Does anybody have an OEM 426 STREET HEMI piston/pin on hand? #3039518
05/03/22 09:28 PM
05/03/22 09:28 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I am asking because I have an NOS set of street hemi pistons which I intend to use on a bone stock build, but I am missing the wrist pins.
I want to see if the correct sized 1.030" wrist pins are available as an off the shelf item, or if I would need to have a custom set of wrist pins ordered.
So, if you have a set of OEM street hemi pistons and pins please let me know what the wrist pin dimensions are. up
Also, I am missing 2 wrist pin retaining locks grin for my OEM street hemi pistons ..... if anybody cares to spare a pair..... wave
Re: Does anybody have an OEM 426 STREET HEMI piston/pin on hand? [Re: domingo] #3039526
05/03/22 10:00 PM
05/03/22 10:00 PM
VA
dragon slayer Offline
VA
You can find it in the service manual. 3.400" + or- .005" Length. 204 grams. 1.031-1.0312" Dia
Re: Does anybody have an OEM 426 STREET HEMI piston/pin on hand? [Re: dragon slayer] #3039543
05/03/22 11:27 PM
05/03/22 11:27 PM
Originally Posted by dragon slayer
You can find it in the service manual. 3.400" + or- .005" Length. 204 grams. 1.031-1.3012" Dia
Do you mean to post 1.031 to 1.032?
Re: Does anybody have an OEM 426 STREET HEMI piston/pin on hand? [Re: dragon slayer] #3039553
05/04/22 12:38 AM
05/04/22 12:38 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
My car had a 426 "crate" ? Hemi when I bought it. I've since rebuilt it as it was a complete slug.
The old wrist pins seem to match what dragon slayer posted.
You're welcome to them if you want them (and the pistons if you want them).
That being said, my unsolicited opinion is, even on a stock rebuild I would go with a modern piston/ring pack vs NOS/ancient.
Re: Does anybody have an OEM 426 STREET HEMI piston/pin on hand? [Re: dragon slayer] #3039615
05/04/22 09:47 AM
05/04/22 09:47 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the reply....but there is also an important dimension missing and that would be wall thickness. Hemi pistons are so heavy I guess the hemi pins will have thicker walls?
Re: Does anybody have an OEM 426 STREET HEMI piston/pin on hand? [Re: INTMD8] #3039616
05/04/22 09:47 AM
05/04/22 09:47 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
email sent!!!!! laugh
Re: Does anybody have an OEM 426 STREET HEMI piston/pin on hand? [Re: Cab_Burge] #3039813
05/04/22 09:16 PM
05/04/22 09:16 PM
VA
VA
Yes I did. Corrected post.
Wall thickness not given. But that is not critical if the pin is spec'd to a hemi. But I guess you could figure it out with density and the weight. Solve for thickness since you have the area measurements. grin
