.
John
Re: More Cubes, More Power - What about the Torque Convertor? [Re: gearhead01] #3040905
05/09/22 07:55 AM
05/09/22 07:55 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
John
If you dont mind me asking, what is the part number on the Turbo Action Torque Converter? Just out of curiosity.
I agree with others who said keep running the same converter with the new combo. Everyone on my race team have gone from smaller cubic inch big block engines, to larger big block engines, and continued to ran the same Turbo Action converter with both combos. They worked just as good in the smaller engines as they do the big engines. We all run Turbo Action 8" opel converters. They are all fast and consistent.
