727 torque converter #3037059
04/25/22 07:14 PM
04/25/22 07:14 PM
Hobart
1stealth1 Offline OP
Hobart
I bought a torque coverter 12 years ago best converter i owned until trans blew and now cant get motor to run correctly.
I was told from a&a it was a j converter but the part number doesnt seem rigjt to me if anyone can tell me what converter it is
Re: 727 torque converter [Re: 1stealth1] #3037164
04/26/22 07:09 AM
04/26/22 07:09 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Turbo-action J converter part # is 17509-J. That being said I think B&M are the originators of it so it could be theirs. They were built off a Morris-Minor core and many companies used them for various applications till the supply ran out. The torque converter can make or break a combination. If it can't be modified to what you need sell it and get what the converter company recommends.
Re: 727 torque converter [Re: fbs63] #3038466
04/30/22 12:21 PM
04/30/22 12:21 PM
Hobart
Hobart
Been trying to figure out this part number car hasnt ran great since it blew
Re: 727 torque converter [Re: fbs63] #3038527
04/30/22 03:47 PM
04/30/22 03:47 PM
I was told that the original B&M 069J Mopar race converters were built from English Ford Cortina cores, not sure about the T/A 069J converters confused
I was lucky enough to get an original stock unmodified B&M 069J converter , it was great up boogie
Until I broke it beyond repair realcrazy puke whiney
Re: 727 torque converter [Re: Cab_Burge] #3038543
04/30/22 04:35 PM
04/30/22 04:35 PM
A727Tflite Offline
A727Tflite  Offline
At some point in time they used Opal converters.
If they ever build a Museum for converters the O69J would be the main attraction.
Re: 727 torque converter [Re: A727Tflite] #3039080
05/02/22 01:10 PM
05/02/22 01:10 PM
I had heard that they use the Opal converters also work confused
Re: 727 torque converter [Re: Cab_Burge] #3039147
05/02/22 05:10 PM
05/02/22 05:10 PM
A727Tflite Offline
A727Tflite  Offline
I spoke to a guy much closer than I to converter development back in the day and he said Falcon, Cortina and Opal converters were used in various applications.
Can’t recall in what order they were used between the Cortina and Opal. The Falcon was believed to be used in the old 6877F
Which I believe was the predecessor to the Cortina and Opal. I think a tad larger than the other two.
