Re: LOWERING BLOCKS
[Re: PARTSMAN440]
#303917
04/30/09 05:14 PM
04/30/09 05:14 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Lots of guys use them with no problem, but stay away from the parts store cheapie molded ones. I had a set of 2" blocks on a Charger I used to own and broke them in just a few passes(cheapie molded part store brand). Bought a set of hefty machined blocks from Speedway motors and they held up just fine. They were not completely solid, but still very ridgid by comparison.
2 kids and a dog
Re: LOWERING BLOCKS
[Re: PARTSMAN440]
#303919
04/30/09 05:38 PM
04/30/09 05:38 PM
Posts: 5,080 organ
maximum entropy
organ
i used the extruded ones, and they were not up to the task. i've since switched to the billet aluminum units. i got them from mancini. much better.
Re: LOWERING BLOCKS
[Re: maximum entropy]
#303920
05/01/09 10:07 AM
05/01/09 10:07 AM
Posts: 767 NW PA
V10nacuda
NW PA
Go with the solid ones with the STEEL locating pins. Had a truck & Duster lowered with the CHEEZY aluminum ones. The aluminum casting will more than likely fail. 4x4 places are a good place to shop. V10
Re: LOWERING BLOCKS
[Re: PARTSMAN440]
#303922
12/03/10 12:47 AM
12/03/10 12:47 AM
Thumperdart
State of confusion
My buddy made me some 2" billet alum. ones w/angle cut in em to get my pinion angle where I needed it.........$40.00 for the pair and bullet proof.
Re: LOWERING BLOCKS
[Re: Thumperdart]
#303923
12/03/10 12:56 AM
12/03/10 12:56 AM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
Hey Dom,its nice seeing you post again!!!!! Hope all is well!!!
Any pics of the blocks?? How thick of a block you use and whats your pinion angle??
Re: LOWERING BLOCKS
[Re: MIKES_DUSTER]
#303924
12/03/10 01:12 AM
12/03/10 01:12 AM
Thumperdart
State of confusion
Thankxxx..........don`t have pics but it`s just a slab of billet alum. cut at an angle I suggested to get me my 4 1/2-5 degrees down w/my cal-tracs. He stopped making em so I can`t hook you up.....sorry.
Re: LOWERING BLOCKS
[Re: MIKES_DUSTER]
#303929
12/06/10 04:52 AM
12/06/10 04:52 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
What about adjustable lowering blocks??? Do they adjust the height or the rear back and forth??
If you see them advertised but no pictures, I bet they are the circle track ones that adjust rear steer fore and aft. We used them all the time in the circle track car I worked on.
