Page 4 of 6 1 2 3 4 5 6
Re: Lake Powell is 70% empty [Re: Pacnorthcuda] #3038259
04/29/22 03:11 PM
04/29/22 03:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted by Pacnorthcuda
Originally Posted by HotRodDave
The natural flow of the Colorado river should be around 20,000 cubic feet per second
The Columbia river dumps 265,000 cubic feet per second of fresh water into the ocean! Over 10 times what the un-interrupted flow of the Colorado should be!
My idea is the best and everyone else's is terrible! (just kidding) but honestly they do not need to pump much, just dump a small portion of the Columbia into a pipe near Portland, lay 1000 miles of pipe on the ocean floor to LA with no tunneling needed and very minimal disturbance to any ecosystems and if there is a leak big stinking deal as that fresh water was just about to end up in the ocean anyhow. The only pumping needed would be to pump it out of the southern end of the pipe into the LA water plant or a reservoir or something. If you try to get it from the other side of the Rockies you will need at least 1500 miles of pipe, drilling through mountains and under or over roads, securing right of ways, pumping it up hill several thousand feet takes a lot of energy, that's how we make so much energy damming it up and letting it fall a couple hundred feet. This plan frees up the portion of Colorado river water going to southern California cities so Phoenix and Vegas can have more, heck we could probably get Mexico to chip in some of the cost if we let some more of the Colorado flow into Mexico.
It’s not your idea, it’s been talked about for many years.
https://www.sandiegouniontribune.co...california-columbia-2015apr10-story.html
I'm fine with someone thinking of it first but I did come up with it on my own when I saw the columbia river outlet in person back in 2013 when I went to portland for a 24 hours of lemons race, I though my goodness that is a lotawata dumping in the ocean, they should pipe it down to the dessert.
Re: Lake Powell is 70% empty [Re: HotRodDave] #3038268
04/29/22 03:51 PM
04/29/22 03:51 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've seen the Columbia River and it is huge. More like the Mississippi and the Missouri River. Not the little drainage ditch we call the Colorado River. Just amazes me that over 30 million people rely on that little trickle. What ever they do is going to require buttloads of money.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Lake Powell is 70% empty [Re: moparmarks] #3038288
04/29/22 05:09 PM
04/29/22 05:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Everyday we waste money on pet projects. Let’s spend some on our country because we all would benefit.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lake Powell is 70% empty [Re: pittsburghracer] #3038310
04/29/22 07:06 PM
04/29/22 07:06 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Any farther comments from me would move this topic to the unmoderated section. I kind of wish it would be moved there, I have a lot of stuff I would like to comment on, but I will not be the guy that gets it moved.
Re: Lake Powell is 70% empty [Re: moparmarks] #3038422
04/30/22 09:12 AM
04/30/22 09:12 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I had not pondered anything but diverting Missouri River water to the Colorado Watershed.
Assuming you need at least 200 feet of elevation drop to avoid pumping,
at what spot is one of the many rivers of the Columbia River Watershed
200 feet above either Lake Powell or Lake Mead’s elevation?
Perhaps the Northern section of a Western USA water diversion
should be a “Y”
with one leg running to the Columbia watershed, and another leg running to the Missouri watershed.
Thinking again about rock aquifers underground that already exist due to nature,
one leg of the Y should run to a rock aquifer that can be fed from the Columbia
and the other leg of the Y should run to a rock aquifer that can be fed from the Missouri.
Aquifer water reduces the chances of the Colorado getting unwanted life, like the Chinese Carp, etc.
Re: Lake Powell is 70% empty [Re: 360view] #3038462
04/30/22 12:11 PM
04/30/22 12:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Most of the Columbia river water talk is about a pipeline.it would have to be huge, would cost many billions, and would involve hundreds of lawsuits. Theoretically possible, not so sure that it’s practically possible.
Re: Lake Powell is 70% empty [Re: Pacnorthcuda] #3038464
04/30/22 12:14 PM
04/30/22 12:14 PM
I live on the Naches River, which drains into the Yakima River, which drains into the Columbia. So if they build the pipeline I could theoretically toss a rubber duck out my backyard and it would go to some farmer’s field in California!
