ARP Exhaust Bolt - same material? #3036611
04/24/22 03:02 PM
04/24/22 03:02 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
So a while back I picked up the ARP 144-1202 header bolt kit in prep for my TTI W2 build, and while these are nice, they are just too short to work with the hefty flanges on the TTIs. These bolts are all 0.750" UHL.
Looking through ARP's catalog I find 641-1000, which is a 5/16-18 bolt but with 1.000" UHL...seems like that's exactly what I need.
Strangely though, ARP does not list an exhaust header bolt kit that is a 5/16" with 1.000" UHL.
So I'm wondering: are these the same bolts as the ones in the kit, just longer?
Heck, these are only holding the headers on, so I can't imagine the materials would need to be all that different...but what do I know about materials sience...LOL, so I thought I'd check-in here.
Thanks!
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3036614
04/24/22 03:06 PM
04/24/22 03:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
These are listed as header bolts. Bolts
Re: ARP Exhaust Bolt - same material? [Re: NITROUSN] #3036615
04/24/22 03:08 PM
04/24/22 03:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Summit lists them as header bolts. What am I missing? Summit
Re: ARP Exhaust Bolt - same material? [Re: NITROUSN] #3036623
04/24/22 03:28 PM
04/24/22 03:28 PM
Windsor, ON, Canada
Windsor, ON, Canada
...the ARP part you pointed to is a 3/8-18 thread...I need a 5/16-18.
In fact, initially I actually ordered the ARP 100-1209 kit, which is a 3/8-18 x 1" bolt, only to discover that I actually need a 5/16 thread.
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3036638
04/24/22 04:39 PM
04/24/22 04:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I see that. I just searched 5/16 x 1 inch header bolt. To bad your heads were not made with 3/8 threads. 5/16 seems like an odd ball.
Re: ARP Exhaust Bolt - same material? [Re: NITROUSN] #3036644
04/24/22 04:46 PM
04/24/22 04:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Would these work? Bolts
Or these. Hedman
Re: ARP Exhaust Bolt - same material? [Re: NITROUSN] #3036678
04/24/22 06:46 PM
04/24/22 06:46 PM
Windsor, ON, Canada
Windsor, ON, Canada
Both good finds, I hit these up as well:
1) Summit Lock bolts - never used this style before so I'm a little hesitant to toss these into a street car where the header to chassis clearance is already tight
2) Hedman - larger 6pt head (7/16) vs 12-pt (3/8) on the ARP, there are a couple of tight spots on this install, like the #7 cylinder, where I literally need every tiny little amount of wrench room, I say this because my old headers were using the shorter 6pt Hedman bolts and it was such a PITA to tighten up a few of these bolts
I'll fire off a quick inquiry to ARP next.
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3037219
04/26/22 11:54 AM
04/26/22 11:54 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3037398
04/26/22 10:03 PM
04/26/22 10:03 PM
Windsor, ON, Canada
Windsor, ON, Canada
Alright, so here is the update from ARP (two emails actually):
1) my question was: are the materials different in these two bolt kits?
"There is no difference in the material type of the two kit numbers you have provided. They are both the same chrome moly steel. The only difference will be the collar diameter. The exhaust manifold kit has a reduced collar diameter for clearance on the header tubes. If this will not affect you, then you should be good to go."
2) my question was: so what is the actual collar diameter on the 1" bolt, or at least what's the difference between the two of them (so that I can measure out the clearance I need on the headers)?
144-1202 UHL .750” Collar OD .530”
641-1000 UHL 1.000” Collar OD .620”
Bottom line, the 641-1000 is just fine given that the washer that comes in the 144-1202 kit is already a 0.670" side anyways.
Re: ARP Exhaust Bolt - same material? [Re: CMcAllister] #3037399
04/26/22 10:05 PM
04/26/22 10:05 PM
Windsor, ON, Canada
Windsor, ON, Canada
Wow!!!
Can't go wrong with that find...7/8" should be fine, I need to measure that out, but it's such a tiny (1/8") difference...and heck, 50 pcs for $6.20???
Awesome find, thank you again, I'll most likely pick these up!
EDIT
Hmm...just realized these are plain steel, which is going to rust in this application, can't do that! damn...
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3037551
04/27/22 10:30 AM
04/27/22 10:30 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Maybe you'd like these/attached. Or not.
Rich H.
Esse Quam Videri
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3037634
04/27/22 03:24 PM
04/27/22 03:24 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Originally Posted by Diplomat360
Wow!!!
EDIT
Black oxide will eventually rust too. Stainless won't. Gold zinc won't, if you can find those.
Re: ARP Exhaust Bolt - same material? [Re: CMcAllister] #3037647
04/27/22 03:51 PM
04/27/22 03:51 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Stainless will gall aluminum threads. Not an issue if your aluminum head has helicoil inserts though. If not use anti-seize.
Re: ARP Exhaust Bolt - same material? [Re: Sniper] #3037657
04/27/22 04:20 PM
04/27/22 04:20 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
He's using iron W2 econo heads I think.
https://arp-bolts.com/kits/arpkit-detail-b.php?RecordID=2445
https://www.summitracing.com/parts/arp-612-1000
You're overthinking this, don't worry. I've used Chinesium hardware store SS bolts for exhaust before. These will work just fine.
Re: ARP Exhaust Bolt - same material? [Re: MarkZ] #3038061
04/28/22 09:48 PM
04/28/22 09:48 PM
Windsor, ON, Canada
Windsor, ON, Canada
MarkZ, guys...
Correct, cast iron W2 race econo (long-valve).
I can't do it Mark...my OCD is holding me prisoner: the TTIs are finished in ceramic Black Satin...can't have a shiny steel/chrome bolt heads on those flanges, just can't do it man!!! LOL
(like I said, I'm a prisoner...now you know why my coupe took THAT long to hit the road)
Thanks again to everyone, great suggestions!!!
Re: ARP Exhaust Bolt - same material? [Re: Diplomat360] #3038233
04/29/22 01:17 PM
04/29/22 01:17 PM
moparx Offline
moparx  Offline
any time i use stainless hardware i use anti-seize.
stainless will gall in any type of material if anti-seize is not used.
i use the copper high temperature stuff on all applications.
just my life experience, your mileage will vary.
beer
