Tranny #3036938
04/25/22 12:47 PM
04/25/22 12:47 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
1967 R/T and when sitting for more than a few days , when starting in park, it would not go into drive or reverse very well. Putting it in neutral, while running, it would engage just like new. Rebuilt a newer BB727 and new converter. Swapped the valve body from the old to new trans. Issue is actually worse then before but going to neutral fixes the issue. The only common denominator is the valve body. Can this be the cause? Thanks in advance. Addition. I drove it for about 25 miles yesterday and when starting in park it didn't want to move. Worse than before as if I drove it daily or within a few days, there was no issue.
Re: Tranny [Re: terzmo] #3036972
04/25/22 02:22 PM
04/25/22 02:22 PM
A727Tflite Offline
A727Tflite  Offline
Some guys drill the valve body at the torque converter regulator valve and this will cause a more rapid converter drain.
Warm it up and drive it, then verify the fluid level in neutral before shutting the engine off.
Check the fluid level the next day before starting. If the fluid is very high on the stick then likely you have excessive drainback.
Start it and once you get a good engagement check the fluid again, it should be much lower now.
Excessive pump face clearance causes this as well.
Re: Tranny [Re: A727Tflite] #3037024
04/25/22 05:34 PM
04/25/22 05:34 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Checked it when cold and stick was way over...started..ran...stick said 1/2 qt down. So CAN it be the valve body?
Re: Tranny [Re: terzmo] #3037028
04/25/22 05:39 PM
04/25/22 05:39 PM
A727Tflite Offline
A727Tflite  Offline
If the problem followed the valve body then it could. Try a bone stock valve body.
Or just start it in neutral and wait a few seconds.
Re: Tranny [Re: A727Tflite] #3037031
04/25/22 05:49 PM
04/25/22 05:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sitting for a few days allows the converter to drain. The fluid doesn't pump in park so you need to start in neutral which does circulate the fluid. It's basically normal for that to happen. trans go makes a no yo yo kit to cure that.
Re: Tranny [Re: A727Tflite] #3037032
04/25/22 05:55 PM
04/25/22 05:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or install a Transgo No Yo-Yo kit.
Re: Tranny [Re: John_Kunkel] #3037055
04/25/22 07:07 PM
04/25/22 07:07 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Or start the motor, put it in neutral for 30 seconds before you put it gear, it will be ready to go. You do want to make sure the level is full while it is warmed up, running it a 1/2 quart low is never a good idea.
Re: Tranny [Re: stumpy] #3037092
04/25/22 09:09 PM
04/25/22 09:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up Used to be called morning sickness wink Will usually get a bit worse over a long period of time like 50K miles. I was told many years back that the condition was due to excess clearance between the converter and bushings. Maybe JK or Tman can confirm or deny that.
Doesn't seem to bother anything as along as the neutral thing is done before dropping into gear as I drove my 66 wagon with it go over 50k miles. This was before the Trans go No Yo Yo Kit was out there or before I became aware of it. I believe they have incorporated the "fix" into all of their shift kits
Feel free to correct me if I am in error beer
Re: Tranny [Re: TJP] #3037094
04/25/22 09:24 PM
04/25/22 09:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There could be a ball missing in the valve body causing the drain back.
Re: Tranny [Re: stumpy] #3037106
04/25/22 10:16 PM
04/25/22 10:16 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
It was ok the next day and even a few days later. The old 67 tranny is in my garage and the one installed was rebult..71 but it's now worse than before..lol
Re: Tranny [Re: John_Kunkel] #3037107
04/25/22 10:17 PM
04/25/22 10:17 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I assume this cannot be installed with the tranny in the car?
Re: Tranny [Re: terzmo] #3037108
04/25/22 10:20 PM
04/25/22 10:20 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Put the simple shift kit on so you do not get converter drain like you have now
The member who posted above was on the money saying to do so.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Tranny [Re: NITROUSN] #3037123
04/25/22 10:49 PM
04/25/22 10:49 PM
Or the anti drain back ball could have junk in it holding it open all the time scope up twocents
Re: Tranny [Re: 340SIX] #3037163
04/26/22 06:58 AM
04/26/22 06:58 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Explain a bit better about simple shift kit. Is this stock? Can it be installed with tranny in the car? Shift kit is valve body ?
Re: Tranny [Re: terzmo] #3037221
04/26/22 12:13 PM
04/26/22 12:13 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Yes it can, pull the valve body and do it on the bench , re install the valvebody. The part you are replacing is the shift(manual) valve , it allows more fluid flow in park than the stock valve does.
Re: Tranny [Re: TJP] #3037249
04/26/22 01:31 PM
04/26/22 01:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are no converter anti-drain back provisions in the Torqueflite, drain back is perfectly normal...as long as there is any clearance in the pump bushing, fluid will drain from the converter when sitting (or when idling for prolonged periods in Park). Of course, the more clearance, the quicker it will drain.
Much ado about this, but the cure is either starting in Neutral or installing the redesigned manual valve.
Re: Tranny [Re: John_Kunkel] #3037258
04/26/22 02:05 PM
04/26/22 02:05 PM
Guitar Jones Offline
You can buy just the valve from Sonnax.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Tranny [Re: JohnRR] #3037377
04/26/22 09:37 PM
04/26/22 09:37 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
So does this also make the tranny a manual shift only ? thanks for the info. Approximate cost and where to get?
Re: Tranny [Re: terzmo] #3037761
04/27/22 09:10 PM
04/27/22 09:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
No on the manual shift,
AMAZON LINK
likely able to find elsewhere as well, Trans go part # SK TF SC
beer
Re: Tranny [Re: TJP] #3037858
04/28/22 06:14 AM
04/28/22 06:14 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Thank You very much I ordered and hope it fixes My issue.