Re: Lake Powell is 70% empty [Re: Pacnorthcuda] #3038510
04/30/22 02:57 PM
04/30/22 02:57 PM
There was talk about piping Columbia River water through a pipe in the Pacific Ocean to SO CA back in the 1970s, to many environmentalists started screaming and protesting and threatening lawsuits so it got drop.
I have to cross the Columbia River to go to Washington to visit family or go racing up there, it is big and carries a lot of water into the ocean work I'm not sure how much of the water in the Columbia drains out of Canada, I know a lot of the water in the Columbia drains out of Idaho, Washington and Oregon.
The Snake River Gorge reminds me of the Grand Canyon, not as long or probably not as deep either whistling grin
The power of water flowing bow
Re: Lake Powell is 70% empty [Re: Cab_Burge] #3039234
05/03/22 12:33 AM
05/03/22 12:33 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Columbia starts up in British Columbia and flows south . . .
Re: Lake Powell is 70% empty [Re: 360view] #3039278
05/03/22 08:54 AM
05/03/22 08:54 AM
USA
3
360view Offline
360view  Offline
3
USA
A large nuclear powered boat should fill up with Columbia river water and transport it down to California.
USA will soon retire a entire class of nuclear powered Aircraft Carriers....
Russia has a fleet of Nuclear powered Ice Breakers,
and at least one “floating Nuclear Power Plant”
Re: Lake Powell is 70% empty [Re: 360view] #3039314
05/03/22 10:52 AM
05/03/22 10:52 AM
a12rag Offline
a12rag  Offline
Well here is something on the desalination front :
https://www.designboom.com/technolo...n-unit-generates-clean-water-04-29-2022/
Can be solar powered !!! . . . there it is, time to ramp up the scale and start sucking up the pacific for the parched California areas . . .
Re: Lake Powell is 70% empty [Re: a12rag] #3039343
05/03/22 12:27 PM
05/03/22 12:27 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Lake Mead is giving up some secrets
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Lake Powell is 70% empty [Re: bigdad] #3039348
05/03/22 12:34 PM
05/03/22 12:34 PM
CA
crackedback Offline
crackedback  Offline
CA
Vegas is right next door.... probably not the only weighted swimmer in that lake. grin
Old home foundations isn't apparently the only findings going on out there.
Re: Lake Powell is 70% empty [Re: crackedback] #3039562
05/04/22 01:58 AM
05/04/22 01:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
“Barrel washed up on shore”…. I think she got that wrong smile
….believe they found another body before this one.
Re: Lake Powell is 70% empty [Re: J_BODY] #3043533
05/19/22 10:33 AM
05/19/22 10:33 AM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lake Powell is 70% empty [Re: crackedback] #3043546
05/19/22 11:18 AM
05/19/22 11:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
maybe Hoffa will surface laugh2
Re: Lake Powell is 70% empty [Re: TJP] #3043581
05/19/22 12:48 PM
05/19/22 12:48 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Anyone ever check out molten salt solar installations? For generating power it's a stupid idea, but I wonder if the same principal could be used for desalination. Boil salt water with concentrated sun light. Not like we don't have deserts right on the ocean.
Re: Lake Powell is 70% empty [Re: MarkZ] #3043620
05/19/22 03:00 PM
05/19/22 03:00 PM
CA
crackedback Offline
crackedback  Offline
CA
Environmentalist are already pissed about that type of facility. Birds fly through the "hot zone" and get roasted in flight.
Re: Lake Powell is 70% empty [Re: crackedback] #3043640
05/19/22 03:53 PM
05/19/22 03:53 PM
PA.
"Little"John
"Little"John
PA.
Kinda like getting killed by windmills, only different. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lake Powell is 70% empty [Re: pittsburghracer] #3043644
05/19/22 04:03 PM
05/19/22 04:03 PM
CA
crackedback Offline
crackedback  Offline
CA
Yep... everything has a potentially inherent hazard. Youtube, I think, has some videos of cooking birds in flight...
